vManage alarm notification for site-site tunnel down
We are deploying an SD-WAN environment in a HUB-Spoke configuration, where tunnels from the Site to the HUB and to other Sites are up. When a tunnel between Sites goes down, we want to be notified through some means. Do you know if there's any way to achieve this? Although there are some notification patterns in vManage Alarm notification, none seem to be applicable. (Is it possible that there's no scenario where only the tunnel between Sites goes down?)
Pulkit Mittal
Hi there,
You can configure smtp notifications for the alarms using  Cisco Catalyst SD-WAN Monitor and Maintain Configuration Guide - Alarms, Events, and Logs [Cisco SD-WAN] - Cisco
If you find this useful, please mark it helpful and accept the solution.
The SMTP settings are already configured, and Alarm Notifications are being received. My question is, is there a way to be notified when the tunnel between sites goes down? (Other than Alarm Notifications would also be fine.) If you have any good ideas, please let me know.
