One common task in ASA/FTD troubleshooting is to find the top hosts, ports, hosts pair, socket-host pair etc using the "show conn" output file. This document is using "show conn" output, "show conn long" and "show long detail" has multiline outputs and different processing is needed. I will explain the logic, goal is readers can use this as a framework and do similar tasks, lot of file processing tasks can be mapped to this type of programs.
show conn output will look like following:
TCP outside 10.48.26.239:8305 inside 192.168.1.96:41815, idle 0:00:01, bytes 32564248, flags UxIO
TCP outside 3.65.105.133:443 inside 192.168.1.222:50034, idle 0:00:02, bytes 6734661, flags UxIO
TCP outside 10.48.26.239:8305 inside 192.168.1.96:47891, idle 0:00:08, bytes 13081667, flags UxIO
TCP outside 146.112.255.69:443 inside 192.168.1.222:50880, idle 0:00:55, bytes 11005, flags UxIO
UDP outside 172.31.74.20:123 inside 192.168.1.223:123, idle 0:00:08, bytes 48, flags -
TCP outside 10.0.1.10:389 inside 192.168.1.222:44914, idle 0:00:17, bytes 0, flags sxaA
UDP outside 10.0.1.135:514 inside 192.168.1.222:56219, idle 0:00:00, bytes 1141743837, flags -
TCP outside 10.0.1.11:389 inside 192.168.1.222:48668, idle 0:00:07, bytes 0, flags sxaA
TCP outside 10.0.1.202:8910 inside 192.168.1.222:49486, idle 0:00:21, bytes 0, flags sxaA
TCP outside 10.48.26.239:8305 inside 192.168.1.94:41823, idle 0:00:04, bytes 10865453, flags UxIO
TCP outside 10.48.26.239:8305 inside 192.168.1.94:57773, idle 0:00:01, bytes 9255547, flags UxIO
This kind of task in general can be mapped to unique string count issue. I will be using awk and other common linux tools to do this task.
Example 1
In this we will calculate top hosts from file. First is to prepare the input so each data that we are interested to process is a unique column i.e each IP address is on unique line in output.
Code i am using for this task is following:
base) RAJATSH-M-V7QW:Desktop rajatsh$ cat prep.awk
#Next line is setting the output field separator to new line
BEGIN{OFS = "\n"}
#Next line is removing the commas from each line
gsub(",", "", $0)
#Next line is checking if the first column value is TCP,UDP,ICMP,GRE as for portless connections such as EIGRP etc column will be different.
if($1 == "TCP" || $1 == "UDP" || $1 == "ICMP" || $1 == "GRE")
#Next two line removes the ":" between the IP address and ports.
sub(":", " ", $0)
sub(":", " ", $0)
print $3,$6
else
{ #Next line is printing the IP address in connections without ports such as EIGRP
print $3,$5
END{}
If it take output above and pipe to this awk program, result is something like below:
(base) RAJATSH-M-V7QW:Desktop rajatsh$ echo "TCP outside 10.48.26.239:8305 inside 192.168.1.96:41815, idle 0:00:01, bytes 32564248, flags UxIO
TCP outside 10.48.26.239:8305 inside 192.168.1.94:57773, idle 0:00:01, bytes 9255547, flags UxIO " | awk -f prep.awk
10.48.26.239
192.168.1.96
3.65.105.133
192.168.1.222
10.48.26.239
192.168.1.96
146.112.255.69
192.168.1.222
172.31.74.20
192.168.1.223
10.0.1.10
192.168.1.222
10.0.1.135
192.168.1.222
10.0.1.11
192.168.1.222
10.0.1.202
192.168.1.222
10.48.26.239
192.168.1.94
10.48.26.239
192.168.1.94
As you can see above each IP address in the connection is on new line.
Next task would be to calculate the count of each IP address, following code is used for this task, this is a hashamp/associative array which will have each IP address as key and count as value and it will print key-value pair two columns in each line.
(base) RAJATSH-M-V7QW:Desktop rajatsh$ cat hashmap.awk
BEGIN{}
{a[$1]++}
END{for(x in a)print a[x]" "x}
Then we can pipe the output of the first part to this code
TCP outside 10.48.26.239:8305 inside 192.168.1.94:57773, idle 0:00:01, bytes 9255547, flags UxIO " | awk -f prep.awk | awk -f hashmap.awk
1 10.0.1.202
1 146.112.255.69
6 192.168.1.222
2 192.168.1.94
1 192.168.1.223
2 192.168.1.96
1 172.31.74.20
1 10.0.1.135
1 3.65.105.133
4 10.48.26.239
1 10.0.1.10
1 10.0.1.11
As seen above first column is count and second column is IP address value.
