what is API call for upgrade vEdge device in multitenancy environment
rohitspostowl
what is the right API call to upgrade the vEdge device in a multitenant SD wan environment?
because the wan edge device visibility is restricted to tenant mode.
Dan Frey
It is the same API call as single tenant but you will need to add metadata to the http header.  Run /dataservice/tenant to get the list of tenants and select a tenantId.   Once you have selected the tenantId execute /dataservice/tenant/<tenantId>/switch api and this will respond with Jsession ID and vsessionId.  Use the Jessionid and VsessionID in the http header in subsequent api calls for that tenant.
headers = {'Content-Type': "application/json", 'Cookie': jsessionid, 'X-XSRF-TOKEN': token, 'VSessionId':vsessionId}
These APIs are documented in the swagger interface in a multi-tenant enabled vmanage.
5 Replies 5
Dan Frey
Thanks a lot Dan,
Can you please help to share the same  API doc, link here.
The API doc is built directly in the mutli tenant vmanage.   Access by going to https://<vmanageIp>/apidocs
curl --location --request POST 'https://{{IP}}:{{PORT-NO}}/dataservice/dataservice/device/action/software' \
--header 'Authorization: Basic ENCODED-ID-PASS' \
--header 'Cookie: JSESSIONID=JSON-ID'
--header 'VSessionId: VSESSIOn_ID'
This curl call gives me 409
<html><head><title>Error</title></head><body>Conflict</body></html>
I faced same issue, the issue is fixed after correct vSessionId token
