Yadhu Tony
Level 4
Level 4
<P style="TEXT-ALIGN: left; CLEAR: both" mcestyle="text-align: left; clear: both;">The Cisco IOS Zone Based firewall is one the most advanced form of Stateful firewall used in the Cisco IOS devices. The Zone Based Firewall is the successor of Classic IOS firewall or CBAC (Context-Based Access Control). Cisco first implemented the router-based stateful firewall in CBAC where it used ip inspect command to inspect the traffic in layer 4 and layer 7.
<DIV style="TEXT-ALIGN: left" mcestyle="text-align: left;">
Even though ASA devices are considered as the dedicated firewall device, Cisco integrated the firewall functionality in the router which in fact will make the firewall a cost effective device. The Zone Based firewall replaces the CBAC by introducing many features in its firewall functionality. The ZBF mainly deals with the security zones, where we can put the interfaces into various security zones and control the traffic between the zones.
<DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in" align=left mcestyle="font-style: normal; margin-bottom: 0in;">
Comparison chart of ZBF & CBAC
<TD style="BORDER-BOTTOM: #000000 1px solid; BORDER-LEFT: #000000 1px solid; PADDING-BOTTOM: 0.04in; PADDING-LEFT: 0.04in; PADDING-RIGHT: 0in; BORDER-TOP: #000000 1px solid; BORDER-RIGHT: medium none; PADDING-TOP: 0.04in" width=310 mcestyle="border-bottom: #000000 1px solid; border-left: #000000 1px solid; padding-bottom: 0.04in; padding-left: 0.04in; padding-right: 0in; border-top: #000000 1px solid; border-right: medium none; padding-top: 0.04in;">
CBAC
<TD style="BORDER-BOTTOM: #000000 1px solid; BORDER-LEFT: #000000 1px solid; PADDING-BOTTOM: 0.04in; PADDING-LEFT: 0.04in; PADDING-RIGHT: 0.04in; BORDER-TOP: #000000 1px solid; BORDER-RIGHT: #000000 1px solid; PADDING-TOP: 0.04in" width=302 mcestyle="border: #000000 1px solid; padding: 0.04in;">
Zone Based Firewall
<TD style="BORDER-BOTTOM: #000000 1px solid; BORDER-LEFT: #000000 1px solid; PADDING-BOTTOM: 0.04in; PADDING-LEFT: 0.04in; PADDING-RIGHT: 0in; BORDER-TOP: medium none; BORDER-RIGHT: medium none; PADDING-TOP: 0in" width=310 mcestyle="border-bottom: #000000 1px solid; border-left: #000000 1px solid; padding-bottom: 0.04in; padding-left: 0.04in; padding-right: 0in; border-top: medium none; border-right: medium none; padding-top: 0in;">
Controls inbound & outbound access on an interface
<TD style="BORDER-BOTTOM: #000000 1px solid; BORDER-LEFT: #000000 1px solid; PADDING-BOTTOM: 0.04in; PADDING-LEFT: 0.04in; PADDING-RIGHT: 0.04in; BORDER-TOP: medium none; BORDER-RIGHT: #000000 1px solid; PADDING-TOP: 0in" width=302 mcestyle="border-bottom: #000000 1px solid; border-left: #000000 1px solid; padding-bottom: 0.04in; padding-left: 0.04in; padding-right: 0.04in; border-top: medium none; border-right: #000000 1px solid; padding-top: 0in;">
Controls Bidirectional access between zones.
Uses inspect statements and stateful ACLs
Uses C3PL Configuration language
Support from IOS Release 11.2
Support from IOS Release 12.4(6)
<P style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; FONT-WEIGHT: normal; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; font-weight: normal; text-decoration: none;">
<DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; FONT-WEIGHT: normal; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; font-weight: normal; text-decoration: none;">
When you first look at the ZBF configuration you would think it is complex and difficult. But once you understand the actual concept behind the configuration everything seems to be easy for you. Here I am going to divide the full configuration into different logical sets and finally combine all those sets to get the full configuration.
