TCC_2
Level 10
Level 10
Core issue
No crypto debugs appear when trying to initiate the tunnel. IPSec worked before adding generic routing encapsulation (GRE) to the configuration.
Resolution
To add GRE to a working IPSec configuration, follow these steps.
  1. Remove the crypto map from the interface.
  2. Create the tunnel interfaces.
    int tunnel
    ip address private_ip subnet_mask
    tunnel source outside_interface_name
    tunnel destination peer_address
  3. Modify the crypto access list as shown below.
    access-list acl_name permit gre host tunnel_source_ip host peer_address
  4. Use routing protocol or configure a static route for the remote LAN with the next hop pointing to the tunnel interface.
  5. Reapply the crypto map to the physical interface and the tunnel interface.
For more information, including a sample configuration, see Configuring Router-to-Router IPSec (Pre-shared Keys) on GRE Tunnel with CBAC and NAT.
Cisco IOS Software Version
12.2
12.0
12.1
VPN Tunnel End Points
Router
