Viptela - Endpoints
altafaddy
I know other vendors have a solution for endpoints(end users) to connect with SDwan. Does Cisco-Viptela? Sounds like a no brainer that end users would be the last piece to connect into a fully connect tunneled environment instead of having a separate solution for vpn connections at the end user level.
Are you looking for Remote Access with SD-WAN?
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-ra/cisco-sd-wan-remote-access/m-sdwan-remote-access1.html
HTH,
Lei Tian
As others have mentioned, integrated RA is supported. Another option is to use the Cisco SSE solution. https://www.cisco.com/c/en/us/products/collateral/security/secure-access/hybrid-workforce-cloud-agile-security-ds.html
HTH,
Lei Tian
