06-10-2009 12:59 AM - edited 03-08-2019 05:58 PM
The Cisco adaptive security appliance phone proxy is the replacement product for the Cisco Unified Phone Proxy. This page is intended to assist with troubleshooting problems with Phone Proxy feature on the firewall
The Cisco ASA phone proxy feature allows for phones to establish secured communication channels directly with the ASA; These secure communications terminate directly onto the firewall, and the firewall "proxies" the voice communication between the phone and the Call Manager.
This feature allows for secure voice communication for phones deployed in the field without requiring a separate device to encrypt the traffic to the call manager.
ASA 8.0 Configuration guide - Phone Proxy feature
ASA Phone Proxy sample configuration in 8.0
Official Phone Proxy troubleshooting Documentation
To determine the number of remote phones can connect to the phone-proxy, use the "show version" command. Note the line that reads "UC Proxy Sessions":
PhoneProxyASA#show version
Cisco Adaptive Security Appliance Software Version 8.0(4)
Device Manager Version 5.2(4)
UC Proxy Sessions : 2
This is the total number of TLS proxy sessions that can be simultaneously established. For instance, if there is only one CUCM in the cluster, then the total number of phones that can be registered through the phone-proxy is 2. If there is a backup and a primary CUCM in the cluster, then only 1 phone can be registered since the phone would also initiate a TLS connection to the backup CUCM and consume a TLS connection. For more information on licensing, please seehttp://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/unified_comm.html#wp1139894.
To see what phones are connected use the command "show tls-proxy session". If the license becomes exceeded, you will receive the syslog below:
%ASA-4-446002: Denied TLS Proxy session from outside:10.10.10.2/49572 to
inside:192.168.1.2/2000, licensed UC Proxy session limit of 20 exceeded
Please note that if users disconnect and then re-connect quickly from a different ip address, the firewall might be affected by the bug CSCsu11361.
This is a step by step walkthrough of what occurs when the phone connects to the phone-proxy.
If the Cisco CA manufacturing certificates have not been installed on the ASA, and the phone connecting in is using a MIC (and not a LSC cert), then you'll see the following syslogs:
Aug 29 2008 09:03:30: %ASA-6-725001: Starting SSL handshake with client
outside:192.168.254.254/50272 for TLSv1 session.
Aug 29 2008 09:03:30: %ASA-7-725010: Device supports the following 4 cipher(s).
Aug 29 2008 09:03:30: %ASA-7-725011: Cipher[1] : RC4-SHA
Aug 29 2008 09:03:30: %ASA-7-725011: Cipher[2] : AES128-SHA
Aug 29 2008 09:03:30: %ASA-7-725011: Cipher[3] : AES256-SHA
Aug 29 2008 09:03:30: %ASA-7-725011: Cipher[4] : DES-CBC3-SHA
Aug 29 2008 09:03:30: %ASA-7-725008: SSL client outside:192.168.254.254/50272 proposes the
following 2 cipher(s).
Aug 29 2008 09:03:30: %ASA-7-725011: Cipher[1] : AES256-SHA
Aug 29 2008 09:03:30: %ASA-7-725012: Device chooses cipher : AES128-SHA for the SSL
session with client outside:192.168.254.254/50272
Aug 29 2008 09:03:32: %ASA-7-725014: SSL lib error. Function: SSL3_READ_BYTES Reason: ssl
handshake failure
Aug 29 2008 09:03:32: %ASA-7-717025: Validating certificate chain containing 1
certificate(s).
Aug 29 2008 09:03:32: %ASA-7-717029: Identified client certificate within certificate
chain. serial number: 19567F78000000281D45, subject name:
cn=CP-7942G-SEP001DA23EA450,ou=EVVBU,o=Cisco Systems Inc..
Aug 29 2008 09:03:32: %ASA-3-717009: Certificate validation failed. No suitable
trustpoints found to validate certificate serial number: 19567F78000000281D45, subject
name: cn=CP-7942G-SEP001DA23EA450,ou=EVVBU,o=Cisco Systems Inc..
Aug 29 2008 09:03:32: %ASA-3-717027: Certificate chain failed validation. No suitable
trustpoint was found to validate chain.
Aug 29 2008 09:03:32: %ASA-7-725014: SSL lib error. Function: SSL3_GET_CLIENT_CERTIFICATE
Reason: no certificate returned
Aug 29 2008 09:03:32: %ASA-6-725006: Device failed SSL handshake with outside
client:192.168.254.254/50272
Aug 29 2008 09:03:32: %ASA-6-302014: Teardown TCP connection 797 for
outside:192.168.254.254/50272 to inside:10.55.151.140/2000 duration 0:00:01 bytes 623 Flow
closed by inspection
Symptom: The phone will download the TFTP configuration but will then fail to connect to the firewall on port the secure port 2443. Instead it connects on port non-secure port 2000 (the non-secure port). If the phone has no certificate installed, then it will ignore the config file entry that says to use encryption and will connect as if it were non-secure. If the outside ACL allows inbound connections on port 2000, the phone might register with the Call Manager, but in non-secure mode. If inbound port 2000 is blocked, the phone will fail to register and simply read "Opening x.x.x.x". The status messages on the phone will just show that the config file was downloaded, and that's it. The tftp debugs will show the CTL and configuration file are downloaded successfully
PP: 172.18.254.73/51783 requesting CTLSEP0007EBF0EE54.tlv
PP: Created entry for secure device outside:172.18.254.73, MAC 0007.ebf0.ee54, current count 1, list count 3
PP: opened 0x32b3cfea
PP: Data Block 1 forwarded from 14.36.107.90/46309 to 172.18.254.73/51783 ingress ifc outside
PP: Received ACK Block 1 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.73/51783
PP: Received ACK Block 2 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 3 forwarded to 172.18.254.73/51783
PP: Received ACK Block 3 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 4 forwarded to 172.18.254.73/51783
PP: Received ACK Block 4 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 5 forwarded to 172.18.254.73/51783
PP: Received ACK Block 5 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 6 forwarded to 172.18.254.73/51783
PP: Received ACK Block 6 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 7 forwarded to 172.18.254.73/51783
PP: Received ACK Block 7 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 8 forwarded to 172.18.254.73/51783
PP: Received ACK Block 8 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: Data Block 9 forwarded to 172.18.254.73/51783
PP: Received ACK Block 9 from outside:172.18.254.73/51783 to inside:172.18.124.230
PP: TFTP session complete, all data sent
PP: 172.18.254.73/51784 requesting SEP0007EBF0EE54.cnf.xml.sgn
PP: opened 0x32b48326
PP: Received Data Block 1 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 1
PP: Acked Block #1 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Received Data Block 2 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 2
PP: Acked Block #2 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Received Data Block 3 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 3
PP: Acked Block #3 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Received Data Block 4 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 4
PP: Acked Block #4 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Received Data Block 5 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 5
PP: Acked Block #5 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Received Data Block 6 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 6
PP: Acked Block #6 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Received Data Block 7 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 7
PP: Acked Block #7 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Received Data Block 8 from inside:172.18.124.230/32815 to outside:172.18.254.73/51784
Received Block 8
PP: Acked Block #8 from 172.18.124.241/33423 to 172.18.124.230/32815
PP: Added ACL for 172.18.254.73 to outside:14.36.107.90/2443
PP: Applied Application Redirect rule for 172.18.254.73/2000 to 14.36.107.90, secure port 2443
PP: Added ACL for 172.18.254.73 to outside:14.36.107.90/59699
PP: Applied Application Redirect rule for 172.18.254.73/3804 to 14.36.107.90, secure port 59699
PP: Modifying to encrypted mode.