Then you can pipe this to sort to sort by count value.
TCP outside 10.48.26.239:8305 inside 192.168.1.94:57773, idle 0:00:01, bytes 9255547, flags UxIO " | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1
6 192.168.1.222
4 10.48.26.239
2 192.168.1.96
2 192.168.1.94
1 3.65.105.133
1 192.168.1.223
1 172.31.74.20
1 146.112.255.69
1 10.0.1.202
1 10.0.1.135
1 10.0.1.11
1 10.0.1.10
To run this on a show conn file, here name if file is "connu" to show top 20 hosts, syntax would be following
(base) RAJATSH-M-V7QW:Desktop rajatsh$ cat connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20
I am masking IP address to x.x.x.x as sample file contains some Public address.
56638 x.x.x.x
14716 x.x.x.x
13448 x.x.x.x
13118 x.x.x.x
12619 x.x.x.x
12615 x.x.x.x
12218 x.x.x.x
11982 x.x.x.x
11367 x.x.x.x
11214 x.x.x.x
11159 x.x.x.x
10862 x.x.x.x
10828 x.x.x.x
10767 x.x.x.x
10741 x.x.x.x
10706 x.x.x.x
10633 x.x.x.x
10607 x.x.x.x
10512 x.x.x.x
10510 x.x.x.x
You can use GREP to filter the connections that you need to process.
e.g
for TCP
grep TCP connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20
for UDP
grep UDP connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20
for ICMP
grep ICMP connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20
for EIGRP
grep EIGRP connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20
for GRE
grep GRE connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20
you can also use regex to filter what you need for particular case, e.g you only need to check 443 connections
grep ":443 " connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20
Also for context connu file contains around 600k connections
(base) RAJATSH-M-V7QW:Desktop rajatsh$ wc -l connu
628849 connu
(base) RAJATSH-M-V7QW:Desktop rajatsh$ ls -lh connu
-rw-r--r-- 1 rajatsh staff 65M Oct 20 12:35 connu
Also it is quite scalable for CPU/Mem usage, more importantly memory usage (maximum resident set size) is constant around 1 Mbytes irrespective of file size.
(base) RAJATSH-M-V7QW:Desktop rajatsh$ date; /usr/bin/time -l -h cat connu | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20; date
Sat Nov 2 20:51:28 CET 2024
4.15s real 0.00s user 0.04s sys
1327104 maximum resident set size
0 average shared memory size
0 average unshared data size
0 average unshared stack size
194 page reclaims
2 page faults
0 swaps
0 block input operations
0 block output operations
0 messages sent
0 messages received
0 signals received
4160 voluntary context switches
135 involuntary context switches
189503143 instructions retired
138920617 cycles elapsed
1164224 peak memory footprint
56638 x.x.x.x
14716 x.x.x.x
13448 x.x.x.x
13118 x.x.x.x
12619 x.x.x.x
12615 x.x.x.x
12218 x.x.x.x
11982 x.x.x.x
11367 x.x.x.x
11214 x.x.x.x
11159 x.x.x.x
10862 x.x.x.x
10828 x.x.x.x
10767 x.x.x.x
10741 x.x.x.x
10706 x.x.x.x
10633 x.x.x.x
10607 x.x.x.x
10512 x.x.x.x
10510 x.x.x.x
Sat Nov 2 20:51:33 CET 2024
if it run it on large file, 4Gbytes file, around 39 million connections
(base) RAJATSH-M-V7QW:Desktop rajatsh$ wc -l conn2
39398150 conn2
(base) RAJATSH-M-V7QW:Desktop rajatsh$ ls -lh conn2
-rw-r--r--@ 1 rajatsh staff 4.0G Sep 10 23:37 conn2
(base) RAJATSH-M-V7QW:Desktop rajatsh$ date; /usr/bin/time -l -h cat conn2 | awk -f prep.awk | awk -f hashmap.awk | sort -nrk1 | head -20; date
Sat Nov 2 20:55:02 CET 2024
4m11.51s real 0.10s user 2.00s sys
206 page reclaims
4 page faults
0 swaps
0 messages sent
0 messages received
0 signals received
259634 voluntary context switches
7516 involuntary context switches
7083887647 instructions retired
6225113100 cycles elapsed
3568194 x.x.x.x
927108 x.x.x.x
847224 x.x.x.x
826434 x.x.x.x
794745 x.x.x.x
788449 x.x.x.x
763303 x.x.x.x
748488 x.x.x.x
710190 x.x.x.x
700556 x.x.x.x
697162 x.x.x.x
682164 x.x.x.x
678562 x.x.x.x
672494 x.x.x.x
670972 x.x.x.x
668771 x.x.x.x
664328 x.x.x.x
662636 x.x.x.x
656616 x.x.x.x
656597 x.x.x.x
Sat Nov 2 20:59:14 CET 2024
Example 2
In this we will calculate top ports from file. First is to prepare the input so each data that we are interested to process is a unique column i.e each port is on unique line in output.
