wavelogix
hi , i facing issues on ASA5515-X with 9.1(2) version, i am not able the built tunnel from client router 881-sec-k9. additionally i am not able ping 8.8.8.8 from my internal desktop which connected gig 0/1, can some one help please
attached both ASA and router show run
regards
sathees
Eurosigma
I had the same problem, I think. Did you try to browse the internet from your PC?
If yes, maybe you're missing a policy that allows the pings to go through. That's what happened to me. This worked for me:
policy-map global_policy
class inspection_default
inspect icmp
end