PP: Modifying to TLS as the transport layer protocol.
PP: Data Block 1 forwarded from 14.36.107.90/9694 to 172.18.254.73/51784
PP: Received ACK Block 1 from outside:172.18.254.73/51784 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.73/51784
PP: Received ACK Block 2 from outside:172.18.254.73/51784 to inside:172.18.124.230
PP: Data Block 3 forwarded to 172.18.254.73/51784
PP: Received ACK Block 3 from outside:172.18.254.73/51784 to inside:172.18.124.230
PP: Data Block 4 forwarded to 172.18.254.73/51784
PP: Received ACK Block 4 from outside:172.18.254.73/51784 to inside:172.18.124.230
PP: Data Block 5 forwarded to 172.18.254.73/51784
PP: Received ACK Block 5 from outside:172.18.254.73/51784 to inside:172.18.124.230
PP: Data Block 6 forwarded to 172.18.254.73/51784
PP: Received ACK Block 6 from outside:172.18.254.73/51784 to inside:172.18.124.230
PP: Data Block 7 forwarded to 172.18.254.73/51784
PP: Received ACK Block 7 from outside:172.18.254.73/51784 to inside:172.18.124.230
PP: Data Block 8 forwarded to 172.18.254.73/51784
PP: Received ACK Block 8 from outside:172.18.254.73/51784 to inside:172.18.124.230
The syslogs simply show the tftp connections, and then the subsequent skinny connection on port 2000.
Sep 19 2008 15:19:03: %ASA-7-609001: Built local-host outside:172.18.254.73
Sep 19 2008 15:19:03: %ASA-6-305011: Built dynamic UDP translation from
outside:172.18.254.73/51783 to inside:172.18.124.241/41910
Sep 19 2008 15:19:03: %ASA-6-302015: Built inbound UDP connection 25958 for
outside:172.18.254.73/51783 (172.18.124.241/41910) to inside:172.18.124.230/69 (14.36.107.90/69)
inside:172.18.124.230/39638 to outside:14.36.107.90/46309
Sep 19 2008 15:19:03: %ASA-6-302015: Built inbound UDP connection 25959 for
outside:172.18.254.73/51783 (172.18.124.241/41910) to inside:172.18.124.230/39638 (14.36.107.90/46309)
Sep 19 2008 15:19:04: %ASA-6-305012: Teardown dynamic UDP translation from
inside:172.18.124.230/32813 to outside:14.36.107.90/62674 duration 0:02:30
Sep 19 2008 15:19:05: %ASA-6-305011: Built dynamic UDP translation from
outside:172.18.254.73/51784 to inside:172.18.124.241/33423
Sep 19 2008 15:19:05: %ASA-6-302015: Built inbound UDP connection 25960 for
outside:172.18.254.73/51784 (172.18.124.241/33423) to inside:172.18.124.230/69 (14.36.107.90/69)
Sep 19 2008 15:19:05: %ASA-6-302015: Built inbound UDP connection 25961 for
outside:172.18.254.73/51784 (172.18.124.241/33423) to inside:172.18.124.230/32815 (14.36.107.90/9694)
Sep 19 2008 15:19:05: %ASA-6-305011: Built dynamic TCP translation from
inside:172.18.124.230/3804 to outside:14.36.107.90/59699
Sep 19 2008 15:19:06: %ASA-2-106001: Inbound TCP connection denied from
172.18.254.73/51989 to 14.36.107.90/2000 flags SYN on interface outside
Sep 19 2008 15:19:07: %ASA-2-106001: Inbound TCP connection denied from
The traffic from the Call Manager back to the phone must traverse the ASA; if it does not, the registration process will fail due to the asymmetric routing.
In this situation, the CTL file will be downloaded by the phone just fine, since it is receiving this directly from the ASA (and the Call Manager is not involved yet). Once the phone has the CTL file, it will send a TFTP request to the Call Manager; this tftp request packet will be sourced from the phone's real external IP. The Call Manager will respond by sending the requested tftp data destined back to the phone's real ip address. The network must route the return packets from the Call Manager back to the phones through the firewall. If the packets do not traverse the ASA, when they are received at the phone they will be dropped. Depending on where the ASA is placed on the network, fixing this routing problem could require some additional (possibly major) routing changes. One workaround is to perform inbound NAT/PAT on all the phone traffic as it enters the network, but this might cause other problems (especially if nat-control is enabled. If nat-control is enabled and any outside NAT/PAT is configured, then outside NAT will have to be configured for all inbound traffic).
Here is a picture showing the problem:
Here is an example of the output of 'debug phone-proxy tftp' when a remote phone connecting to the phone proxy on the ASA. The network is not routing the traffic from the Call Manager to the phone through the ASA, and thus the TFTP transfer of the configuration file fails. The phone will retry the download over and over.
PP: 172.18.254.73/52361 requesting CTLSEP0007EBF0EE54.tlv
PP: opened 0x116804ea
PP: Data Block 1 forwarded from 14.36.107.90/8554 to 172.18.254.73/52361 ingress ifc outside
PP: Received ACK Block 1 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.73/52361
PP: Received ACK Block 2 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 3 forwarded to 172.18.254.73/52361
PP: Received ACK Block 3 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 4 forwarded to 172.18.254.73/52361
PP: Received ACK Block 4 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 5 forwarded to 172.18.254.73/52361
PP: Received ACK Block 5 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 6 forwarded to 172.18.254.73/52361
PP: Received ACK Block 6 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 7 forwarded to 172.18.254.73/52361
PP: Received ACK Block 7 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 8 forwarded to 172.18.254.73/52361
PP: Received ACK Block 8 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: Data Block 9 forwarded to 172.18.254.73/52361
PP: Received ACK Block 9 from outside:172.18.254.73/52361 to inside:172.18.124.230
PP: 172.18.254.73/52362 requesting SEP0007EBF0EE54.cnf.xml.sgn
PP: opened 0x116974f6
PP: 172.18.254.73/52363 requesting SEP0007EBF0EE54.cnf.xml.sgn
PP: opened 0x116a21e2
PP: 172.18.254.73/52364 requesting SEP0007EBF0EE54.cnf.xml.sgn
PP: opened 0x116b06ae
The phone will continue to request the config file, but will never be successful. Adding outside PAT for this remote phone will mitigate the problem (in this case I've performed PAT on all outside traffic going inbound through the firewall):
PhoneProxyASA(config)# nat (outside) 55 0 0 outside
PhoneProxyASA(config)# global (inside) 55 interface
or
Here is a sample which does PAT outside for only traffic destined to the call manager on the inside.
