Hello All,
Recently I got an opportunity to perform POC with Cisco ISE (2.7 Patch 4) and Juniper EX 2300 switch to perform 802.1x EAP-FAST (machine + user) authentication followed by Posture Assessment on Windows 10 Machines (installed with AnyConnect 4.9 NAM , Posture and compatible compliance module)
I was able to perform all the requirements of client successfully.
Most challenging part of to achieve seamless posture assessment using dynamic URL redirect.
Attaching the document which can guide everyone to configure the same. Hope it helps.
Also attaching Cisco switch template for reference.
Mitesh Manwatkar
