vManage unhide command
navidn
As I was trying to push vManage (version 20.7.1) templates for vManage itself, I lost connectivity to the GUI interface and currently, I am not able to configure vpn0 and interfaces again because template overwrites itself. So, I need to go round the "is_vmanaged" state and configure the device via CLI.
Apparantly, there was a "unhide vipteal_internal" available for disabling "is_vmanaged" state which I can not find it in recent version.
I would be appreciated if anyone can help me through these situation.
5 Replies 5
Lei Tian
Try this, see if it works in 20.7?
vmanage# request support is-vmanaged disable
“is-vmanaged successfully disabled”
HTH,
Lei Tian
svemulap@cisco.com
hi Navidn -
Starting 20.4, unhide support has been taken out.
Please Checkout: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx23574
Have added:
vEdge: request support is-vmanaged [disable|enable] cEdge: request platform software sdwan is-vmanaged [disable|enable] [configure 'sevice internal' if is not seen]
Hope it helps.
navidn
Thanks for your answer,
Unfortunately, it does no apply on vManage and the CLI configuration can not be commited. Should I deploy vManage from the ground again?
Which version the vManage is running ?
Feel free to open a TAC Case if you need assistance.
vManage 20.7.1
As my vManage is running on my LAB environment I am not entiteled with any service contract to use Cisco TAC.
