vManage server is not ready or temporarily unavailable
Hi everyone.
I have one vManage (20.7.1) in standalone mode in my eve-ng. Yesterday I had an eletric power disruption at home and my vManage seems to have died.
I can telnet to 8443 from my desktop. But I've tried to wget through vMware console and I got 503 error like below.
NMS services seems to be ok:
I performed the command: request nms configuration-db diagnostics ang I've got the output:
Is it the reason of failure? How to fix that? I have tried to start this service, but I couldn't.
Furthermore, I tried to make a copy of the vManage's DB using the following command, but it didn't create the .tar.gz file as described. It looks like to create only the log file about this tried.
I hope someone could help me out to get a backup file from vManage database (specially regarding the templates) either having the GUI interface access enabled again...
Thanks in advance.
10 Replies 10
Copied from another thread with the same issue
These are complicated issues to figure out given that many components come to play for services to come up online and operate as expected but you can do this to have a better idea of what the problem might be:
In vManage CLI: #request nms all restart
Now get into vshell mode: #vshell
On vshell mode: $ tail -f /var/log/nms/vmanage-server.log
Try to track any error message or something that looks obvious regarding application services
If you can log the session, upload it to review it as well.
You may want to have 2 CLI sessions opened one where you can run a "request nms all status" to check if services are coming up and the other one with the tail -f command.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hi @bigevilbeard
I have collected the logs as mentioned and catched some error messages as below. The entire file was attached as well.
I am turned if you could have a light on this.
Much appreciate that.
Output:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.08.04 10:50:09 =~=~=~=~=~=~=~=~=~=~=~=
Successfully stopped NMS CloudAgent v2
INFO[2023-08-04T13:50:36.095666460Z] Container 20ec2e40c242d796cf69a749168a39c8e150c631dd2f5ae780bac46908734479 failed to exit within 10 seconds of signal 15 - using the force
INFO[2023-08-04T13:50:36.238595971Z] shim reaped                                   id=20ec2e40c242d796cf69a749168a39c8e150c631dd2f5ae780bac46908734479
INFO[2023-08-04T13:50:36.248410291Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:50:36.304371643Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully stopped NMS cloud agent
Successfully stopped NMS service proxy
INFO[2023-08-04T13:50:47.413085395Z] Container b4b40c1e4cd5e62e499a5a12485a7fc8abec933e4e5b662e141bc5ae44ab989f failed to exit within 10 seconds of signal 15 - using the force
INFO[2023-08-04T13:50:47.523448367Z] shim reaped                                   id=b4b40c1e4cd5e62e499a5a12485a7fc8abec933e4e5b662e141bc5ae44ab989f
INFO[2023-08-04T13:50:47.532715733Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:50:47.542607502Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully stopped NMS service proxy rate limit
INFO[2023-08-04T13:50:57.606185451Z] Container bf0cd46a5ccc989066629b409232f5b623917a62410479a94ccabf9d68802a61 failed to exit within 10 seconds of signal 15 - using the force
INFO[2023-08-04T13:50:57.721849922Z] shim reaped                                   id=bf0cd46a5ccc989066629b409232f5b623917a62410479a94ccabf9d68802a61
INFO[2023-08-04T13:50:57.732761131Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:50:57.806564312Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully stopped NMS application server
Successfully stopped NMS data collection agent
Successfully stopped NMS messaging server
INFO[2023-08-04T13:51:04.840662284Z] shim reaped                                   id=580717c371f2c4f587ce9289c194ac19aab37ae18d4c949c7303b334f56a85bd
INFO[2023-08-04T13:51:04.850367844Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:51:04.933727844Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully stopped NMS coordination server
INFO[2023-08-04T13:51:05.429794576Z] shim reaped                                   id=a183621fc7fbf04e0574873cea992497fe55ea756d7abde303a226bc0a809a72
INFO[2023-08-04T13:51:05.439460458Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:51:05.512180646Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully stopped NMS configuration database
INFO[2023-08-04T13:51:11.132989089Z] shim reaped                                   id=1b227f87593bb62f846b5c9aff489d49026df0278805c6fa5292c24d9e20de40
INFO[2023-08-04T13:51:11.142700488Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:51:11.271061927Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully stopped NMS statistics database
INFO[2023-08-04T13:51:11.847407844Z] shim reaped                                   id=4770c866d4eb09c628b0806058ffbf2ffcf9b4115135ce00d4ac7f05afee56dd
INFO[2023-08-04T13:51:11.857164936Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:51:11.936462364Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
WARN[2023-08-04T13:51:12.020346914Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
WARN[2023-08-04T13:51:12.037121336Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully started NMS statistics database
