vEdge 100B Maximum Throughput
awatson20
Level 4
Level 4
I am trying to understand what the throughput capacity is for a vedge 100b GigabitEthernet port.  Assuming I had a 1GB Internet connection terminated on a vedge 100B port, what is the maximum throughput rate I could achieve?  I have not found any documentation that details this. Thank you.
inderdeeps
Level 4
Level 4
The overall throughput of the device is 100 Mbps which is AES-256. You will not able to get more than 100 Mbps on that box.
Check the link below
Cisco SD-WAN Routers Data Sheet (etilize.com)
Inderdeep Singh
www.thenetworkdna.com
***RATE MY RESPONSE IF YOU LIKE MY REPLY ****
