Jason Kunst
This document goes over the purpose, information and installation of the Anyconnect Network Visibility (NVM) Collector.
CESA for Splunk
Cisco AnyConnect Network Visibility Module (NVM) App for Splunk is comprised of three components:
* The Splunk App with pre-designed Dashboards to visualize and view the data.
* The Splunk Add-on which provides data indexing and formatting inside Splunk Enterprise.
* The NVM Collector Component which is responsible for collecting and translating all IPFIX (nvzFlow) data from the endpoints and forwarding it to the Splunk Add-on.
This is a manually installed component that runs on 64-bit Linux.
Your options for install is to put on an existing system (there is a guide posted to the bottom of CESA POV page), on a separate linux or docker machine.
This document also talks about the collector install and configuration options.
Support
For more information on the solution access the following links:
Proof of Value - this page goes over everything to know about CESA, solution, sales, licensing, design, etc - http://cs.co/cesa-pov
CESA guide - this page goes through all the dashboard elements of CESA-splunk and the necessary - http://cs.co/cesa-guide
  • For first time engagement and for POV/Trial please reach out to your account team before installation
  • For first-line technical support on the CESA solution (Anyconnect, NVM module, NVM collector and CESA dashboard), please reach out to Cisco TAC and/or Cisco Account team. If the account team is new to the product, they are able to reach out to cesa-pov@cisco.com for help with the deployment
  • If there are specific questions about CESA specifically (for account teams) please email - cesa-pov@cisco.com.
  • For specific questions around the collector, design enhancements and technical details please reach out to  nvzFlow@cisco.com.
NVM Collector
Install
Techzone install article
The collector runs on 64-bit Linux. For compatibility with other platforms, please see Docker Installation section below. CentOS and Ubuntu configuration scripts are included. The CentOS install scripts and configuration files can also be used in Fedora and Redhat distributions as well.
 The collector should be run on either a standalone 64-bit Linux system or on a 64-bit Splunk Forwarder.
The collector is packaged with the Cisco NVM Technology Add-On for Splunk. In order to install the collector you will need to copy the application in the acnvmcollector.zip file from, located in the $APP_DIR$/appserver/addon/ directory to the system you plan to install it on.
Extract the tar file on the system where you plan to install the collector on and execute the install.sh script with super user privileges.
It is recommended to read the $PLATFORM$_README file in the .zip bundle before executing the install.sh script. The $PLATFORM$_README file provides information on the relevant configuration settings that need to be verified and modified (if necessary) before the install.sh script is executed. Failing to do so can cause the collector to not function accordingly.
NOTE: Check if the collector is running
A collector can handle a minimum of 5000 flows per second on a properly sized system.
Upgrade
Do the same as install, it will overwrite existing, and then after upgraded validate the version
To find the collector version run with -v flag
  • ./opt/acnvm/bin/acnvmcollector -v
/opt/acnvm/bin
[root@splunk-virtual-machine bin]# ./acnvmcollector -v
Cisco AnyConnect Network Visibility Module Collector (version 4.10.02086 release)
Copyright (C) 2004-2021 All Rights Reserved.
Configuration Options
The collector needs to be configured and running before the Splunk App can be used. By default, the collector receives flows from AnyConnect NVM endpoints on UDP port 2055.
Additionally, the collector produces three data feeds for Splunk, Per Flow Data, Endpoint Identity Data and Endpoint Interface Data, on UDP ports 20519, 20520 and 20521 respectively.
Both the receive and data feed ports can be changed by altering the acnvm.conf file and restarting the collector instance.
Make sure that any network firewalls between endpoints and the collector or between the collector and Splunk system(s) are open for the configured UDP ports.
Also ensure that your AnyConnect NVM configuration matches your collector configuration. Refer to the AnyConnect Administration Guide for more information.
The Splunk App is NOT configured by default to receive data, however the inputs.conf file contains an example of three data feeds that are disabled, Per Flow Data, Endpoint Identity Data and Endpoint Interface Data, on UDP ports 20519, 20520 and 20521 respectively.
To enabled these feeds change the settings inputs.conf file to remove the commented out default connections.
