Viptela SD-WAN vEdge connection problem
joyanta.debnath
hi there i am having a problem during adding vedge to vmange. when i bring up one vedge at that point my vbond went down and vedge information(system ip) showing in the vbond section. hereby i have attached the config of all my devices.
thanks in advance for your support.
joyanta.debnath
hi i found the problem. this one i tried in eve and the os version was 20.2. I did downgrade the os level 19.2 and its now working fine.
Lei Tian
vBond doesnt need tunnel config. Try remove the vbond tunnel config and see if you can onboard the vedge.
HTH,
Lei Tian
joyanta.debnath
hi, thanks for your feedback. i have tried without ipsec in vBond. but the result is smae.
joyanta.debnath
see my vbon connection
vBond# show orchestrator connections
PEER PEER
PEER PEER PEER SITE DOMAIN PEER PRIVATE PEER PUBLIC ORGANIZATION
INSTANCE TYPE PROTOCOL SYSTEM IP ID ID PRIVATE IP PORT PUBLIC IP PORT REMOTE COLOR STATE NAME UPTIME
0 vedge dtls 10.12.0.1 12 1 192.1.1.2 12366 192.1.1.2 12366 public-internet up lab 0:00:03:24
0 vsmart dtls 10.100.0.12 100 1 223.1.1.12 12346 223.1.1.12 12346 default up lab 0:00:12:47
0 vsmart dtls 10.100.0.12 100 1 223.1.1.12 12446 223.1.1.12 12446 default up lab 0:00:12:48
0 vmanage dtls 10.100.0.10 100 0 223.1.1.10 12346 223.1.1.10 12346 default up lab 0:00:24:35
0 vmanage dtls 10.100.0.10 100 0 223.1.1.10 12446 223.1.1.10 12446 default up lab 0:00:24:36
but in vsmat it showed the vbond is down
joyanta.debnath