PhoneProxyASA(config)#object-group service CUCM-PROXY-PORTS
PhoneProxyASA(config-service)#service-object udp eq tftp
service-object udp range 1024 65535
service-object tcp eq 2443
service-object tcp eq 5061
service-object tcp eq 3804
PhoneProxyASA(config)#access-list cucm-traffic extended permit object-group
CUCM-PROXY-PORTS any host 172.18.124.230
PhoneProxyASA(config)#nat (outside) 55 access-list cucm-traffic outside
PhoneProxyASA(config)#global (inside) 55 interface
Where 172.18.124.230 is the translated address of the call manager on the inside.
or
PhoneProxyASA(config)# nat (outside) 55 172.18.254.73 255.255.255.255 outside
where 172.18.254.73 is the ip address of the phone on the outside.
or
Under 8.3, NAT configuration format has changed. Twice NAT is introduced for policy based NAT. Below is a working Twice NAT that dynamically PAT any traffic destined to the CUCM public ip address translating the source to the ASA's inside ip address and the destination from the CUCM public ip address to its corresponding private ip address.
PhoneProxyASA(config)# object network obj-cucm-public
PhoneProxyASA(config-network-object)# host <cucm-public-ip-address>
PhoneProxyASA(config)# object network obj-cucm-private
PhoneProxyASA(config-network-object)# host <cucm-private-ip-address>
PhoneProxyASA(config)# nat (outside,inside) source dynamic any interface destination static obj-cucm-public obj-cucm-private
If the Call Manager cluster has multiple devices (TFTP server, Publisher, Subscriber etc) then there will need to be static translations, ctl-file entries and trustpoints for each individual device.
If the call manager is defined by its hostname (not by ip address) then when the phone first pulls the tftp configuration down the ASA will try to perform a lookup on the call manager hostname and this will fail. You'll see the following in the output of "debug phone-proxy tftp"
PP: Received Data Block 15 from vlan100:172.16.100.1/34248 to vlan96:172.16.96.16/49165
Received Block 15
PP: Acked Block #15 from 172.16.96.16/49165 to 172.16.100.1/34248
PP: Received Data Block 16 from vlan100:172.16.100.1/34248 to vlan96:172.16.96.16/49165
Received Block 16
PP: Acked Block #16 from 172.16.96.16/49165 to 172.16.100.1/34248
PP: Received Data Block 17 from vlan100:172.16.100.1/34248 to vlan96:172.16.96.16/49165
Received Block 17
PP: Acked Block #17 from 172.16.96.16/49165 to 172.16.100.1/34248
PP: Received Data Block 18 from vlan100:172.16.100.1/34248 to vlan96:172.16.96.16/49165
Received Block 18
PP: Acked Block #18 from 172.16.96.16/49165 to 172.16.100.1/34248
PP: Unable to get dns response for id 7
PP: Callback, error modifying config file
PP: Unable to CM name addr
PP: Callback required for parsing config file
The solution is to configure name resolution on the ASA, so it can resolve the ip for the name of the call manager
The certificate offered by the phone might be rejected if the date is wrong on the firewall. The phone might flash an error referring to TLS problems.
The syslogs on the firewall will show the following:
Jan 02 2005 22:22:38: %ASA-6-305011: Built dynamic TCP translation from
outside:172.18.254.95/1072 to inside:172.18.124.241/3165
Jan 02 2005 22:22:38: %ASA-6-302013: Built inbound TCP connection 569 for
outside:172.18.254.95/1072 (172.18.124.241/3165) to inside:172.18.124.230/2000 (14.36.107.90/2443)
Jan 02 2005 22:22:38: %ASA-6-725001: Starting SSL handshake with client
outside:172.18.254.95/1072 for TLSv1 session.
Jan 02 2005 22:22:38: %ASA-7-725010: Device supports the following 4 cipher(s).
Jan 02 2005 22:22:38: %ASA-7-725011: Cipher[1] : RC4-SHA
Jan 02 2005 22:22:38: %ASA-7-725011: Cipher[2] : AES128-SHA
Jan 02 2005 22:22:38: %ASA-7-725011: Cipher[3] : AES256-SHA
Jan 02 2005 22:22:38: %ASA-7-725011: Cipher[4] : DES-CBC3-SHA
Jan 02 2005 22:22:38: %ASA-7-725008: SSL client outside:172.18.254.95/1072 proposes
the following 2 cipher(s).
Jan 02 2005 22:22:38: %ASA-7-725011: Cipher[1] : AES256-SHA
Jan 02 2005 22:22:38: %ASA-7-725012: Device chooses cipher : AES128-SHA for the SSL
session with client outside:172.18.254.95/1072
Jan 02 2005 22:22:38: %ASA-7-111009: User 'enable_15' executed cmd: show logging
Jan 02 2005 22:22:40: %ASA-7-717025: Validating certificate chain containing 1
certificate(s).
Jan 02 2005 22:22:40: %ASA-7-717029: Identified client certificate within certificate
chain. serial number: 01, subject name: cn=SEP0007EBF0EE54.
Jan 02 2005 22:22:40: %ASA-7-717030: Found a suitable trustpoint capf_trustpoint to
validate certificate.
Jan 02 2005 22:22:40: %ASA-3-717009: Certificate validation failed. Certificate date
is out-of-range, serial number: 01, subject name: cn=SEP0007EBF0EE54.
Jan 02 2005 22:22:40: %ASA-3-717027: Certificate chain failed validation. Certificate
chain date is out-of-range.
Jan 02 2005 22:22:40: %ASA-7-725014: SSL lib error. Function: SSL3_GET_CLIENT_CERTIFICATE
Jan 02 2005 22:22:40: %ASA-6-725006: Device failed SSL handshake with outside
client:172.18.254.95/1072
Jan 02 2005 22:22:40: %ASA-6-302014: Teardown TCP connection 569 for
outside:172.18.254.95/1072 to inside:172.18.124.230/2000 duration 0:00:02 bytes 901 Flow closed by inspection
Please see bug id CSCsv86408.
