Magnus Mortensen
Static NAT/PAT
Pre-8.3 NAT8.3 NAT
Regular Static NAT
static (inside,outside) 192.168.100.100 10.1.1.6 netmask  255.255.255.255
 object network obj-10.1.1.6
   host 10.1.1.6
   nat (inside,outside) static 192.168.100.100
Regular Static PAT
static (inside,outside) tcp 192.168.100.100 80 10.1.1.16 8080 netmask  255.255.255.255
 object network obj-10.1.1.16
   host 10.1.1.16
   nat (inside,outside) static 192.168.100.100 service tcp 8080 www
Static Policy NAT
access-list NET1 permit ip host 10.1.2.27 10.76.5.0 255.255.255.224
static (inside,outside) 192.168.100.100 access-list NET1
object network obj-10.1.2.27
   host 10.1.2.27
 object network obj-192.168.100.100
   host 192.168.100.100
 object network obj-10.76.5.0
   subnet 10.76.5.0 255.255.255.224
 nat (inside,outside) source static obj-10.1.2.27 obj-192.168.100.100
                      destination static obj-10.76.5.0 obj-10.76.5.0
Pre-8.3 NAT8.3 NAT
Regular Dynamic PAT
 nat (inside) 1 192.168.1.0 255.255.255.0
 nat (dmz) 1 10.1.1.0 255.255.255.0
 global (outside) 1
192.168.100.100
object network obj-192.168.1.0
   subnet 192.168.1.0 255.255.255.0
   nat (inside,outside) dynamic 192.168.100.100
 object network obj-10.1.1.0
   subnet 10.1.1.0 255.255.255.0
   nat (dmz,outside) dynamic 192.168.100.100
Regular Dynamic PAT
nat (inside) 1 10.1.2.0 255.255.255.0
global (outside) 1 192.168.100.100
global (dmz) 1 192.168.1.1
 object network obj-10.1.2.0
   subnet 10.1.2.0 255.255.255.0
 object network obj-10.1.2.0-01
   nat (inside,dmz) dynamic 192.168.1.1
Regular Dynamic PAT-3
 nat (inside) 1 0 0
 global (outside) 1 interface
 object network obj_any
   subnet 0.0.0.0 0.0.0.0
   nat (inside,outside) dynamic interface
Dynamic Policy NAT
 object-group network og-net-src
   network-object 192.168.1.0 255.255.255.0
   network-object 192.168.2.0 255.255.255.0
 object-group network og-net-dst
   network-object 192.168.200.0 255.255.255.0
 object-group service og-ser-src
   service-object tcp gt 2000
   service-object tcp eq 1500
 access-list NET6 extended permit object-group og-ser-src
                  object-group og-net-src object-group og-net-dst
 nat (inside) 10 access-list NET6
 global (outside) 10 192.168.100.100
 object service obj-tcp-range-2001-65535
   service tcp destination range 2001 65535
 object service obj-tcp-eq-1500
   service tcp destination eq 1500
 nat (inside,outside) source dynamic og-net-src
             obj-192.168.100.100 destination
             static og-net-dst og-net-dst
             service obj-tcp-eq-1500 obj-tcp-eq-1500
Policy Dynamic NAT (with multiple ACEs)
 access-list ACL_NAT permit ip 172.29.0.0 255.255.0.0
                               192.168.3.0 255.255.255.0
                               192.168.4.0 255.255.255.0
 nat (inside) 1 access-list ACL_NAT
 object network obj-172.29.0.0
   subnet 172.29.0.0 255.255.0.0
object network obj-192.168.2.0
   subnet 192.168.2.0 255.255.255.0
object network obj-192.168.3.0
   subnet 192.168.3.0 255.255.255.0
 object network obj-192.168.4.0
   subnet 192.168.4.0 255.255.255.0
nat (inside,outside) source dynamic obj-172.29.0.0 obj-192.168.100.100
             destination static obj-192.168.1.0 obj-192.168.1.0
             destination static obj-192.168.2.0 obj-192.168.2.0
             destination static obj-192.168.3.0 obj-192.168.3.0
             destination static obj-192.168.4.0 obj-192.168.4.0
Outside NAT
 global (inside) 1 10.1.2.30-1-10.1.2.40
 nat (dmz) 1 10.1.1.0 255.255.255.0 outside
 static (inside,dmz) 10.1.1.5 10.1.2.27 netmask 255.255.255.255
   host 10.1.2.27
   nat (inside,dmz) static 10.1.1.5
   nat (dmz,inside) dynamic obj-10.1.2.30-10.1.2.40
 object network obj-10.1.2.30-10.1.2.40
   range 10.1.2.30 10.1.2.40
NAT & Interface PAT together
 global (outside) 1 192.168.100.100-192.168.100.200
 object network obj-192.168.100.100_192.168.100.200
   range 192.168.100.100 192.168.100.200
            obj-192.168.100.100_192.168.100.200 interface
NAT & Interface PAT with additional PAT together
 nat (inside) 1 10.0.0.0 255.0.0.0
  global (outside) 1 192.168.100.1-192.168.100.200
  global (outside) 1 192.168.100.210
 object network obj-10.0.0.0
   subnet 10.0.0.0 255.0.0.0
 object network second-pat
   host 192.168.100.210
 object-group network dynamic-nat-pat
   network-object object obj-192.168.100.100_192.168.100.200
   network-object object second-pat
nat (inside,outside) dynamic dynamic-nat-pat interface
Twice NAT with both source IP, Dest IP and Source port, Dest port change.
