WMware Mutli-Auth Problem - Cisco ISE
asliikimaya
Some of our developers work with virtual machines on their hosts. (VMware) These VMs end up in their own VLAN, which we assign via the ISE.
Client authenticates itself via certificate against the ISE
VM is in bridged mode and comes with its own MAC address on the same switch-port, which we assign to a different VLAN via MAB list
This configuration works perfectly, except for one client. There I do not see the MAC addresses of the VMs on the switch port. Only the one from the client is displayed. Switch and port configuration is identical to all others - Multi-Auth is also active. The settings in the WMware for Workstation software have also been checked. Client is a Dell laptop with docking station (Realtek network adapter). Everything is wired.
Does anyone have any ideas for me?
0 Replies 0
