vManage RESTAPI for applications running on cEdge
AD32111
I am looking for a vManage real-time API which gives us applications on a device.
device/dpi/applications API works for vEdges but it returns empty data response for cEdges.
Please let me know the corresponding API for cEdge
I tried the APIs in the section “Real-Time Monitoring - DPI” from the link https://developer.cisco.com/docs/sdwan/#!reference-device-realtime-monitoring.
They work for vEdges but cEdges are returning empty data.
Are the APIs in the section “Real-Time Monitoring - DPI” applicable only for vEdges and not for cEdges ?
8 Replies 8
inderdeeps
Level 4
Level 4
Did you check the below link
https://developer.cisco.com/docs/sdwan/#!introduction/cisco-sd-wan-vmanage-api
Inderdeep Singh
www.thenetworkdna.com
****RATE MY RESPONSES IF YOU LIKE****
I did look at the link.
Like how we have device/dpi/applications API for vEdges, what is corresponding API for cEdge?
No these should work for both vEdges and cEdges. What version of code you are using on cEdges. Need to verify if there is any issue there
Inderdeep Singh
****RATE MY RESPONSE IF YOU LIKE MY REPLY***
Using 20.1.1 version on vManage. cEdge is running with 17.3.2
Can you let me know the cEdge used here ?
I see that there is compatibility issue between these version codes. Can you check here 20.1.x below, I dont see 17.3.2 version compatible
Cisco SD-WAN Controller Compatibility Matrix and Server Recommendations - Compatibility Matrix [Cisco SD-WAN] - Cisco
Inderdeep Singh
***RATE MY RESPONSE IF YOU LIKE***
May not be compatibility issue. All other APIs are working fine except DPI APIs. device/dpi/applications is returning empty data even with
vmanage "version": "20.3.1"
cEdge ISR4331 "version": "17.03.01a.0.354"
Yeah then this is something odd, Did you open a ticket with Cisco TAC. I will check if i see anything related to this kind of issue in my circle and help you out !
Inderdeep Singh
