Nexus data collection problem with SMC 6.9.2
murat001
Level 4
Level 4
Hi all
we have nexus 7k switches with f3 line card configured exporter sampler netflow data to Stealthwatch 6.9.2.
The problem explain,
Stealthwatch showing less data on interface inbound traffic  comparing to SNMP interface statics for example WAN interface has 300Mbps but  stealthwatch collect up to 100 mbps with netflow.
we can see no more than 100 Mpbs sampler mode 1 out of 1
we do not see any traffic while sampler mode 1:1000
and we can not seen any sampler configuraiton on flow collector and stealhwatch console.
which is the problem ?  nexus or swtealthwatch ?
do you have any experiance with similar problem ?
Hi brford
thanks for your suggestions
we have solved this issue by entering sample rate same as nexus side on the Flow Collector .
for your info.
brford
The issue may be the result of the use of sampled NetFlow (rather than full or un-sampled NetFlow).  The interface statistics produced in Stealthwatch when using sampled NetFlow are an approximation of the traffic based on the sampling rate and the sampling type (random or deterministic).  The statistics reported at the command line interface (CLI) of a device are often exact.
In this network the NetFlow sampled data generated by the Nexus switch can contribute to behavioral analytics but really can't be the only data source. You can greatly improve Stealthwatch findings by adding exporters that support full, un-sampled NetFlow elsewhere in the network.
Brian Ford | brford@cisco.com | brford@yahoo.com | 51 75 61 6c 69 74 79 20 6d 65 61 6e 73 20 64 6f 69 6e 67 20 69 74 20 72 69 67 68 74 20 77 68 65 6e 20 6e 6f 20 6f 6e 65 20 69 73 20 6c 6f 6f 6b 69 6e 67 2e | Email me when you figure this out.
Hi brford
for your info.
