Voice over SD-WAN
Hello Cisco Community.
I request your help to obtain information about how send voice (rtp) over SD WAN Solution. Actually, one customer oportunity to purchase SD-WAN solution, but the customer is requesting us a proof of concept sending voice over the SD-WAN  I don´t find information about this, so, could you share some material or url´s where the voice over SD-WAN is supported? Thanks
elesani
Hi Marco,
Within SD-WAN overlay network, this is achievable through Application-Aware Routing. In nutshell, in a pure IPv4 network or MPLS based network, QoS will utilise CoS & DSCP to deliver the classification that meets expected quality while in Cisco SD-WAN it has been moved to the application level (noting stops you to use DSCP still). so you can classify or even steer traffic based on application type (DPI engine identify different type of applications).
Through vManage, this can be configured through the Centralized Policies. Below link should give you a clue on this:
https://sdwan-docs.cisco.com/Product_Documentation/Software_Features/Release_16.3/07Policy_Applications/01Application-Aware_Routing
Ehsan
elesani
Hi Marco,
Ehsan
Hello Elesani
Please, could you share the doc again?
Thanks, Cristian