Collector Enhancements
In addition to Ubuntu and CentOS install scripts, we have added Docker support so you can run the NVM Collector in a Docker Container.
We've also added the ability to tune the multi-core behavior of the NVM Collector as well as include/exclude filtering capability refer to the collector configuration help file in the Splunk App dashboard for more information.
The NVM Collector daemon now runs under a low rights user and group (acnvm) instead of a root process.
Finally, there is an SDK so that you can write your own streaming format. In addition to the built-in syslog format, we include an Apache Kafka C++ sample plugin to get you started.
Docker Installation
CiscoNVMCollector_TA.zip includes a Dockerfile that can be used to build a Docker image for the collector. Before building, first make any configuration adjustments (as needed) to acnvm.conf.
Build docker image from the directory containing Dockerfile:
docker build -t nvmcollector .
Parameters for running the docker image depends on your acnvm.conf file. For the default config where collector listens on port 2055 and the syslog server is on the same host:
docker run -t -p 2055:2055/udp --net="host" nvmcollector
Detailed Configuration and Operation
Concurrency
By default when running on a host with multiple cores, the collector takes advantage of by creating a separate server process per core. This parallelizes IPFX processing. This configuration can be tuned using the "multiprocess" dictionary inside of the main collector config file.
To disable multiprocessing (force a single process):
    "multiprocess":
        {"enabled": false}
To force 2 server processes:
    "multiprocess":
            "enabled": true,
            "numProcesses": 2
Filtering Flows
Collector supports three optional flow filtering modes- inclusion mode (whitelist), exclusion mode (blacklist), and hybrid. Filtering is defined in a separate JSON policy file. The policy file path could be specified when starting the collector. By default, the collector will look for policy stored in this file:
/etc/acnvmfilters.conf
If no policy exists, filtering is disabled and all flows will be processed and exported. The three filtering modes operates as follows:
  • Include Only (whitelist) - By default, a flow is dropped unless it matches an include rule.
  • Exclude Only (blacklist) - By default, a flow is collected unless it matches an exclude rule.
  • Include + Exclude (hybrid) - By default, a flow is dropped unless it matches an include rule AND it does not match an exclude rule.
Each rule is specified as a JSON dictionary, with each key/value pair specifying a match criteria on a flow field (whose name matches the key). Suffix wildcards are supported for string field types and is denoted by a *.
Sample: Exclude all DNS flows:
  "rules":
        "exclude":
            {"dp": 53, "pr": 17}
Sample: Exclude flows to certain DNS servers:
  "rules":
        "exclude":
            {"dp": 53, "pr": 17, "da": "1.2.*"},
            {"dp": 53, "pr": 17, "da": "8.8.8.8"}
Sample- Only collect flows from Angry Birds (Android app), but ignore DNS flows:
  "rules":
        "include":
          {"pname": "com.rovio.angrybirds"}
        "exclude":
Additional Exporters
The collector exporter currently supports Splunk (syslog). There is also limited support for Kafka. To request additional support, please contact: nvzflow@cisco.com
Export behavior can be configured in the main configuration file.
Sample Splunk (syslog) Export Configuration
  "exporter": {
        "type": "syslog",
        "syslog_server": "localhost",
        "flow_port": 20519,
        "endpoint_port": 20520,
        "interface_port": 20521
Sample Kafka Export Configuration
  "exporter": {
        "type": "kafka",
        "bootstra_server": "localhost:9092",
        "flow_port": "flow",
        "endpoint_port": "endpoint",
        "interface_port": "interface"
Implementing Your Own Exporter as a Plugin
The collector's export capability can be extended using native C++ code by building a shared library against the plugin API. The SDK bundle (including headers and sample) is located in the Splunk app bundle in addon directory: CiscoNVM/appserver/addon. For questions, please contact: please contact: nvzflow@cisco.com
To use your custom plugin, a special configuration is required in the main collector config:
    "exporter": {
        "type": "plugin"
Data Model and Correlation Index
The following diagram depicts the relationship between the three data sources, Per Flow, Endpoint Identity, and Interface Info. The UDID field is used as a means of correlating records between these sources.
