vpn 0 and tloc redundancy question
MichaelKim24362
Controllers are in Internet.
There are 2 x cedges in DC.  1 x MPLS on MPLS cedge and 1 x Internet on INET cedge .
There are 2 x cedges in each Branch.1 x MPLS circuit on MPLS cedge and 1 x Internet circuit on INET cedge .
TLOC Extension works for connecting MPLS cedge through INET cedge.
However, control connections are only through Internet circuit.
I'm trying to establish backup control connections through MPLS, but I could not find proper information yet.
There is a way to do so by adding separate MPLS router in front of cEdge in Datacenter. This method is simply directing branch WAN network to internal and Firewall => Controllers. (attached "Topology_TLOC_Backup_solution.png")
However, what I want to achieve is without separate router as image attached "Topology_TLOC_Backup.png". The red traffic flow to connect controllers in Internet.
Is it possible?
6 Replies 6
tunnel enabled interfaced is hardcoded, does not allow transit underlay traffic through router.
Use loopback interfaces both for mpls and internet on DC-MPLS connected router.
HTH,
Thank you for your help.
Do you mean just add loopback to VPN 0? Hum.. Hope you can provide little more explanation.
My config is INET cedge has TLOC extension for MPLS cedge.
MPLS cedge has TLOC for INET cedge.
INET cedge has NAT enabled for MPLS cedge to give Internet access.
Should loopback need to be added on both edges?
As I mention LO can not use for tloc extensions (I will double check maybe cisco change this but I am sure until last check it still not support that)
Anyway
In cedge use
Ping ip <vbond> source-interface <interface use for extension>
Check if you can connect to vbond via mpls using extension
MHM
MPLS Cedge can ping to controller (vmange, vbond, vsmart) through INET Cedge.
L0 is not yet used. Just interface between MPLS and INET Cedges with physical interface.
That is why branch cannot access controllers through DC MPLS Cedge=> DC INET Cedge => Internet.
I tried TLOC extension on MPLS Cedge WAN interface but that interface is already VPN0, so not working.
I'm could not find proper solution to achieve my goal. I thought L0 may work as Kanan's comment.
Can I see config of tloc extensions in both side ?
MHM
Your tlco extension missing NAT to NATing mpls IP to internet and access to controller
Note:- LO can not use for tloc extensions
MHM
