Cisco SD-WAN vManage Task doesnt work
Hi.
I always appreciate to all help.
I have a LAB environment, and I'm testing something.
When I try "set default version" in the Maintenance > Software Upgrade, It doesnt work.
I think API for this task doesnt work between vManage <-> cEdge. (Kind of hanging)
There is any log in the cEdge console screen except this log.
*Sep 5 07:52:59.925: %DMI-5-AUTH_PASSED: R0/0: dmiauthd: User 'vmanage-admin' authenticated successfully from 169.254.10.3:47040 for netconf over ssh. External groups:
Version
- vManage, vBond, vSmart : 20.12.3.1
- C8500-12X : 17.12.3a
I would appreciate If anyone gives me help.
Thank you.
I've solved this by rebooting vManage.
Praveen Anand
Hi JJpark,
Thank you for the post, you also learn about Cisco SD-WAN api here and in the Manager API Swagger (you can access it by - https://<manager-ip>/apidocs )
- Praveen Anand
Thank you. I will check it.