BEGIN{OFS = "\n"}
gsub(",", "", $0)
#Next line is checking if the first column value is TCP,UDP as this would be most common use case
if($1 == "TCP" || $1 == "UDP")
sub(":", " ", $0)
sub(":", " ", $0)
print $4,$7
END{}
we will get something like this
TCP outside 10.48.26.239:8305 inside 192.168.1.94:57773, idle 0:00:01, bytes 9255547, flags UxIO " | awk -f portprep.awk
8305
41815
443
50034
8305
47891
443
50880
123
123
389
44914
514
56219
389
48668
8910
49486
8305
41823
8305
57773
Next step would be same as example 1
TCP outside 10.48.26.239:8305 inside 192.168.1.94:57773, idle 0:00:01, bytes 9255547, flags UxIO " | awk -f portprep.awk | awk -f hashmap.awk | sort -rnk1
4 8305
2 443
2 389
2 123
1 8910
1 57773
1 56219
1 514
1 50880
1 50034
1 49486
1 48668
1 47891
1 44914
1 41823
1 41815
some tests:
628849 connu
(base) RAJATSH-M-V7QW:Desktop rajatsh$ date; /usr/bin/time -l -h cat connu | awk -f portprep.awk | awk -f hashmap.awk | sort -nrk1 | head -25; date
Sat Nov 2 21:21:16 CET 2024
3.93s real 0.00s user 0.02s sys
193 page reclaims
2 page faults
0 swaps
0 messages sent
0 messages received
0 signals received
4156 voluntary context switches
104439337 instructions retired
85841344 cycles elapsed
1147776 peak memory footprint
580331 443
8167 80
7426 3478
3856 8443
3333 25
2751 8089
2649 3061
2309 3060
2033 5223
1771 3481
1760 3480
1392 5061
1279 36400
898 46447
848 3479
602 5222
595 36010
588 40013
471 22
464 37777
408 53
390 40014
376 8282
370 9092
347 3065
Sat Nov 2 21:21:20 CET 2024
(base) RAJATSH-M-V7QW:Desktop rajatsh$ date; /usr/bin/time -l -h cat conn2 | awk -f portprep.awk | awk -f hashmap.awk | sort -nrk1 | head -25; date
Sat Nov 2 21:22:00 CET 2024
4m10.24s real 0.09s user 1.90s sys
212 page reclaims
5 page faults
0 swaps
0 messages sent
0 messages received
0 signals received
260016 voluntary context switches
5644 involuntary context switches
7048339914 instructions retired
5975607020 cycles elapsed
36355520 443
510896 80
463925 3478
242921 8443
208249 25
173313 8089
166885 3061
145465 3060
127027 5223
110627 3481
109995 3480
87690 5061
80575 36400
56572 46447
53004 3479
37924 5222
37484 36010
37042 40013
29634 22
28983 37777
25655 53
24565 40014
23686 8282
23308 9092
21857 3065
Sat Nov 2 21:26:10 CET 2024
39398150 conn2
Example 3
In this we will calculate top pair of IP address.
