Tloc Extension using NAT
K.Inaba-MD
Hi Everyone,
By inserting NAT settings on the WAN interface of cedge, we are checking the operation of TlocExtension.
The cedge establishes a control connection, but does not establish a BFD session.
I would like to establish a BFD session, is it possible to share any similar knowledge?
The SD-WAN versions are as follows:
 vmanage,vbond,vsmart: 20.15.1
 cedge(C1111-8P): 17.12.03a.0.4
Kei
We used a private color because the network environment uses a closed network, but if you use NAT, you need to use a public color regardless of the type of network.
6 Replies 6
K.Inaba-MD
I'm already aware of that site article.
I have used Tloc Extension to build SD-WAN environments multiple times.
Based on that premise, I am filing a petition because it is not available.
A control connection can be established, but a BFD session cannot be established.
Does anyone have a solution or experience with a similar situation?
Dan Frey
What color are you using on the tloc-ext interface?      What color is the remote TLOC interface where BFD is not being established?
Did you solve problem?
Can you share some detail with us
MHM
And what type of NAT do you use? PAT on both side or symmetric 1:1 NAT?
HTH,
