Routing and SD-WAN
Labels
Hi every one.We have 2 routers (namely Router1 and Router2, PID is 8102-64H-O) .both of them are running the same version.It has been 2 times that Router 1 crashes.(Symptoms : all interfaces go down, device will not be responsive until some one unplu...
AshkanKiani by • Community Member
  • 137 Views
  • 1 replies
While booting up, an ISR 4k router can reload unexpectedly   in the cpp-mcplo-ucode process: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting: process exit with reload fru code %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (dm-0): previous I/O er...
mmaliyekkal by • Community Member
  • 5965 Views
  • 9 replies
Hi ,Does anyone know what this statement means ? Behavior when a Canonical Name (CNAME) record point to a different Top Level Domain (TLD)If your lookup uses a CNAME that resolves to a different Top Level Domain, FQDN rules will not be applied to tha...
Raphael_L_1-1795631753021.png Raphael_L_0-1795631731679.png Raphael_L_2-1795631799633.png
Raphael_L by • Meraki Community All-Star
  • 194 Views
  • 2 replies
hi,I read about MST in SWITCHING BOOK but after completing MST, i am not able to understand functionality of IST and CST instace in MST.can you please explain me in brief about IST and CST?Thanks and Regards,sourabh
Hi ,Has anyone deployed MX 26.2.X ? I have deployed 26.2.4 on 15 networks and it broke 2 of them. The MX starts to logg a lot of Martian Events which it never did before. Rebooting the MX "fixes" the issue. I have opened a case but in the meantime I'...
  • 443 Views
  • 5 replies
  • 2 Helpful votes
Hi all, is anyone running the C8221-G2 in routing mode (not SD-WAN)?1. Which IOS XE release did yours ship with, and what are you running in production (26.1.x or 26.2.x)? Any bugs to watch for?2. Does a routed (L3) LACP port-channel on the flex port...
markacronin by • Community Member
  • 258 Views
  • 2 replies
Hello, I'm a rather new networking student and I've been doing a simple topology regarding dynamic routing (OSPF more specifically) as my school project. I've setup a couple of protocols (HSRP, DHCPv4 and stateful v6) along with OSPFv2 (which works w...
@technology & supports About the technology and support provided by Cisco Systems and community to updates and secure access for users to their networks via their own devices with own servers , and  to make their ownership for more transparent and se...