* Please note that starting in ASA version 8.2, a Media Termination Address can be configured on a per-interface basis. This resolves many of the call audio-routing problems that some administrators encountered when deploying phone-proxy in version 8.0. For more information on per-interface MTA, see the config example here: https://supportforums.cisco.com/docs/DOC-8165
The most likely cause of this problem is incorrect packet routing, caused by one of the following situations:
An example of this is shown here:
Please note that starting in the upcoming version 8.2, a new feature is being added that supports per-interface Media Termination Addresses. This will mitigate the problem outlined in this example.
You can potentially mitigate this problem by doing one of the following:
As part of Call Manager 8.0 (CUCM 8.0) phone HTTP services, such as directory and authentication, will now use HTTPS connections by default. At this time, these features are not supported with the proxy-server functionality of the ASA's Phone Proxy.
Please see ASA defect CSCti62447
Why it does not work
In order for the Phones to make secure (HTTPS) connections, the phone must now communicate with the TVS store on the Call Manager. Currently, Phone Proxy does not support communication with the TVS store and as a result, Secure Services will fail.
The message flow for TVS without Phone Proxy will be the following:
This feature allows us to maintain one trust store on the CUCM server for all IP Phone endpoints that support TVS. This will be enabled by default on all 3rd gen and newer phones running 9.X phone firmware on 8.X CUCM.
Workaround
In order to get this to work with the current Phone Proxy implementation, you need to force the phone to use HTTP instead of HTTPS. There is no straight forward way of achieving this. In order to have the phone use HTTP instead of HTTPS please configure the following setting in Call Manager for the remote phone-proxy phone
Once the phone configuration on the Call Manager is set correctly, configure the 'proxy-server' functionality in the ASA phone-proxy config as you would normally. For example:
phone-proxy ASA-phone-proxy
media-termination phone-proxy-mta
tftp-server address 192.168.0.11 interface Inside
tls-proxy ASA-tls-proxy
ctl-file ctl_phoneproxy_file
proxy-server address 192.168.0.11 interface Inside
These show commands are taken in the context of the following network diagram:
| show phone-proxy secure-phones |
This shows all phones currently in the phone-proxy's secure-phone DB. Note that if the Port for a phone is 0, that means the phone has not successfully registered with the CUCM.
PhoneProxyASA# show phone-proxy secure-phones
ASA-phone-proxy: 2 in use, 2 most used
Interface IP Address Port MAC Timeout Idle
outside 172.18.254.25 19931 0009.b7d0.eea7 0:05:00 0:00:11
outside 172.18.254.73 50124 0007.ebf0.ee54 0:05:00 0:00:08
PhoneProxyASA#
| show phone-proxy media-sessions |
This shows all currently active media-sessions (calls) that are flowing through the firewall. If no calls are currently up, this output will be blank.
PhoneProxyASA# show phone-proxy media-sessions
Media-session: 14.36.107.91/26830 :: client ip 172.18.254.73/29836
Lcl SRTP conn 14.36.107.91/26830 to 172.18.254.25/41282 tx_pkts 60 rx_pkts 61
Media-session: 14.36.107.91/29724 :: client ip 172.18.254.25/41282
Lcl SRTP conn 14.36.107.91/29724 to 172.18.254.73/29836 tx_pkts 61 rx_pkts 61
PhoneProxyASA#
| show tls-proxy sessions |
This shows all the phones currently terminating TLS connections on the ASA.
PhoneProxyASA# show tls-proxy sessions
3 in use (3 established), 7 most used
outside 172.18.254.95:1035 inside 172.18.124.230:2000 P:0xd5a407f0(ASA-tls-proxy) S:0xd5bd4738 byte 8392
outside 172.18.254.46:1143 inside 172.18.124.230:2000 P:0xd5a407f0(ASA-tls-proxy) S:0xd5bd7c90 byte 8572
outside 172.18.254.49:6136 inside 172.18.124.230:2000 P:0xd5a407f0(ASA-tls-proxy) S:0xd5bbac40 byte 6460
You will see an identical connection in the show conn output:
PhoneProxyASA# show conn
4 in use, 48 most used
TCP outside 172.18.124.241(172.18.254.95):1035 inside 172.18.124.230:2000, idle 0:00:27, bytes 16951, flags UIOB
TCP outside 172.18.124.241(172.18.254.49):6136 inside 172.18.124.230:2000, idle 0:00:13, bytes 13949, flags UIOB
TCP outside 172.18.124.241(172.18.254.46):1143 inside 172.18.124.230:2000, idle 0:00:04, bytes 17213, flags UIOB
| show tls-proxy sessions detail |
This shows detailed information on the TLS connections. If the connection to the CUCM is cleartext, the State would show "TCPOK" like so:
PhoneProxyASA# show tls-proxy sessions detail
outside 172.18.22.223:2658 DMZ 192.168.2.3:2000 P:0xd5f4fc20(mytls)
S:0xd6193430 byte 37124
Client: State SSLOK Cipher AES128-SHA Ch 0xd49090d8 TxQSize 0
LastTxLeft 0 Flags 0x31
Server: State TCPOK Cipher N/A Ch 0xd4909118 TxQSize 0
LastTxLeft 0 Flags 0x8
| show phone-proxy signaling-sessions |
PhoneProxyASA# show phone-proxy signaling-sessions
outside 172.18.254.25:19931 inside 172.18.124.230:2000
Local Media (audio) conn: 172.18.254.25/22988 to 14.36.107.91/26830
Local SRTP key set : Remote SRTP key set
Remote Media (audio) conn: 14.36.107.91/26830 to 14.36.107.91/29724
outside 172.18.254.73:50124 inside 172.18.124.230:2000
Local Media (audio) conn: 172.18.254.73/29836 to 14.36.107.91/29724
Remote Media (audio) conn: 14.36.107.91/29724 to 14.36.107.91/26830
PhoneProxyASA#
| show asp table classify domain app-redirect |
This shows all the app-redirect rules created by the phone-proxy. There should be one entry for each phone to the CUCM IF the phone was configured as a nonsecure phone.
