sokakkar
Introduction
The purpose of this article is to explain the impact of interface monitoring on ASA failover pair.
Here is the documentation which is already available on Cisco.com:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ha_active_standby.html#wp1079547
Failover Triggers
The unit can fail if one of the following events occurs:
The unit has a hardware failure or a power failure.
The unit has a software failure.
Too many monitored interfaces fail.
The no failover active command is entered on the active unit or the failover active command is entered on the standby unit.
Failover Behavior
Failure Event
Policy
Active Action
Standby Action
Notes
Active unit failed (power or hardware)
Failover
n/a
Become active
Mark active as failed
No hello messages are received on any monitored interface or the failover link.
Formerly active unit recovers
No failover
Become standby
No action
None.
Standby unit failed (power or hardware)
No failover
Mark standby as failed
n/a
When the standby unit is marked as failed, then the active unit does not attempt to fail over, even if the interface failure threshold is surpassed.
Failover link failed during operation
No failover
Mark failover interface as failed
You should restore the failover link as soon as possible because the unit cannot fail over to the standby unit while the failover link is down.
Failover link failed at startup
No failover
Become active
If the failover link is down at startup, both units become active.
Stateful Failover link failed
No failover
No action
No action
State information becomes out of date, and sessions are terminated if a failover occurs.
Interface failure on active unit above threshold
Failover
Become active
None.
Interface failure on standby unit above threshold
No failover
No action
When the standby unit is marked as failed, then the active unit does not attempt to fail over even if the interface failure threshold is surpassed.
Now, following will explain the use of 'monitor-interface' command and its impact on physical and sub-interfaces:
If the physical interface is not monitored (using no monitor-interface), ASA won’t failover even if interface goes down (configured with nameif/IP).
Here are the recreate results:
Details of Recreate
E0/2 of ASA named as test with IP 2.2.2.1/30.
E0/2.100 in vlan 100 named sub100 with IP 100.100.100.1/30
E0/2.200 in vlan 200 named sub200 with IP 200.200.200.1/30
E0/2 of primary connects to f0/43 on switch
E0/2 of secondary connects to f0/44 on switch
ASA(config)# sh run int
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.10.10.13 255.255.255.0 standby 10.10.10.15
interface Ethernet0/1
nameif inside
security-level 100
ip address 20.20.20.13 255.255.255.0 standby 20.20.20.15
interface Ethernet0/2
nameif test
security-level 50
ip address 2.2.2.1 255.255.255.252 standby 2.2.2.2
interface Ethernet0/2.100
vlan 100
nameif sub100
security-level 0
ip address 100.100.100.1 255.255.255.252 standby 100.100.100.2
interface Ethernet0/2.200
vlan 200
nameif sub200
security-level 0
ip address 200.200.200.1 255.255.255.252 standby 200.200.200.2
interface Ethernet0/3
description LAN/STATE Failover Interface
Default: Interface e0/2 (physical) is monitored but sub100 and sub200 are not:
ASA(config)# sh run all monitor-interface
monitor-interface outside
monitor-interface inside
monitor-interface test
no monitor-interface sub100
no monitor-interface sub200
Failover is healthy:
ASA(config)# sh fail
Failover On
Failover unit Primary
Failover LAN Interface: Failover Ethernet0/3 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 3 of 110 maximum
Version: Ours 8.2(5), Mate 8.2(5)
Last Failover at: 08:11:54 EDT Mar 29 2013
                This host: Primary - Active
                                Active time: 3781 (sec)
                                slot 0: ASA5510 hw/sw rev (1.1/8.2(5)) status (Up Sys)
                                  Interface outside (10.10.10.13): Normal (Monitored)
                                  Interface inside (20.20.20.13): Normal (Monitored)
                                  Interface test (2.2.2.1): Normal (Monitored)
                                  Interface sub100 (100.100.100.1): Normal (Not-Monitored)
                                  Interface sub200 (200.200.200.1): Normal (Not-Monitored)
                                slot 1: ASA-SSM-10 hw/sw rev (1.0/7.0(8)E4) status (Up/Up)
                                  IPS, 7.0(8)E4, Up
                Other host: Secondary - Standby Ready
                                Active time: 0 (sec)
                                  Interface outside (10.10.10.15): Normal (Monitored)
                                  Interface inside (20.20.20.15): Normal (Monitored)
                                  Interface test (2.2.2.2): Normal (Monitored)
                                  Interface sub100 (100.100.100.2): Normal (Not-Monitored)
                                  Interface sub200 (200.200.200.2): Normal (Not-Monitored)
                                slot 1: ASA-SSM-10 hw/sw rev (1.0/7.1(6)E4) status (Up/Up)
                                  IPS, 7.1(6)E4, Up
Stateful Failover Logical Update Statistics
                Link : Failover Ethernet0/3 (up)
---Output Ommitted--
I shutdown f0/43 on switch:
interface f0/43
shut
Got kicked out as ASA failed over: Expected
ASA(config)# login as: cisco
cisco@20.20.20.13's password:
Type help or '?' for a list of available commands.