ZBF Configuration Tasks
<P style="TEXT-ALIGN: left" mcestyle="text-align: left;">
<DIV style="MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="margin-bottom: 0in; text-decoration: none;">
We can configure a Zone Based Firewall by accomplishing the below tasks:
Configure zones.
Assign Router Interfaces to zones
Create zone pairs
Configure Interzone Access Policy
<DIV style="MARGIN-BOTTOM: 0in; FONT-WEIGHT: normal; TEXT-DECORATION: none" align=left mcestyle="margin-bottom: 0in; font-weight: normal; text-decoration: none;">
Which Include:
Class Maps
Policy Maps
    5. Apply policy maps to zone pairs
    Network Diagram
    I am using the below diagram as a reference to configure Zone Based Firewall :
    <IMG class="jive-image-thumbnail jive-image" alt="zbf_ntwrk_dgm (2).jpg" src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108592/zbf_ntwrk_dgm%282%29.jpg" width=620 mcesrc="/servlet/JiveServlet/downloadImage/108592/zbf_ntwrk_dgm%282%29.jpg" __jive_id="108592" __jive_ID="108592">
    Here I am defining three zones i.e Inside zone, Outside zone and DMZ zone.
    Below is the rule set for our ZBF:
    1. From Inside to Outside -http, tcp, udp, icmp and pop3 is allowed
    2. From Outside to Inside -icmp is allowed
    3. From Inside to DMZ -http, tcp and icmp is allowed
    4. From Outside to DMZ -only HTTP is allowed.
    Before going to the configuration you have to understand the default rule of communication between the zones:
    <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    Interzone (Between two zones) communication – Denied by default
    Intrazone communication (Inside a zone) – Allowed by default
    Task 1: Configure zones
    We have to configure three zones. Inside , Outside , DMZ
    INSIDE Zone - This is the zone where my LAN is located
    OUTSIDE Zone – This is the zone where the router is connected to the Internet
    DMZ Zone – Company's DMZ zone.
    Connect the router via console or putty and switch to the global configuration mode and type the command as below :
    Router(config)#zone security INSIDE
    Router(config)#zone security OUTSIDE
    Router(config)#zone security DMZ
    <IMG class="jive-image-thumbnail jive-image" alt=zbf1.JPG src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108602/zbf1.JPG" width=620 mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108602/zbf1.JPG" __jive_id="108602" __jive_ID="108602">
    Now we got three zones in our firewall.
    Task 2 :Assign Router Interfaces to zones
    Now we have to assign the router's interface to a particular zone.Here I am going to assign Gigabyte Ethernet 0/0 (LAN interface) to INDISE zone , Ge0/1 to OUTSIDE zone and Ge0/2 to DMZ zone.
    For this we have to go to the particular interface and attach the interface to the zone.Type the command below to achieve this:
    Router(config)#interface gigabitEthernet 0/0
    Router(config-if)#zone-member security INSIDE
    Router(config)#interface gigabitEthernet 0/1
    Router(config-if)#zone-member security OUTSIDE
    Router(config)#interface gigabitEthernet 0/2
    Router(config-if)#zone-member security DMZ
    <IMG class=jive-image alt=zbf2.JPG src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108603/zbf2.JPG" mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108603/zbf2.JPG" __jive_id="108603" __jive_ID="108603">
    Task 3: Create zone pairs
    Zone pairs are created to connect the zones. If you want to make two zones to communicate you have to create zone pairs.
    DO NOT create zone pairs for non-communicating zones.
