brquinn
Introduction
This is a basic configuration example of Transparent Mode configuration on an ASA 5505. This configuration is only valid in version 8.4 and later since it utilizes bridge-groups.
Configuration Example
interface Ethernet0/0
  switchport access vlan 10
interface Ethernet0/1
  switchport access vlan 20
interface Vlan10
  nameif outside
  bridge-group 1
  security-level 0
interface Vlan20
  nameif inside
  bridge-group 1
  security-level 100
interface BVI1
  ip address 10.10.10.10 255.255.255.0
route outside 0.0.0.0 0.0.0.0 10.10.10.1
route inside 192.168.1.0 255.255.255.0 10.10.10.254
http 0.0.0.0 0.0.0.0 inside
Notes
In order to enable ASDM access, the http command must be configured for a named interface. In the example above, access has been enabled for all IP addresses on the inside interface.
Routing is important in transparent mode to ensure inspection functionality. Many of the ASA's inspections rely on the routing table. In this example, there is a default route configured outside and a route to the 192.168.1.0/24 subnet configured inside.
Thanks Bro ,