NVM Collector Syslog Fields
NOTE: The "Source" entry below indicates which Splunk sourcetype(s) it is found in:
cisco:nvm:flowdata, cisco:nvm:sysdata, cisco:nvm:ifdata
Search Key Key Name Source Key Description
udid UDID
cisco:nvm:flowdata
cisco:nvm:sysdata
cisco:nvm:ifdata
unique identifier for each end point in the network. This is derived and recreated from hardware attributes. It is used to correlate records back to a single source. Note that this matches the same value sent by AnyConnect VPN to an ASA.
osn OSName cisco:nvm:sysdata Name of the Operating System on the endpoint (e.g. WinNT). Note that this matches the same value sent by AnyConnect VPN to an ASA.
osv OSVersion cisco:nvm:sysdata Version of the operating system on the endpoint(e.g. 6.1.7601). Note that this matches the same value sent by AnyConnect VPN to an ASA.
vsn VirtualStationName cisco:nvm:sysdata Device name configured on the endpoint (e.g. Boris-Macbook).
Domain joined machines will be in the form [machinename].[domainname].[com] (e.g. CESA-WIN10-1.mydomain.com)
sm SystemManufacturer cisco:nvm:sysdata Endpoint Manufacturer (e.g. Lenovo, Apple, etc.).
st SystemType cisco:nvm:sysdata Endpoint Type (e.g. x86, x64).
agv AgentVersion cisco:nvm:sysdata Software version of the agent/client software. Typically of the form major_v.minor_v.build_no. [AnyConnect NVM 4.9 or later]
liuid LoggedInUser cisco:nvm:flowdata The logged in username on the physical device, in the form Authority\Principal, on the endpoint from which the network flow is generated.
Note that a domain user is in the same form as a user locally logged in to a machine.
e.g. MYDOMAIN\aduser or SOMEMACHINE\localuseracct
NOTE: If this field is empty, it indicates that either no user was not logged into the device,
or a user remotely logged in to the device via RDP, SSH, etc. liuida and liuidp fields would also be empty as a result.
User information can still be derived from the process account (pa) information (see below for more information).
liuida LoggedInUserAuthority cisco:nvm:flowdata The Authority portion of the logged in username on the physical device from which the network flow is generated.
liuidp LoggedInUserPrincipal cisco:nvm:flowdata The Principal portion of the logged in username on the physical device from which the network flow is generated.
fss StartSeconds cisco:nvm:flowdata Time stamp of when the network flow was initiated by the endpoint. see timestamp notes below for details
fes EndSeconds cisco:nvm:flowdata Time stamp of when the network flow was completed by the endpoint. see timestamp notes below for details
sa SourceIPv4Address cisco:nvm:flowdata IPv4 address of the interface from where the flow was generated on the endpoint.
da DestinationIPv4Address cisco:nvm:flowdata IPv4 address of the destination to where the flow was generated from the endpoint.
sa6 SourceIPv6Address cisco:nvm:flowdata IPv6 address of the interface from where the flow was generated on the endpoint.
da6 DestinationIPv6Address cisco:nvm:flowdata IPv6 address of the destination to where the flow was generated from the endpoint.
sp SourceTransportPort cisco:nvm:flowdata Source port number from where the flow was generated on the endpoint.
dp DestinationTransportPort cisco:nvm:flowdata Destination Port number to where the flow was generated from the endpoint.
ibc InBytesCount cisco:nvm:flowdata The total number of Bytes downladed during a given flow on the endpoint at layer 4, not including L4 headers.
obc OutBytesCount cisco:nvm:flowdata The total number of Bytes uploaded during a given flow on the endpoint at layer 4, not including L4 headers.
pr ProtocolIdentifier cisco:nvm:flowdata Network Protocol number associated with each flow. For now we only support TCP (6) and UDP(17).
ph ProcessHash cisco:nvm:flowdata Unique SHA256 hash for the executable generating the Network Flow on the endpoint.
pa ProcessAccount cisco:nvm:flowdata The fully qualified account, in the form Authority\Principal, under whose context the application generating the Network Flow on the endpoint was executed.
