Fix Vulnerabilities
sachinsharma
Please help how to fix this Vulnerabilities:- SSL / TLS Renegotiation Handshakes MiTM Plaintext Data Injection
2 Accepted Solutions
from where did you found this is affecting to your current OS? if you used any scanning software, it should show cisco advisory or CVS ID related to this. through that you can find the fix using advisory document. it normally says which OS version is not impacted.
Good luck
KB
hi,
what is the device/model/platform/OS you are using? and from where did you found this is affected to your device.
Good luck
KB
Hardware: ASA5525, 8192 MB RAM, CPU Lynnfield 2394 MHz, 1 CPU (4 cores)
ASA Version 9.2(2)4
Good luck
KB