    Here the communication is happening between:
    INSIDE to OUTSIDE
    OUTSIDE to INSIDE
    OUTSIDE to DMZ
    INSIDE to DMZ
    So we need to create four zone pairs. The command is as follows:
    Router(config)#zone-pair security IN-TO-OUT source INSIDE destination OUTSIDE
    Router(config)#zone-pair security OUT-TO-IN source OUTSIDE destination INSIDE
    Router(config)#zone-pair security OUT-TO-DMZ source OUTSIDE destination DMZ
    Router(config)#zone-pair security IN-TO-DMZ source INSIDE destination DMZ
    Router(config)#exit
    <IMG class="jive-image-thumbnail jive-image" alt=zbf3.JPG src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108604/zbf3.JPG" width=634 height=86 mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108604/zbf3.JPG" __jive_id="108604" __jive_ID="108604">
    Task 4: Configure Interzone Access Policy
    The interzone access policy is the key part of the zone based firewall where we configure layer 3 & layer 4 access policies.
    In this step we will create Class Maps and Policy Maps.
    <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; FONT-WEIGHT: normal; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; font-weight: normal; text-decoration: none;"> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; FONT-WEIGHT: normal; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; font-weight: normal; text-decoration: none;">
    Class Map Configuration
    Class map will group the traffic into different categories. In our situation we have to create class maps for all the traffic between the zones.
    Here I am going to create the ACL and associate it with the class maps. The ACL will decide the interesting traffic.
    <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;"> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;"> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    Class Map for INSIDE-TO-OUTSIDE
    Router(config)#ip access-list extended INSIDE-TO-OUTSIDE
    Router(config-ext-nacl)#permit tcp 172.17.0.0 0.0.255.255 any eq www
    Router(config-ext-nacl)#permit tcp 172.17.0.0 0.0.255.255 any eq echo
    Router(config-ext-nacl)#permit tcp 172.17.0.0 0.0.255.255 any eq pop3
    Router(config)#class-map type inspect match-all INSIDE-TO-OUTSIDE-CLASS
    Router(config-cmap)#match access-group name INSIDE-TO-OUTSIDE
    Class Map for OUTSIDE-TO-INSIDE
    Router(config)#ip access-list extended OUTSIDE-TO-INSIDE
    Router(config-ext-nacl)#permit tcp any 172.17.0.0 0.0.255.255 eq echo
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;">Router(config)#class-map type inspect match-all OUTSIDE-TO-INSIDE--CLASS</STRONG></SPAN></P></DIV> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;">Router(config-cmap)#match access-group name OUTSIDE-TO-INSIDE</STRONG></SPAN></P></DIV> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    Class Map for OUTSIDE-TO-DMZ
    Router(config)#ip access-list extended OUTSIDE-TO-DMZ
    Router(config-ext-nacl)#permit tcp any 192.168.1.0 0.0.0.255 eq www
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;">Router(config)#class-map type inspect match-all OUTSIDE-TO-DMZ--CLASS</STRONG></SPAN></P> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;"> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;">Router(config-cmap)#match access-group name OUTSIDE-TO-DMZ
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;">Class Map for INSIDE-TO-DMZ</STRONG></SPAN></P> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    Router(config)#ip access-list extended INSIDE-TO-DMZ
    Router(config-ext-nacl)#permit tcp 172.17.0.0 0.0.255.255 192.168.1.0 0.0.0.255 eq www
    Router(config-ext-nacl)#permit tcp 172.17.0.0 0.0.255.255 192.168.1.0 0.0.0.255 eq echo
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;">Router(config)#class-map type inspect match-all INSIDE-TO-DMZ--CLASS
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;">Router(config-cmap)#match access-group name INSIDE-TO-DMZ
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;"><STRONG style="COLOR: #000000" mcestyle="color: #000000;"><IMG class=jive-image alt=zbf4.JPG src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108605/zbf4.JPG" mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108605/zbf4.JPG" __jive_id="108605" __jive_ID="108605">
    <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; FONT-WEIGHT: normal; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; font-weight: normal; text-decoration: none;"> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;"> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;"><STRONG style="COLOR: #000000" mcestyle="color: #000000;"><STRONG style="COLOR: #000000" mcestyle="color: #000000;"><STRONG style="COLOR: #000000" mcestyle="color: #000000;"><IMG class="jive-image-thumbnail jive-image" alt=zbf5.JPG src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108606/zbf5.JPG" width=620 mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108606/zbf5.JPG" __jive_id="108606" __jive_ID="108606"></STRONG></STRONG></STRONG></STRONG></STRONG></SPAN></P> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in" align=left mcestyle="font-style: normal; margin-bottom: 0in;">
    Policy Map Configuration
    <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;"> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in" align=left mcestyle="font-style: normal; margin-bottom: 0in;">
    Now we are going to define the firewall rules for the above mentioned class maps. We can apply three rules to the traffic which is classified in class maps. i.e 1.)Inspect 2.)Drop 3.)Pass
    Inspect : This will inspect the traffic in a bidirectional manner
    Drop : This will drop the packets
    Pass : This will simply pass the packet.
