In case we see the error message Internal Error 2738 follow these steps:
1. Run a command prompt in administrator mode (Start/All Programs/Accessories/ right click on Command Prompt, select Run As Administrator)
2. type: cd %systemroot%\system32
3. type: regsvr32 vbscript.dll Now try installing the client in admin mode on Windows 7. If the same error pops up again use the following:
a. Click on the Start menu, choose Run, type cmd and click OK
b. To unregister the VBScript engine, run this command: reg delete “HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}” /f
c. type: regsvr32 vbscript.dll
The idea behind the above steps is the error code 2738. This error code pops up when the installer uses VBSCRIPT and cannot find the VBScript engine to parse it. The installer
should be able to find it normally as the VBScript Engine is registered and running with the OS. But with Windows VISTA and Windows 7 for some reason the VBScript engine is not
registered or it is registered under the HKCU in the windows registry. We need to unregister it from there(done by removing registry entry) and re-register it under HKLM
(done by command regsvr32 vbscript.dll).
On Vista or Windows 7 or any OS the engine used is specified by the installer for the software. The installer can be written in VBScript or JAVA Script. Every Script running on
Windows uses a WSH(Windows Scripting Host). For VBScript VBscript engine is used and similarly for JAVA Script Java Script engine is used. Here we got the error message 2738
which determined the problem to be with VB Script engine. In case the problem was with JAVA Script engine the error code is 2739.
In case we see the error message Internal Error 2739 follow these steps:
3. type: regsvr32 jscript.dll Now try installing the client in admin mode on Windows 7. If the same error pops up again use the following:
b. To unregister the JScript engine, run this command: reg delete “HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{F414C260-6AC0-11CF-B6D1-00AA00BBBB58}” /f (can do it manually also)
c. type: regsvr32 jscript.dll