On the inside:
Source IP: 10.30.97.129
Dest IP: 10.30.97.200
Source port: 5300
Dest port: any port
On the outside:
Source IP: Interface IP
Dest IP: 172.16.1.10
Source port: 5300
Dest port: 1022
object network source-real
  host 10.30.97.129
object network dest-mapped
  host 10.30.97.200
object network dest-real
  host 172.16.1.10
object service inside-src-dest-port
 service tcp source eq 5300 destination range 0 65535
object service outside-src-dest-port
 service tcp source eq 5300 destination eq 1022
nat (inside,outside) after source static source-real interface destination static dest-mapped dest-real service inside-src-dest-port outside-src-dest-port
Static NAT for a Range of Ports
Not Possible - Need to write multiple Statements or perform a Static one-to-one NAT.
           (in)    (out)
10.1.1.1-------ASA-----
        --xlate-------> 10.2.2.2
Original Ports: 10000 - 10010
Translated ports: 20000 - 20010
object service ports
service tcp source range 10000 10010
object service ports-xlate
service tcp source range 20000 20010
object network server
host 10.1.1.1
object network server-xlate
host 10.2.2.2
nat (inside,outside) source static server server-xlate service ports ports-xlate
David White
Yes, that is correct.
darshan288shah
I am using ASA5505 with version a 8.3(2) and having problem with the nat configuration.
inside ip - 192.168.1.1/255.255.255.0
outside ip - 10.127.225.10/255.255.255.0
we have TCP10042 as service port thru' which we are passing data from inside network to outside network.
We have Client_server as 10.127.226.21/24
our DataServer as 192.168.1.3/ 24
we want to send the data from dataServer to Client server thru' port no. 10042.
We did following settings in the ASA thru' ASDM but facing problem that no any nating actually takes place.
Object network Client_Server
host 10.127.226.21
Object network DataServer
host 192.168.1.3
Object service TCP_10042
Service tcp source range 1 65535 destination eq 10042
Object network Firewall_Outside
host 10.127.225.10
object network DataServer(192.168.1.3)
nat (inside, outside) static interface service tcp 10042 10042
object network Firewall_outside (10.l27.225.10)
nat (outside, inside) static DataServer(192.168.1.3) service tcp 10042 10042
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit tcp any any
access-list outside_access_in extended permit tcp any any
access-list outside_access_in extended permit ip any any
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group outside_access_in in interface outside
access-group global_access global
but still we are getting problem for NAT rules.
Also when we tried with Packet Transfer check point and found that "Access List - denied due to “Implicit rule”
Please help how we have to transfer data thru' Firewall.
Jouni Forss
Hi Darshan Shah,
Please post this question on the Discussion area of the CSC and not in a document
You will find the Firewall section of the forums here
https://supportforums.cisco.com/community/netpro/security/firewall?view=discussions
- Jouni
petr.hofmann
Hello guys,
I am trying to use your NAT conversion table, but I cant solve it... Can anyone please help me? My old config is following:
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 any
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 host 192.168.0.0
access-list 101 extended permit icmp any any echo
access-list 101 extended permit icmp any any echo-reply
access-list inside_nat0_outbound_1 extended permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_1_cryptomap_1 extended permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound_1
nat (inside) 101 0.0.0.0 0.0.0.0
access-group 101 in interface outside
Jouni Forss
Hi Petr,
As in the previous reply above, I would suggest that you also post this question on the Discussions section rather than in this Document.
- Jouni
David White
Hi Petr,
You only have two NAT rules:
1) nat (inside) 0 access-list inside_nat0_outbound_1
  Which says:  Do not NAT traffic matching access-list inside_nat0_outbound_1 - which is:
This translates into the following NAT rule:
object network ServerReal
object network RemoteSite
subnet 192.168.0.0 255.255.255.0
nat (inside,outside) source static ServerReal ServerReal destination static RemoteSite RemoteSite
2) global (outside) 101 interface
Which says, "PAT all inside traffic to the outside interface IP address"
This will be changed to the following:
  object network any
Hope this helps!
David.
Odys (CSC)
Could someone describe a static nat in PLAIN ENGLISH for me ?
for instance, allowong external access to internal web server (10.1.1.6)
object network obj-WEB-SVR
   host 10.1.1.6
   nat(inside,outside) static 192.168.100.100
what does the statement say ?
THX
The statement says that there is a Web-Server at 10.1.1.6 on the "inside" and it is statically being translated to 192.168.100.100 on the "outside"
Odys (CSC)
In this case the outside user is supposed to initiate the request to the inside web-server, not vice versa.
Still that work ?
This is a bi-directional nat statement. So yes, outside user can initiate a connection request to 192.168.100.100 which will then get untranslated to 10.1.1.6 on the inside interface.
PS: We need to allow access to real ip address in the access-list on the outside interface i.e. "permit <protocol> any host 10.1.1.6")
Odys (CSC)
Obvious, thank you!
sandman42
One question:
I have a 8.2 nat that says:
nat (inside) 1 0.0.0.0 0.0.0.0
This should translate in a 8.4.1:
object network OBJ_GENERIC_ALL
nat (inside,outside) dynamic OBJ_GENERIC_ALL
but this give me an error with the caret pointing to the "d" of "dynamic".
What's wrong??????
I see a problem with the statement:
an ip-address/network-based object should follow the 'dynamic' keyword.
In your case, i see the statement should have been:
sandman42
I've added a
nat (inside,outside) after-auto source dynamic any interface
and now it works.
Thanks anyway
Mahesh Deshpande
Well thank you Mr.
Poonguzhali Sankar
It has helped me a lot................