PhoneProxyASA# show asp table classify domain app-redirect
Interface _phone_proxy_ifc:
Interface inside:
Interface outside:
in id=0xd5b85918, priority=12, domain=app-redirect, deny=false
hits=1, user_data=0xd007, cs_id=0x0, flags=0x0, protocol=6
src ip=172.18.254.73, mask=255.255.255.255, port=0
dst ip=14.36.107.95, mask=255.255.255.255, port=2443, dscp=0x0
in id=0xd59f0d10, priority=12, domain=app-redirect, deny=false
hits=0, user_data=0xdc0e, cs_id=0x0, flags=0x0, protocol=6
dst ip=14.36.107.95, mask=255.255.255.255, port=3804, dscp=0x0
in id=0xd5ba9a28, priority=12, domain=app-redirect, deny=false
src ip=172.18.254.25, mask=255.255.255.255, port=0
in id=0xd59d8f58, priority=12, domain=app-redirect, deny=false
Interface identity:
Last clearing of hits counters: Never
PhoneProxyASA#
| show asp table classify domain inspect-phone-proxy |
This shows the classification rule to punt all TFTP traffic destined to the configured phone-proxy TFTP server to the inspect-phone-proxy engine. The classification rule should show the TFTP server's global address for that particular interface. If the phone-proxy was applied globally, there should be a classification rule for each interface except the interface it resides on. This rule is built when the phone-proxy config is applied to a service-policy in MPF, and will build the rules based upon the existing translation config on the firewall. Therefore, if you configure the phone proxy and apply it and then later put the NAT config in, the asp table rule will be incorrect (it will show the local ip for the call manager, not the global ip like it should). Therefore, ensure that you configure nat first, THEN apply the phone-proxy mpf to a service-policy.
PhoneProxyASA#show asp table classify domain inspect-phone-proxy
Interface inside:
Interface outside:
in id=0xd5ba1640, priority=73, domain=inspect-phone-proxy, deny=false
hits=4200, user_data=0xd59beff8, cs_id=0x0, reverse, flags=0x0, protocol=17
src ip=0.0.0.0, mask=0.0.0.0, port=0
dst ip=14.36.107.95, mask=255.255.255.255, port=69, dscp=0x0
in id=0xd59ca8b8, priority=73, domain=inspect-phone-proxy, deny=false
hits=0, user_data=0xd48b62b0, cs_id=0x0, reverse, flags=0x0, protocol=17
Interface identity:
PhoneProxyASA#
| show conn | inc p |
This shows all the connections that have gone through the inspect-phone-proxy which inspects the TFTP traffic.
PhoneProxyASA# show conn | inc p
9 in use, 67 most used
UDP outside 172.18.254.25:8872 inside 172.18.124.230:32847, idle 0:00:02, bytes 4076, flags p-
UDP outside 172.18.254.25:62644 inside 172.18.124.230:39392, idle 0:00:03, bytes 4486, flags p-
TCP outside 172.18.124.241(172.18.254.25):29544 inside 172.18.124.230:2000, idle 0:00:01, bytes 894, flags UOB
UDP outside 172.18.254.25:8872 inside 172.18.124.230:69, idle 0:00:02, bytes 32, flags p-
UDP outside 172.18.254.25:62644 inside 172.18.124.230:69, idle 0:00:03, bytes 0, flags p-
TCP outside 172.18.124.241(172.18.254.73):50124 inside 172.18.124.230:2000, idle 0:00:14, bytes 22969, flags UIOB
PhoneProxyASA#
New syslogs relating to the phone-proxy feature:
%ASA-4-446001 - Maximum number of configured TLS proxy sessions reached
%ASA-4-446001: Maximum TLS Proxy session limit of max_sess reached.
%ASA-4-446002 - License exceeded
%ASA-4-446002: Denied TLS Proxy session from outside:10.10.10.2/49572 to inside:192.168.1.2/2000, licensed UC Proxy session limit of 20 exceeded
Sample syslogs from when a phone connected to the phone-proxy reboots and connects back in
%ASA-5-305011: Built dynamic UDP translation from outside:172.18.254.73/53011 to
inside:172.18.124.241/60692
%ASA-6-302015: Built inbound UDP connection 4338 for outside:172.18.254.73/53011
(172.18.124.241/60692) to inside:172.18.124.230/69 (14.36.107.95/69)
%ASA-6-302015: Built inbound UDP connection 4339 for outside:172.18.254.73/53011
(172.18.124.241/60692) to inside:172.18.124.230/4677 (14.36.107.95/4677)
%ASA-6-305011: Built dynamic UDP translation from outside:172.18.254.73/53012 to
inside:172.18.124.241/63537
%ASA-6-302015: Built inbound UDP connection 4340 for outside:172.18.254.73/53012
(172.18.124.241/63537) to inside:172.18.124.230/69 (14.36.107.95/69)
%ASA-6-302015: Built inbound UDP connection 4341 for outside:172.18.254.73/53012
(172.18.124.241/63537) to inside:172.18.124.230/32851 (14.36.107.95/32851)
%ASA-6-305011: Built dynamic TCP translation from outside:172.18.254.73/50125 to
inside:172.18.124.241/37554
%ASA-6-302013: Built inbound TCP connection 4342 for outside:172.18.254.73/50125
(172.18.124.241/37554) to inside:172.18.124.230/2000 (14.36.107.95/2443)
%ASA-6-725001: Starting SSL handshake with client outside:172.18.254.73/50125 for TLSv1 session.
%ASA-7-725008: SSL client outside:172.18.254.73/50125 proposes the following 2 cipher(s).
%ASA-7-725012: Device chooses cipher : AES128-SHA for the SSL session with client
%ASA-7-717025: Validating certificate chain containing 1 certificate(s).
%ASA-7-717029: Identified client certificate within certificate chain.
%ASA-7-717030: Found a suitable trustpoint capf_trustpoint to validate certificate.
%ASA-6-717022: Certificate was successfully validated. serial number: 01,
%ASA-6-717028: Certificate chain was successfully validated with warning,
revocation status was not checked.
%ASA-6-725002: Device completed SSL handshake with client outside:172.18.254.73/50125
%ASA-6-305011: Built dynamic TCP translation from outside:172.18.254.73/52675
to inside:172.18.124.241/45909
%ASA-7-711002: Task ran for 8 msec, Process = Dispatch Unit, PC = 8172a27, Traceback =
Traceback = 0x08172A27 0x0805E983
%ASA-6-305012: Teardown dynamic TCP translation from outside:172.18.254.73/50124 to
inside:172.18.124.241/51711 duration 1:41:06
%ASA-6-305011: Built dynamic UDP translation from outside:172.18.254.73/53013 to
inside:172.18.124.241/58122
%ASA-6-302015: Built inbound UDP connection 4343 for outside:172.18.254.73/53013
(172.18.124.241/58122) to inside:172.18.124.230/69 (14.36.107.95/69)
%ASA-6-302015: Built inbound UDP connection 4344 for outside:172.18.254.73/53013
(172.18.124.241/58122) to inside:172.18.124.230/32852 (14.36.107.95/32852)
%ASA-6-305011: Built dynamic UDP translation from outside:172.18.254.73/53014 to
inside:172.18.124.241/54570
%ASA-6-302015: Built inbound UDP connection 4345 for outside:172.18.254.73/53014
(172.18.124.241/54570) to inside:172.18.124.230/69 (14.36.107.95/69)
%ASA-6-302015: Built inbound UDP connection 4346 for outside:172.18.254.73/53014
(172.18.124.241/54570) to inside:172.18.124.230/32853 (14.36.107.95/32853)
%ASA-6-305011: Built dynamic UDP translation from outside:172.18.254.73/53015 to
inside:172.18.124.241/63316
%ASA-6-302015: Built inbound UDP connection 4347 for outside:172.18.254.73/53015
(172.18.124.241/63316) to inside:172.18.124.230/69 (14.36.107.95/69)
%ASA-6-302015: Built inbound UDP connection 4348 for outside:172.18.254.73/53015
(172.18.124.241/63316) to inside:172.18.124.230/32854 (14.36.107.95/32854)
| debug phone-proxy tftp |
This debug will output information about the tftp session proxied by the firewall.
