ZTP in SDWAN
hroubhi03686
Hello everyone, would anyone help me to add the feature of ZTP in my LAB, please explain to me with pictures, I am new in this domain
Thanks in advance
ZTP is process for vedge physical devices. So, if you doing lab and most probably you do lab with vedge-cloud, you cant do ZTP.
Prepare Routers for ZTP
Cisco SD-WAN provides an automatic provisioning software as a service (SaaS) called zero-touch provisioning (ZTP), which allows hardware vEdge routers to join the overlay network automatically. The ZTP process begins when you power on a hardware vEdge router for the first time.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/cisco-sd-wan-overlay-network-bringup.html#c_Prepare_vEdge_Routers_for_ZTP_9826.xml
HTH,
HTH,
Thanks a lot :)
kindly ask to mark as accepted solution
HTH,
