HQuest
Symptoms
Hardware based devices have, from time to time, BIOS, UEFI or firmware updates, which Cisco calls - for historical purposes - "ROMMON". While there is always an accompanying upgrade guide, there is no reference whatsoever for the ASA-x while running as FTD/sensor mode. This article will add this missing link, in the event anyone ever has to follow this process - as I just did. The below was tested successfully on a 5506-X lab device running FTD 6.2.3.6, managed by a FMC.
Diagnosis
As per "Cisco ASA Series General Operations CLI Configuration Guide, 9.5" document, section "Chapter: Software and Configurations", subsection "Upgrade the ROMMON Image (5506-x, 5508-x, and 5516-x)" [1], the instructions points the admin to upload the new ROMMON code to the device and run the upgrade rommon command. While the firmware revision verification and the file transfer commands can be achieved using the FTD CLI (with a minor command line adjustment for file transfer), there is no such upgrade command. As such, you now may feel stuck.
[1] https://www.cisco.com/c/en/us/td/docs/security/asa/asa95/configuration/general/asa-95-general-config/admin-swconfig.html#task_90917D0EBAC2427487F6F51D21ABC235
Solution
In order to perform the upgrade, the CLI needs to be changed from the default FTD mode to the Diagnostic mode. This is done with the use of command system support diagnostic-cli. This will bring back our old familiar Cisco CLI, where you can move up to the privileged mode with enable command. At this point, you are back in the process, able to perform the last required upgrade command, upgrade rommon. It will verify the file integrity, signature, confirm the configuration, and ask to reload it. The device will then reload twice, one to read the new code, then another to apply the new code, and finally reload to bring back the FTD alive.
On the 5506-X, this process took about 10 minutes. See below how it looks like.
Spoiler
Rom image verified correctly
Cisco Systems ROMMON, Version 1.1.12, RELEASE SOFTWARE
Copyright (c) 1994-2017  by Cisco Systems, Inc.
Compiled Wed 06/28/2017 14:36:11.63 by wchen64
Current image running: Boot ROM1
Last reset cause: PowerCycleRequest
DIMM Slot 0 : Present
INFO: Rommon upgrade state: ROMMON_UPG_START (1)
INFO: Reset code: 0x00002000
Firmware upgrade step 1...
Looking for file 'disk0:asa5500-firmware-1114.SPA'
Located 'asa5500-firmware-1114.SPA' @ cluster 99075.
Image base 0x7700a018, size 9241408
LFBFF signature verified.
Objtype: lfbff_object_rommon (0x800000 bytes @ 0x7700a238)
Objtype: lfbff_object_fpga (0xd0100 bytes @ 0x7780a258)
INFO: FPGA version in upgrade image: 0x0204
INFO: FPGA version currently active: 0x0204
INFO: The FPGA image is up-to-date.
INFO: Rommon version currently active: 1.1.12.
INFO: Rommon version in upgrade image: 1.1.14.
Active ROMMON: Preferred 1, selected 1, booted 1
Switching SPI access to standby rommon 0.
Please DO NOT reboot the unit, updating ROMMON...................
INFO: Duplicating machine state......
Reloading now as step 1 of the rommon upgrade process...
Toggling power on system board...
Last reset cause: RP-Reset
INFO: Reset code: 0x00000008
Firmware upgrade step 2...
Detected current rommon upgrade is available, continue rommon upgrade process
Rommon upgrade reset 0 in progress
Reloading now as step 2 of the rommon upgrade process...
Cisco Systems ROMMON, Version 1.1.14, RELEASE SOFTWARE
Copyright (c) 1994-2018  by Cisco Systems, Inc.
Compiled Tue 06/05/2018 22:45:19.61 by builder
Current image running: *Upgrade in progress* Boot ROM0
Last reset cause: BootRomUpgrade
INFO: Reset code: 0x00000010
PROM B: stopping boot timer
Active ROMMON: Preferred 1, selected 1, booted 0
INFO: Rommon upgrade state: ROMMON_UPG_TEST
!! Please manually or auto boot ASAOS now to complete firmware upgrade !!
Erwan LE BIHAN
Should be integrated into the RomMon Upgrade Procedure as the documentation only covers Upgrade from ASA.
rboersma
In 6.3, the FTD copy command doesn't work (https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn57678), and using copy within the diagnostic CLI doesn't work because it doesn't have any interfaces or routing. So I'm stuck trying to upgrade ROMMON using FTD, vs. having to reimage to ASA, upgrade ROMMON, and then reimage back to FTD. I don't think it would be appropriate to tell customers to go into expert mode and copy in linux. Copying from ROMMON won't work. [actually it does work to copy from the diagnostic CLI if you have a data interface configured.]
GrapeafterEbc
Happy to hear that! Your comment made mine.
rboersma
Revision: You can copy from within the diagnostic CLI if you have a data interface configured (either Diagnostic or a regular data interface). I don't know why it wasn't working for me initially (deployment error, maybe).
aktiviswz
@HQuest wrote:
Symptoms
Diagnosis
Solution
In order to perform the upgrade, the CLI needs to be changed from the default FTD mode to the Diagnostic mode. This is done with the use of command system support diagnostic-cli. This will bring back our old familiar Cisco CLI, where you can move up to the privileged mode with enable command. At this point, you are back in the process, able to perform the last required upgrade command, upgrade rommon. It will verify the file integrity, signature, confirm the configuration, and ask to reload it. The device will then reload twice, one to read the new code, then another to apply the new code, and finally reload to bring back the FTD alive. Sonic Survey
Spoiler
Thank you for sharing superb informations. Your website is very cool. I’m impressed by the details that you have on this website.