    During the Policy Map configuration we have to attach the corresponding class-map with the policy-map and create a rule for the particular traffic (Inspect,Drop or Pass)
    There will be a drop policy, by default ,at the end of all policy maps.
    Policy Map for INSIDE-TO-OUTSIDE
    Router(config)#policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
    Router(config-pmap)#class type inspect INSIDE-TO-OUTSIDE-CLASS
    Router(config-pmap-c)#inspect
    Router(config-pmap)#class class-default
    Router(config-pmap-c)#drop log
    Policy Map for OUTSIDE-TO-INSIDE
    Router(config)#policy-map type inspect OUTSIDE-TO-INSIDE-POLICY
    Router(config-pmap)#class type inspect OUTSIDE-TO-INSIDE-CLASS
    Router(config-pmap-c)#pass
    Policy Map for OUTSIDE-TO-DMZ
    Router(config)#policy-map type inspect OUTSIDE-TO-DMZ-POLICY
    Router(config-pmap)#class type inspect OUTSIDE-TO-DMZ-CLASS
    Policy Map for INSIDE-TO-DMZ
    Router(config)#policy-map type inspect INSIDE-TO-DMZ-POLICY
    Router(config-pmap)#class type inspect INSIDE-TO-DMZ-CLASS
    <IMG class="jive-image-thumbnail jive-image" alt=zbf6.JPG src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108607/zbf6.JPG" width=620 mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108607/zbf6.JPG" __jive_id="108607" __jive_ID="108607"></STRONG></SPAN></P> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    Task 5: Apply policy maps to zone pairs
    Now we have to attach the policy maps to the zone pairs that we have already created using the service-policy command.
    Router(config-sec-zone-pair)#service-policy type inspect INSIDE-TO-OUTSIDE-POLICY
    Router(config-sec-zone-pair)#service-policy type inspect OUTSIDE-TO-INSIDE-POLICY
    Router(config-sec-zone-pair)#service-policy type inspect OUTSIDE-TO-DMZ-POLICY
    Router(config-sec-zone-pair)#service-policy type inspect INSIDE-TO-DMZ-POLICY
    <STRONG style="COLOR: #000000" mcestyle="color: #000000;"><IMG class="jive-image-thumbnail jive-image" alt=zbf7.JPG src="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108608/zbf7.JPG" width=620 height=81 mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/108608/zbf7.JPG" __jive_id="108608" __jive_ID="108608"></STRONG></STRONG></STRONG></SPAN></P></DIV></DIV> <DIV style="FONT-STYLE: normal; MARGIN-BOTTOM: 0in; TEXT-DECORATION: none" align=left mcestyle="font-style: normal; margin-bottom: 0in; text-decoration: none;">
    This is all about the basic configuration of a Zone-Based Policy Firewall.
    <STRONG style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;">Troubleshooting
    Here I am mentioning some basic verification and troubleshooting commands :
    # show class-map type inspect
    #show policy-map type inspect
    #show zone-pair security
    Now you can deploy the Zone Based Firewall in your environment and test it.
    For more information you can visit the Cisco website : <A href="http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_zbf/configuration/15-1s/sec-zone-pol-fw.html" rel=nofollow mcehref="http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_zbf/configuration/15-1s/sec-zone-pol-fw.html">http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_zbf/configuration/15-1s/sec-zone-pol-fw.html