PhoneProxyASA# debug phone-proxy tftp
PhoneProxyASA#
PhoneProxyASA# !- The phone is now rebooted
PhoneProxyASA#
PhoneProxyASA# PP: 172.18.254.25/37212 requesting CTLSEP0009B7D0EEA7.tlv
PP: opened 0x8685366
PP: Data Block 1 forwarded from 14.36.107.95/29840 to 172.18.254.25/37212 ingress ifc outside
PP: Received ACK Block 1 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.25/37212
PP: Received ACK Block 2 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 3 forwarded to 172.18.254.25/37212
PP: Received ACK Block 3 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 4 forwarded to 172.18.254.25/37212
PP: Received ACK Block 4 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 5 forwarded to 172.18.254.25/37212
PP: Received ACK Block 5 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 6 forwarded to 172.18.254.25/37212
PP: Received ACK Block 6 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 7 forwarded to 172.18.254.25/37212
PP: Received ACK Block 7 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 8 forwarded to 172.18.254.25/37212
PP: Received ACK Block 8 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: Data Block 9 forwarded to 172.18.254.25/37212
PP: Received ACK Block 9 from outside:172.18.254.25/37212 to inside:172.18.124.230
PP: 172.18.254.25/53261 requesting SEP0009B7D0EEA7.cnf.xml.sgn
PP: opened 0x8693dd2
PP: Received Data Block 1 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 1
PP: Acked Block #1 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Received Data Block 2 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 2
PP: Acked Block #2 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Received Data Block 3 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 3
PP: Acked Block #3 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Received Data Block 4 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 4
PP: Acked Block #4 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Received Data Block 5 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 5
PP: Acked Block #5 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Received Data Block 6 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 6
PP: Acked Block #6 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Received Data Block 7 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 7
PP: Acked Block #7 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Received Data Block 8 from inside:172.18.124.230/32851 to outside:172.18.254.25/53261
Received Block 8
PP: Acked Block #8 from 172.18.124.241/49633 to 172.18.124.230/32851
PP: Data Block 1 forwarded from 14.36.107.95/32851 to 172.18.254.25/53261
PP: Received ACK Block 1 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.25/53261
PP: Received ACK Block 2 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Data Block 3 forwarded to 172.18.254.25/53261
PP: Received ACK Block 3 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Data Block 4 forwarded to 172.18.254.25/53261
PP: Received ACK Block 4 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Data Block 5 forwarded to 172.18.254.25/53261
PP: Received ACK Block 5 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Data Block 6 forwarded to 172.18.254.25/53261
PP: Received ACK Block 6 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Data Block 7 forwarded to 172.18.254.25/53261
PP: Received ACK Block 7 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Data Block 8 forwarded to 172.18.254.25/53261
PP: Received ACK Block 8 from outside:172.18.254.25/53261 to inside:172.18.124.230
PP: Retrieved MAC 0009.b7d0.eea7 from subject-name cn=SEP0009B7D0EEA7, mac string 0009B7D0EEA7
PP: Found phone device d5b94218
PP: 172.18.254.25/14201 requesting SEP0009B7D0EEA7.cnf.xml.sgn
PP: opened 0x86abd3a
PP: Received Data Block 1 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 1
PP: Acked Block #1 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: Received Data Block 2 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 2
PP: Acked Block #2 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: Received Data Block 3 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 3
PP: Acked Block #3 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: Received Data Block 4 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 4
PP: Acked Block #4 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: Received Data Block 5 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 5
PP: Acked Block #5 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: Received Data Block 6 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 6
PP: Acked Block #6 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: Received Data Block 7 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 7
PP: Acked Block #7 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: Received Data Block 8 from inside:172.18.124.230/32851 to outside:172.18.254.25/14201
Received Block 8
PP: Acked Block #8 from 172.18.124.241/6550 to 172.18.124.230/32851
PP: 172.18.254.25/47823 requesting RINGLIST.XML.sgn
PP: opened 0x86bf8f6
PP: Data Block 1 forwarded from 14.36.107.95/32851 to 172.18.254.25/14201
PP: Received Data Block 1 from inside:172.18.124.230/32851 to outside:172.18.254.25/47823
Received Block 1
PP: Acked Block #1 from 172.18.124.241/13065 to 172.18.124.230/32851
PP: Received Data Block 2 from inside:172.18.124.230/32851 to outside:172.18.254.25/47823
Received Block 2
PP: Acked Block #2 from 172.18.124.241/13065 to 172.18.124.230/32851
PP: Received ACK Block 1 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.25/14201
PP: Received Data Block 3 from inside:172.18.124.230/32851 to outside:172.18.254.25/47823
Received Block 3
PP: Acked Block #3 from 172.18.124.241/13065 to 172.18.124.230/32851
PP: Received Data Block 4 from inside:172.18.124.230/32851 to outside:172.18.254.25/47823
Received Block 4
PP: Acked Block #4 from 172.18.124.241/13065 to 172.18.124.230/32851
PP: Received Data Block 5 from inside:172.18.124.230/32851 to outside:172.18.254.25/47823
Received Block 5
PP: Acked Block #5 from 172.18.124.241/13065 to 172.18.124.230/32851
PP: Data Block 1 forwarded from 14.36.107.95/32851 to 172.18.254.25/47823
PP: Received ACK Block 2 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Data Block 3 forwarded to 172.18.254.25/14201
PP: Received ACK Block 1 from outside:172.18.254.25/47823 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.25/47823
PP: Received ACK Block 3 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Data Block 4 forwarded to 172.18.254.25/14201
PP: Received ACK Block 2 from outside:172.18.254.25/47823 to inside:172.18.124.230
PP: Data Block 3 forwarded to 172.18.254.25/47823
PP: Received ACK Block 4 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Data Block 5 forwarded to 172.18.254.25/14201