INFO[2023-08-04T13:51:12.057738710Z] No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]
INFO[2023-08-04T13:51:12.057796829Z] IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]
WARN[2023-08-04T13:51:12.078846628Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
WARN[2023-08-04T13:51:12.093553490Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully started NMS configuration database
INFO[2023-08-04T13:51:12.117852037Z] shim containerd-shim started                  address="/containerd-shim/moby/126fe1766ef8c59f7acec4514d5a7795410460e65a1499366d2b8606aab1e3cd/shim.sock" debug=false pid=32285
INFO[2023-08-04T13:51:12.119800385Z] No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]
INFO[2023-08-04T13:51:12.119866794Z] IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]
WARN[2023-08-04T13:51:12.159581756Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
WARN[2023-08-04T13:51:12.172182067Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully started NMS coordination server
INFO[2023-08-04T13:51:12.192645605Z] No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]
INFO[2023-08-04T13:51:12.192701500Z] IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]
WARN[2023-08-04T13:51:12.325464455Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
WARN[2023-08-04T13:51:12.351792029Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully started NMS messaging server
INFO[2023-08-04T13:51:12.374487971Z] No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]
INFO[2023-08-04T13:51:12.374540867Z] IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]
INFO[2023-08-04T13:51:12.401409025Z] shim containerd-shim started                  address="/containerd-shim/moby/9eb91573fa47893d20fcd7a70ae8e2b125604dd7bf128a70051859fd259fedb7/shim.sock" debug=false pid=32520
INFO[2023-08-04T13:51:12.608429671Z] shim containerd-shim started                  address="/containerd-shim/moby/ce759046ae19d75f977dc82cea80b17a6b314848a477e3d7268a17fb46089dec/shim.sock" debug=false pid=32646
INFO[2023-08-04T13:51:12.624920138Z] shim containerd-shim started                  address="/containerd-shim/moby/acef1fa256795ac822f681a0086de37a1ef52da1bce19518b96627e159d3cd49/shim.sock" debug=false pid=32658
Successfully started NMS application server
chown: cannot access '': No such file or directory
Successfully started NMS data collection agent
WARN[2023-08-04T13:51:13.433919877Z] Published ports are discarded when using host network mode
WARN[2023-08-04T13:51:13.435456618Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
INFO[2023-08-04T13:51:13.442967882Z] shim reaped                                   id=acef1fa256795ac822f681a0086de37a1ef52da1bce19518b96627e159d3cd49
INFO[2023-08-04T13:51:13.453134950Z] ignoring event                                module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
WARN[2023-08-04T13:51:13.457486909Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully started NMS service proxy
WARN[2023-08-04T13:51:13.479623201Z] Published ports are discarded when using host network mode
INFO[2023-08-04T13:51:13.503576140Z] shim containerd-shim started                  address="/containerd-shim/moby/dd9ad299a33bed387784eac6a29c60434ad67c4b4e4317b396ff6a2b5d59d591/shim.sock" debug=false pid=770
WARN[2023-08-04T13:51:13.539837188Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
WARN[2023-08-04T13:51:13.555180476Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully started NMS service proxy rate limit
WARN[2023-08-04T13:51:13.611192470Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
INFO[2023-08-04T13:51:13.639023349Z] No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]
INFO[2023-08-04T13:51:13.641678130Z] IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]
INFO[2023-08-04T13:51:13.835574456Z] shim containerd-shim started                  address="/containerd-shim/moby/4814c8834f31aed684b46cf332bad899473ad8af9f1f96289c8b26a77ced4559/shim.sock" debug=false pid=1061
python3: can't open file '/etc/sv/cloudagent/httpProxy/proxy.py': [Errno 2] No such file or directory
Successfully started NMS cloud agent
WARN[2023-08-04T13:51:14.235376682Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
Successfully started NMS CloudAgent v2
vManage# WARN[2023-08-04T13:51:14.251485326Z] auplink flush failed:                         error="exec: \"auplink\": executable file not found in $PATH" method=Unmount storage-driver=aufs
INFO[2023-08-04T13:51:14.269713412Z] No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]
INFO[2023-08-04T13:51:14.269765318Z] IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]
INFO[2023-08-04T13:51:14.330682508Z] shim containerd-shim started                  address="/containerd-shim/moby/32861389271f54e7e95f2be26b5f6de5ab5fbaf5cfa1dc632b573c3349f614f6/shim.sock" debug=false pid=1235
INFO[2023-08-04T13:51:17.998941563Z] No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]
INFO[2023-08-04T13:51:17.998995433Z] IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]
INFO[2023-08-04T13:51:18.116331354Z] shim containerd-shim started                  address="/containerd-shim/moby/acef1fa256795ac822f681a0086de37a1ef52da1bce19518b96627e159d3cd49/shim.sock" debug=false pid=1442
./finish: line 29: kill: (3584) - No such process
Setting up watches.