ASA> en
Password: *****
ASA# sh fail
Failover On
Failover unit Secondary
Interface Policy 1
Last Failover at: 22:56:29 EDT Mar 26 2013
                This host: Secondary - Active
                                Active time: 37 (sec)
                                  Interface test (2.2.2.1): Normal (Waiting)
                                  IPS, 7.1(6)E4, Up
                Other host: Primary - Failed
                                Active time: 3807 (sec)
                                  Interface outside (10.10.10.15): Normal (Waiting)
                                  Interface inside (20.20.20.15): Normal (Waiting)
                                  Interface test (2.2.2.2): No Link (Waiting)
                                  IPS, 7.0(8)E4, Up
Now, I disable monitoring on physical interface as follows:
ASA(config)# no monitor-interface test
I do no shut on f0/43 shut down f0/44 (to bring e0/2 on secondary-active down) on switch:
interface f0/43
no shut
interface f0/44
shut
Link goes down on Secondary-active but failover is *not* triggered: Expected
Failover On
Interface Policy 1
Monitored Interfaces 2 of 110 maximum
                                Active time: 115 (sec)
                                  Interface test (2.2.2.1): No Link (Not-Monitored)
                                  Interface sub100 (100.100.100.1): No Link (Not-Monitored)
                                  Interface sub200 (200.200.200.1): No Link (Not-Monitored)
                                  IPS, 7.1(6)E4, Up
                Other host: Primary - Standby Ready
                                  Interface test (2.2.2.2): Normal (Not-Monitored)
                                  IPS, 7.0(8)E4, Up
I enabled monitoring on sub100, keeping monitoring disabled on test (physical interface):
ASA(config)# monitor-interface sub100
ASA# sh run all monitor-interface
Now, I shut down f0/44 again to bring e0/2 link of secondary-active down and as expected failover is triggered:
ASA> en
Password: *****
ASA# sh fail
Failover On
Interface Policy 1
Last Failover at: 09:17:38 EDT Mar 29 2013
                                Active time: 3857 (sec)
                                  Interface sub100 (100.100.100.1): No Link (Waiting)
                                  IPS, 7.0(8)E4, Up
                                Active time: 137 (sec)
                                  Interface sub100 (100.100.100.2): Unknown (Waiting)
                                  IPS, 7.1(6)E4, Up
Thus, if interface is not monitored using 'no monitor-interface' command. ASA won't failover even if physical interface goes down.
For failover to occur:
- Physical interface should be monoitored.
- If not, one of the logical interface configured using this physical interface should be monitored.
Reference
Failover Triggers
Sourav Kakkar
DM27
Hey Guys,
I have a query. Suppose if failover cable is broken and there is no communication between Active and Standby, so in this case Active will remain Active and Standby will also become active (As no active unit found in the failover group) , so both units are now active. Do you have idea how to resolve this situation? (Restore failover interface is one option, I am looking for any other option).
Early response is highly appreciated.
alexk1041
I actually have the same question, even with a switch in between. Whats best practice when it comes to monitoring the failover interface? Because if the whole switch in between dies, then both members will go to standby (split brain scenario). I assume if both firewalls are directly connected, if you dont monitor (to avoid split brain even for an interface going down), you need to have at least some kind of syslog/snmp alert for finding out the interface going down?
