12-29-2023 03:29 PM
I'm in need of assistances please. Our Viptela SDWAN design is a Hub and Spoke which have two VRF's. VPN200 interface has a vrf of 200 for Mgmt. and VPN100 has a vrf 100 for Customer internal network. I need to create a policy that simulates the default route (0.0.0.0/0) disappearing in the vrf 100 customer network. I am doing this to see if our SolarWinds monitoring platform will trigger an alert when the default route (0.0.0.0/0) disappears. I have researched countless documentation on cisco site but have found no real answer, I hope someone can give me guidance on how to achive this please.
-Sebastian Haislmaier
12-30-2023 12:30 PM
how is device configured for default route? Or it receives via OMP dynamically?
12-31-2023 09:57 AM
Default route received via omp dynamically in the vrf100
12-31-2023 10:10 AM
Then, create centralized policy for that specific site in OUT direction which filters 0.0.0.0/0 route (match: 0.0.0.0/0 and action: reject).
01-03-2024 03:59 AM
@Sebastian Haislmaier did you check this option? If you have problem with creating this policy section, I can help.
Just inform, you are testing in production or in lab and you have the same control policy for all sites or separate for each.
12-30-2023 01:39 PM
You have vedge or cedge?
MHM
12-31-2023 10:50 AM
Hubs are C8500-12X
Spokes are C1121X-8P
01-03-2024 02:41 AM