PP: Received ACK Block 3 from outside:172.18.254.25/47823 to inside:172.18.124.230
PP: Data Block 4 forwarded to 172.18.254.25/47823
PP: Received ACK Block 5 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Data Block 6 forwarded to 172.18.254.25/14201
PP: Received ACK Block 4 from outside:172.18.254.25/47823 to inside:172.18.124.230
PP: Data Block 5 forwarded to 172.18.254.25/47823
PP: Received ACK Block 6 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Data Block 7 forwarded to 172.18.254.25/14201
PP: Received ACK Block 5 from outside:172.18.254.25/47823 to inside:172.18.124.230
PP: Received ACK Block 7 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Data Block 8 forwarded to 172.18.254.25/14201
PP: 172.18.254.25/56992 requesting DISTINCTIVERINGLIST.XML.sgn
PP: opened 0x86c9112
PP: Received ACK Block 8 from outside:172.18.254.25/14201 to inside:172.18.124.230
PP: Received Data Block 1 from inside:172.18.124.230/32851 to outside:172.18.254.25/56992
Received Block 1
PP: Acked Block #1 from 172.18.124.241/62582 to 172.18.124.230/32851
PP: Received Data Block 2 from inside:172.18.124.230/32851 to outside:172.18.254.25/56992
Received Block 2
PP: Acked Block #2 from 172.18.124.241/62582 to 172.18.124.230/32851
PP: Data Block 1 forwarded from 14.36.107.95/32851 to 172.18.254.25/56992
PP: Received ACK Block 1 from outside:172.18.254.25/56992 to inside:172.18.124.230
PP: Data Block 2 forwarded to 172.18.254.25/56992
PP: Received ACK Block 2 from outside:172.18.254.25/56992 to inside:172.18.124.230
PhoneProxyASA#
| debug phone-proxy media |
PhoneProxyASA# debug phone-proxy media
PhoneProxyASA#
PhoneProxyASA# !- A call is made from one phone to another
PhoneProxyASA#
PhoneProxyASA#
snp_client_sess_create: Creating client_sess 14.36.107.91/25752 172.18.254.73/24316
snp_media_sess_lock: locking media_sess 14.36.107.91/25752 1
Creating new media session in SNP 14.36.107.91/25752
Setting remote_side SRTP params in SNP 14.36.107.91/25752
SNP_SRTP::master_key and salt 1c9050bb8e388149b89b092e4dca2275 1c9050bb8e388149b89b092e4dca2275
snp_media_sess_lock: locking media_sess 14.36.107.91/25752 2
Rmt media is NULL 14.36.107.91/39012
Getting remote SRTP params in SNP 14.36.107.91/25752
snp_media_sess_lock: locking media_sess 14.36.107.91/25752 3
Remote SRTP params for 14.36.107.91/25752 already set
Setting local SRTP params in SNP 14.36.107.91/25752
SNP_SRTP::master_key and salt e8f9f25522578aff38d32d95895e40b4 e8f9f25522578aff38d32d95895e40b4
snp_client_sess_create: Creating client_sess 14.36.107.91/29668 172.18.254.25/17472
snp_media_sess_lock: locking media_sess 14.36.107.91/29668 1
Creating new media session in SNP 14.36.107.91/29668
Local SRTP params for 14.36.107.91/25752 already set
Setting remote_side SRTP params in SNP 14.36.107.91/29668
snp_media_sess_lock: locking media_sess 14.36.107.91/25752 4
snp_media_sess_lock: locking media_sess 14.36.107.91/25752 5
snp_media_sess_lock: locking media_sess 14.36.107.91/29668 2
Getting remote SRTP params in SNP 14.36.107.91/29668
snp_media_sess_lock: locking media_sess 14.36.107.91/29668 3
Remote SRTP params for 14.36.107.91/29668 already set
Setting local SRTP params in SNP 14.36.107.91/29668
snp_media_sess_lock: locking media_sess 14.36.107.91/29668 4
snp_media_sess_lock: locking media_sess 14.36.107.91/29668 5
SNP_SRTP::Remote media_session found for 14.36.107.91/25752 lcl_ip/lcl_port 14.36.107.91/29668
SNP_SRTP::Setting rmt_pp_ip 14.36.107.91 for 14.36.107.91/25752
SNP_SRTP::Setting passthrough
SNP_SRTP::Setting client_port to sport 24316
SNP_SRTP::Remote media_session found for 14.36.107.91/29668 lcl_ip/lcl_port 14.36.107.91/25752
SNP_SRTP::Setting client_port to sport 49114
PhoneProxyASA#
PhoneProxyASA# !- Call is now connected
PhoneProxyASA#
PhoneProxyASA# !- Call is hung up
PhoneProxyASA#
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/25752 4
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/25752 3
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/29668 4
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/29668 3
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/25752 2
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/25752 1
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/29668 2
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/29668 1
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/25752 0
snp_media_sess_release: releasing media_sess 14.36.107.91/25752
snp_media_sess_unlock: unlocking media_sess 14.36.107.91/29668 0
snp_media_sess_release: releasing media_sess 14.36.107.91/29668
PhoneProxyASA#
| debug phone-proxy signaling |
PhoneProxyASA# debug phone-proxy signaling
PhoneProxyASA#
PhoneProxyASA#
PhoneProxyASA# ! One phone now calls another...
PhoneProxyASA#
PhoneProxyASA#
Inspect Skinny: generating SRTP key
PP_SIG:: Setting rmt SRTP params in pp_cl d5b943f8
PP_SIG::master_key and salt 013351f6a163735e469307253dfa4c11 013351f6a163735e469307253dfa4c11
PP_SIG:: Setting rmt SRTP params in pp_cl d59db4d8
PP_SIG::master_key and salt 8704186bbb636c51079eb312e4d8d77d 8704186bbb636c51079eb312e4d8d77d
PP_SIG::pp_update_media_info: using conn's laddr 172.18.254.73/27754
PP_SIG::Updating lcl media info 172.18.254.73/27754
PP_SIG::Setting lcl_media_sess 14.36.107.91/29596
PP_SIG::Updating lcl PP media info 14.36.107.91/29596
PP_SIG:: calling np_media_sess_set_media_conns
PP_SIG::pp_update_media_info: Found media_sess 14.36.107.91/29596
Called np_nat_api_determine_location: 14.36.107.91/29596
PP_SIG::Updating rmt media info 14.36.107.91/29596
PP_SIG::Setting rmt_media_sess 14.36.107.91/29596
PP_SIG::Updating rmt PP media info 14.36.107.91/29596
PP_SIG:: Getting lcl SRTP params in pp_cl d59db4d8
PP_SIG::pp_update_media_info: using conn's laddr 172.18.254.25/20912
PP_SIG::Updating lcl media info 172.18.254.25/20912
PP_SIG::Setting lcl_media_sess 14.36.107.91/25654
PP_SIG::Updating lcl PP media info 14.36.107.91/25654
PP_SIG::pp_update_media_info: Found media_sess 14.36.107.91/25654
Called np_nat_api_determine_location: 14.36.107.91/25654
PP_SIG::Updating rmt media info 14.36.107.91/25654
PP_SIG::Setting rmt_media_sess 14.36.107.91/25654
PP_SIG::Updating rmt PP media info 14.36.107.91/25654
PP_SIG:: Getting lcl SRTP params in pp_cl d5b943f8
PhoneProxyASA#
PhoneProxyASA#
PhoneProxyASA#
PhoneProxyASA# !- Call is ended by called party
PhoneProxyASA#
PhoneProxyASA#
PP_SIG::pp_clear_lcl_media_ptr_values: calling media_sess_unlock on d59c35f8
PP_SIG::pp_clear_rmt_media_ptr_values: calling media_sess_unlock on d5b90218
PP_SIG::pp_clear_lcl_media_ptr_values: calling media_sess_unlock on d5b90218
PP_SIG::pp_clear_rmt_media_ptr_values: calling media_sess_unlock on d59c35f8
PhoneProxyASA#
ASA Version 8.0(5)
I've a customer setup where output of following command is showing CCM Internal Ip address and not the global ip address.