prep code
BEGIN{OFS = "\n"}
gsub(",", "", $0)
sub(":", " ", $0)
sub(":", " ", $0)
print $3"<->"$6
else
{ #Next line is printing the IP address pair in connections without ports such as EIGRP
print $3"<->"$5
END{}
result
TCP outside 10.48.26.239:8305 inside 192.168.1.94:57773, idle 0:00:01, bytes 9255547, flags UxIO " | awk -f ippairprep.awk | awk -f hashmap.awk | sort -rnk1
2 10.48.26.239<->192.168.1.96
2 10.48.26.239<->192.168.1.94
1 3.65.105.133<->192.168.1.222
1 172.31.74.20<->192.168.1.223
1 146.112.255.69<->192.168.1.222
1 10.0.1.202<->192.168.1.222
1 10.0.1.135<->192.168.1.222
1 10.0.1.11<->192.168.1.222
1 10.0.1.10<->192.168.1.222
(base) RAJATSH-M-V7QW:Desktop rajatsh$ date; /usr/bin/time -l -h cat connu | awk -f ippairprep.awk | awk -f hashmap.awk | sort -nrk1 | head -25; date
Sat Nov 2 21:32:41 CET 2024
4.18s real 0.00s user 0.04s sys
196 page reclaims
1 page faults
0 swaps
0 messages sent
0 messages received
0 signals received
4179 voluntary context switches
85 involuntary context switches
188334292 instructions retired
126029031 cycles elapsed
788 x.x.x.x<->x.x.x.x
710 x.x.x.x<->x.x.x.x
697 x.x.x.x<->x.x.x.x
666 x.x.x.x<->x.x.x.x
657 x.x.x.x<->x.x.x.x
637 x.x.x.x<->x.x.x.x
634 x.x.x.x<->x.x.x.x
625 x.x.x.x<->x.x.x.x
589 x.x.x.x<->x.x.x.x
585 x.x.x.x<->x.x.x.x
582 x.x.x.x<->x.x.x.x
571 x.x.x.x<->x.x.x.x
553 x.x.x.x<->x.x.x.x
548 x.x.x.x<->x.x.x.x
547 x.x.x.x<->x.x.x.x
538 x.x.x.x<->x.x.x.x
534 x.x.x.x<->x.x.x.x
522 x.x.x.x<->x.x.x.x
519 x.x.x.x<->x.x.x.x
516 x.x.x.x<->x.x.x.x
511 x.x.x.x<->x.x.x.x
508 x.x.x.x<->x.x.x.x
502 x.x.x.x<->x.x.x.x
501 x.x.x.x<->x.x.x.x
Sat Nov 2 21:32:46 CET 2024
Example 4
To count IP address and port counts
BEGIN{OFS = "\n"}
gsub(",", "", $0)
#Next line is checking if the first column value is TCP,UDP most common case
sub(":", " ", $0)
sub(":", " ", $0)
print $3":"$4
END{}
(base) RAJATSH-M-V7QW:Desktop rajatsh$ date; /usr/bin/time -l -h cat connu | awk -f socket.awk | awk -f hashmap.awk | sort -nrk1 | head -25; date
Sat Nov 2 21:40:57 CET 2024
194 page reclaims
4 page faults
0 swaps
0 messages sent
0 messages received
0 signals received
4182 voluntary context switches
137 involuntary context switches
190422211 instructions retired
136870629 cycles elapsed
12218 x.x.x.x:443
9691 x.x.x.x:443
9112 x.x.x.x:443
8459 x.x.x.x:443
8249 x.x.x.x:443
8226 x.x.x.x:443
8104 x.x.x.x:443
8095 x.x.x.x:443
7976 x.x.x.x:443
7890 x.x.x.x:443
7875 x.x.x.x:443
6896 x.x.x.x:443
6439 x.x.x.x:443
6397 x.x.x.x:443
6284 x.x.x.x:443
5952 x.x.x.x:443
5090 x.x.x.x:443
4238 x.x.x.x:443
4057 x.x.x.x:443
3884 x.x.x.x:443
3855 x.x.x.x:443
3725 x.x.x.x:443
3500 x.x.x.x:443
3398 x.x.x.x:443
3162 x.x.x.x:443
Sat Nov 2 21:41:02 CET 2024
In summary whatever is your particular use case, prep code can be modified easily.
e.g You are interested in only checking U-Turn connections where both interface are same and count the top hosts
BEGIN{OFS = "\n"}
gsub(",", "", $0)
sub(":", " ", $0)
sub(":", " ", $0)
if($2==$5)
print $3;
print $6;
END{}
"date" and "/usr/bin/time -l -h" commands are optional i am using to check CPU and memory.
Also most of the awk syntax is optional, examples are using descriptive for readability, also two or more codes can be combined etc.
e,g with a script like the following you can combine different parts together, it will write results to stdout, this file is test.text which is attached to this document.