Watches established.
vManage:~$ tail -f /var/log/nms/vmanage-server.log
04-Aug-2023 12:13:24,480 UTC ERROR [] [ConnectionState] (vManage-akka.actor.default-dispatcher-2-EventThread) || Authentication failed
[...] OUTPUT OMITTED
Caused by: org.neo4j.driver.exceptions.ServiceUnavailableException: Could not perform discovery for database '<default database>'. No routing server available.
Suppressed: org.neo4j.driver.exceptions.DiscoveryException: Failed to update routing table with server 'localhost(127.0.0.1):7687'.
Caused by: org.neo4j.driver.exceptions.TransientException: Unable to get a routing table for database 'neo4j' because this database is unavailable
Suppressed: org.neo4j.driver.internal.util.ErrorUtil$InternalExceptionCause
/var/log/nms/vmanage-server.log:04-Aug-2023 12:13:24,480 UTC ERROR [] [ConnectionState] (vManage-akka.actor.default-dispatcher-2-EventThread) || Authentication failed
/var/log/nms/vmanage-server.log:04-Aug-2023 12:14:02,800 UTC ERROR [] [Application] (vManage-akka.actor.default-dispatcher-3) || Application failed to start
/var/log/nms/vmanage-server.log:04-Aug-2023 13:50:52,691 UTC ERROR [vManage] [LoginRedirectFilter] (ServerService Thread Pool -- 87) || Filter class com.viptela.vmanage.server.auth.LoginRedirectFilter destroy called!!
/var/log/nms/vmanage-server.log:04-Aug-2023 13:53:05,829 UTC ERROR [] [ConnectionState] (vManage-akka.actor.default-dispatcher-4-EventThread) || Authentication failed
/var/log/nms/vmanage-server.log:04-Aug-2023 13:53:40,562 UTC ERROR [] [Application] (vManage-akka.actor.default-dispatcher-2) || Application failed to start
vManage:~$
Based on the txt file the error is auplink flush failed: "exec: \"auplink\": executable file not found in $PATH". This means that the auplink command could not be found in the system's $PATH environment variable. The $PATH variable is a list of directories that the shell searches for executable files.
The auplink command is used to flush the AUPlink cache. AUPlink is a tool that is used to manage network interfaces.
Hi @bigevilbeard, thanks for replying and so sorry about my delayed response.
To make a comparison, I build up a new vManage using the same eve-ng image and I saw that the new one has the same log status regarding 'auplink'.
Do know how can I fix the 'auplink' error?
Much thanks in advance,
BR,
Maybe try “sudo apt install auplink“ and once the auplink tool is installed, you need to add its path to the $PATH environment variable. To do this, open the .bashrc file in your home directory.
I’ve only every seen this issue with Docker before. This helped in the fix then.
The key point here is about I don't have the root password to do. Sadly, it couldn't be used even analyze the log error like below cause I have only the admin credentials.
I dont think you do this on the vManage but the VM this is running on. I would ask in the support at EVE if they have seen similar issue to this, as it looks like a docker issue.
All 20.x versions don't have SU password, but token challenges for getting root privilege, only TAC can provide it. Try getting an admin-tech instead and see if neo4j logs are parte of the /var/log/ output bundle.
Hi @ericgar
I've got the admin tech as you mentioned.  I am attaching the file if you (or someone else) could help me.
If I could restore the templates from the old vManage, it will be very helpfull.
Thanks in advance,
Zarar7
I have the same issue and i fixed it. the fix was my vbond was off in my lab and when your vmanage do not have reachability it will not start in GUI. first you should establish reachability to vbond and then try to access vmaange GUI.
let me know if that worked for you
