SDWAN underlay route via interface not next hop
etalaveran
I have an IR1101 router with Cellular interface(Cellular0/1/0).
This interface has  a /32 ip address.
I need to configure an ip route via this interface but it is not possible with VPN template that only allows next hop.
I'm trying with a CLI ADD-ON template like this, but  I get an error.
vpn 0
ip route X.X.X.X/16 Cellular0/1/0
There is a way to configure via templates (feature or CLI) a route with an outgoing interface rather than next hop?
ekhabaro
There is no need for CLI addon template to configure static route via interface, you can configure next-hope as interface in a feature template as well. Moreover your syntax is incorrect in the CLI template, you don't need intent notation (ViptelaOS-like), you should use IOS syntax there (ip route / ip route vrf )
ekhabaro
I'll keep both solutions, self ip address next-hop and cli add-on.
Because in some cases the IP address could change
Do you have a link to a CLI add-on configuration guide ?
How do I set an interface as next-hop in a feature template?
inderdeeps
Level 4
Level 4
when you deploy template from your vManage, you always put the IP address of the interface and the next hop of that ip which is actually a ip route. So no need to put it via CLI command.
Inderdeep Singh