(base) RAJATSH-M-V7QW:awk_program rajatsh$ cat test.sh
#!/bin/bash
echo "Enter the show conn file name in current directory or full path name"
read filename
echo "Enter the number of top hosts, ports, sockets, IP pair required"
read nums
echo "Top IP ADDRESSs" > ip.temp
echo "Top PORTS" > port.temp
echo "Top SOCKETS" > socket.temp
echo "Top PAIR of ADDRESS" > pair.temp
cat $filename | awk 'BEGIN{OFS = "\n"}
gsub(",", "", $0)
sub(":", " ", $0)
sub(":", " ", $0)
print $3,$6
else
print $3,$5
END{}' | awk 'BEGIN{}
{a[$1]++}
' | sort -rnk1 | head -$nums >> ip.temp &
gsub(",", "", $0)
sub(":", " ", $0)
sub(":", " ", $0)
print $4,$7
END{} ' | awk 'BEGIN{}
{a[$1]++}
' | sort -rnk1 | head -$nums >> port.temp &
gsub(",", "", $0)
sub(":", " ", $0)
sub(":", " ", $0)
print $3":"$4
END{}
' | awk 'BEGIN{}
{a[$1]++}
' | sort -nrk1 | head -$nums >> socket.temp &
gsub(",", "", $0)
sub(":", " ", $0)
sub(":", " ", $0)
print $3"<->"$6
else
print $3"<->"$5
{a[$1]++}
' | sort -nrk1 | head -$nums >> pair.temp &
wait
cat ip.temp port.temp socket.temp pair.temp
rm ip.temp port.temp socket.temp pair.temp
output
to run
chmod u+x test.sh
(base) RAJATSH-M-V7QW:awk_program rajatsh$ ./test.sh
conn
20
Top IP ADDRESSs
453104 x.x.x.x
117728 x.x.x.x
107584 x.x.x.x
104944 x.x.x.x
100920 x.x.x.x
95233 x.x.x.x
92102 x.x.x.x
90200 x.x.x.x
86624 x.x.x.x
85743 x.x.x.x
84430 x.x.x.x
84119 x.x.x.x
81808 x.x.x.x
81012 x.x.x.x
80879 x.x.x.x
80633 x.x.x.x
80155 x.x.x.x
79942 x.x.x.x
79176 x.x.x.x
79111 x.x.x.x
Top PORTS
4461480 443
62135 80
55926 3478
30841 8443
25122 25
22008 8089
21190 3061
18470 3060
15323 5223
13332 3481
13292 3480
11131 5061
10231 36400
7182 46447
6416 3479
4814 5222
4759 36010
4702 40013
3735 22
3488 37777
Top SOCKETS
92102 x.x.x.x:443
73109 x.x.x.x:443
68775 x.x.x.x:443
63711 x.x.x.x:443
62106 x.x.x.x:443
62027 x.x.x.x:443
61035 x.x.x.x:443
60818 x.x.x.x:443
60068 x.x.x.x:443
59513 x.x.x.x:443
59467 x.x.x.x:443
51850 x.x.x.x:443
48497 x.x.x.x:443
48272 x.x.x.x:443
47368 x.x.x.x:443
44776 x.x.x.x:443
38342 x.x.x.x:443
31863 x.x.x.x:443
30564 x.x.x.x:443
29220 x.x.x.x:443
Top PAIR of ADDRESS
5921 x.x.x.x<->x.x.x.x
5349 x.x.x.x<->x.x.x.x
5272 x.x.x.x<->x.x.x.x
5256 x.x.x.x<->x.x.x.x
5012 x.x.x.x<->x.x.x.x
5000 x.x.x.x<->x.x.x.x
4791 x.x.x.x<->x.x.x.x
4779 x.x.x.x<->x.x.x.x
4717 x.x.x.x<->x.x.x.x
4458 x.x.x.x<->x.x.x.x
4411 x.x.x.x<->x.x.x.x
4405 x.x.x.x<->x.x.x.x
4291 x.x.x.x<->x.x.x.x
4152 x.x.x.x<->x.x.x.x
4128 x.x.x.x<->x.x.x.x
4123 x.x.x.x<->x.x.x.x
4108 x.x.x.x<->x.x.x.x
4043 x.x.x.x<->x.x.x.x
4030 x.x.x.x<->x.x.x.x
3926 x.x.x.x<->x.x.x.x