All other commands show the correct output, calling is also working fine.
Customer confirmed that he configured NAT first and then MPF. I can see one Global policy is configured but the Secure SCCP class-map is not called inside that and I believe it has nothing to do with my problem. See below MPF configuration:
class-map secure_sccp
match port tcp eq 2443
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
policy-map voice_policy
class secure_sccp
inspect skinny phone-proxy asa-phone-proxy
service-policy global_policy global
service-policy voice_policy interface outside
I am curious to know what issues he may face due to this mismatch, how to rectify it, any impact on ongoing calls?
inner_silence
This is a very good doc on the Phone Proxy, Thank you.
I have run into a problem though, which I dont think is covered here. I have no audio, including ringback when making an outside call, not to internal extensions. We use external voice gateways to send the calls out, so when the proxy phone makes the call, it connects, the remote phone can pick up the call, it connects, and no voice. I can see the connection on the ASA with the gateway IP and the proxy phone IP, so I can see that it has connected, but I have nothing after that.
In the media debug I can see the call connecting to the gateway using the MTA, gets 4 sess_lock, and nothing after that. Is there a translation I need to setup on the ASA for the Phone Proxy to work with external gateways?
The problem is most likely due to media-data packet routing, or media-packets being dropped somewhere in the network. In the case that media packets are routed incorrectly through the network (Discussed in the section above titled "One way, or no-way voice audio when call established") you might see syslogs like this, which indicate the firewall is receiving the media data on an unexpected interface:
%ASA-7-710005: UDP request discarded from 10.99.22.3/22431 to outside:192.168.1.2/28230 %ASA-7-710005: UDP request discarded from 10.99.22.3/22431 to outside:192.168.1.2/28230 %ASA-7-710005: UDP request discarded from 10.99.22.3/22431 to outside:192.168.1.2/28230 %ASA-7-710005: UDP request discarded from 10.99.22.3/22431 to outside:192.168.1.2/28230 %ASA-7-710005: UDP request discarded from 10.99.22.3/22431 to outside:192.168.1.2/28230 %ASA-7-710005: UDP request discarded from 10.99.22.3/22431 to outside:192.168.1.2/28230
Packet captures taken on the firewall interfaces for traffic sourced and destined
to the MTA address will probably help track down where the problem is (Packet capture ASA/PIX - FWSM).
However, these types of call routing-problems can be very complex, and it might be best to
open a case with the TAC.
i have the problem i configure the ASA with non secure
but the phone can not register
PP: Remote phone at 2.2.2.50/49152 requesting CTLSEP0013809EA017.tlv from 10.2.100.1/69
PP: Created entry for secure device outside:2.2.2.50, MAC 0013.809e.a017, current count 1, list count 1
PP: ASA sending local CTL file on disk myctl to remote phone, opened 0xe79fb2
PP: Data Block 1 sent from ASA at 2.2.2.10/25269 to remote phone at 2.2.2.50/49152, ingress ifc
PP: Received ACK for Block 1 from remote phone outside:2.2.2.50/49152 to ASA at inside:10.2.100.1
PP: Data Block 2 sent from ASA to remote phone at 2.2.2.50/49152
PP: Received ACK for Block 2 from remote phone outside:2.2.2.50/49152 to ASA at inside:10.2.100.1
PP: Data Block 3 sent from ASA to remote phone at 2.2.2.50/49152
PP: Received ACK for Block 3 from remote phone outside:2.2.2.50/49152 to ASA at inside:10.2.100.1
PP: Data Block 4 sent from ASA to remote phone at 2.2.2.50/49152
PP: Received ACK for Block 4 from remote phone outside:2.2.2.50/49152 to ASA at inside:10.2.100.1
PP: Data Block 5 sent from ASA to remote phone at 2.2.2.50/49152
PP: Received ACK for Block 5 from remote phone outside:2.2.2.50/49152 to ASA at inside:10.2.100.1
PP: Data Block 6 sent from ASA to remote phone at 2.2.2.50/49152
PP: Received ACK for Block 6 from remote phone outside:2.2.2.50/49152 to ASA at inside:10.2.100.1
PP: Data Block 7 sent from ASA to remote phone at 2.2.2.50/49152
PP: Received ACK for Block 7 from remote phone outside:2.2.2.50/49152 to ASA at inside:10.2.100.1
PP: CTL file TFTP session complete, CTL file has been successfully sent to the remote phone.
%ASA-6-302015: Built inbound UDP connection 464 for outside:2.2.2.50/49153 (2.2.2.50/49153) to inside:10.2.100.1/69 (2.2.2.10/69)
PP: Remote phone at 2.2.2.50/49153 requesting SEP0013809EA017.cnf.xml.sgn from 10.2.100.1/69
PP: The remote phone is requesting file SEP0013809EA017.cnf.xml.sgn.
PP: Removing .sgn extension, ASA is requesting file SEP0013809EA017.cnf.xml from Call Manager TFTP server.
PP: ASA sent request for SEP0013809EA017.cnf.xml sourced from outside:2.2.2.50 to inside:10.2.100.1, opened 0xe8c0fe
%ASA-6-302016: Teardown UDP connection 435 for outside:2.2.2.50/49157 to inside:10.2.100.1/69 duration 0:02:20 bytes 208
%ASA-7-710005: UDP request discarded from 10.2.2.14/17500 to inside:10.2.2.255/17500
PP: Client outside:2.2.2.50/49153 retransmitting request for Config file SEP0013809EA017.cnf.xml.sgn
%ASA-7-710005: UDP request discarded from 10.2.2.14/53856 to inside:255.255.255.255/43440
%ASA-6-302013: Built inbound TCP connection 466 for outside:2.2.2.50/51281 (2.2.2.50/51281) to inside:10.2.100.1/2000 (2.2.2.10/2000)