pap ProcessAccountPrincipal cisco:nvm:flowdata The Principal portion of the fully qualified account under whose context the application generating the Network Flow on the endpoint was executed.
paa ProcessAccountAuthority cisco:nvm:flowdata The Authority portion of the fully qualified account under whose context the application generating the Network Flow on the endpoint was executed.
pn ProcessName cisco:nvm:flowdata Name of the executable generating the Network Flow on the endpoint.
pph ParentProcessHash cisco:nvm:flowdata Unique SHA256 hash for the executable of the parent process of the application generating the Network Flow on the endpoint.
ppa ParentProcessAccount cisco:nvm:flowdata The fully qualified account, in the form Authority\Principal, under whose context the parent process of the application generating the Network Flow on the endpoint was executed.
ppap ParentProcessAccountPrincipal cisco:nvm:flowdata The Principal portion of the fully qualified account under whose context the parent process of the application generating the Network Flow on the endpoint was executed.
ppaa ParentProcessAccountAuthority cisco:nvm:flowdata The Authority portion of the fully qualified account under whose context the parent process of the application generating the Network Flow on the endpoint was executed.
ppn ParentProcessName cisco:nvm:flowdata Name of the parent process of the application generating the Network Flow on the endpoint.
ds FlowDNSSuffix cisco:nvm:flowdata The DNS suffix configured on the network to which the user was connected to when the network flow was generated on the endpoint.
dh FlowDestinationHostName cisco:nvm:flowdata The Destination Domain of the Destination Address to where the network flow was sent to from the endpoint.
fv FlowVersion cisco:nvm:flowdata Network Visibility Flow (nvzFlow) version sent by the client.
mnl ModuleNameList cisco:nvm:flowdata List of 0 or more names of the modules hosted by the process that generated the flow. This can include the main DLLs in common containers such as dllhost, svchost, rundll32, etc. It can also contain other hosted components such as the name of the jar file in a JVM.
mhl ModuleHashList cisco:nvm:flowdata List of 0 or more SHA256 hashes of the modules associated with the nvzFlowModuleNameList
luat LoggedInUserAccountType cisco:nvm:flowdata Account type of the logged in user. As per the enumeration of AccountType, defined by this spec.
puat ProcessAccountType cisco:nvm:flowdata Account type of the process account. As per the enumeration of AccountType, defined by this spec.
ppuat ParentProcessAccountType cisco:nvm:flowdata Account type of the parent-process account. As per the enumeration of AccountType, defined by this spec.
fsms FlowStartMsec cisco:nvm:flowdata Time stamp (in msec) of when the network flow was initiated by the endpoint. [AnyConnect NVM 4.9 or later] see timestamp notes below for details
fems FlowEndMsec cisco:nvm:flowdata Time stamp (in msec) of when the network flow was completed by the endpoint. [AnyConnect NVM 4.9 or later] see timestamp notes below for details
pid ProcessId cisco:nvm:flowdata Process Id of the process that initiated the network flow. [AnyConnect NVM 4.9 or later]
ppath ProcessPath cisco:nvm:flowdata Filesystem path of the process that initiated the network flow. [AnyConnect NVM 4.9 or later]
parg ProcessArgs cisco:nvm:flowdata Command Line Arguments of the process that initiated the network flow. [AnyConnect NVM 4.9 or later]
ppid ParentProcessId cisco:nvm:flowdata Process Id of the parent of the process that initiated the network flow. [AnyConnect NVM 4.9 or later]
pppath ParentProcessPath cisco:nvm:flowdata Filesystem path of the parent of the process that initiated the network flow. [AnyConnect NVM 4.9 or later]
pparg ParentProcessArgs cisco:nvm:flowdata Command Line Arguments of the parent of the process that initiated the network flow. [AnyConnect NVM 4.9 or later]
iid InterfaceInfoUID
cisco:nvm:flowdata
cisco:nvm:ifdata
Unique ID for an interface meta-data. Should be used to lookup the interface meta-data from the InterfaceInfo records.
ii InterfaceIndex cisco:nvm:ifdata The index of the Network interface as reported by the OS.
it InterfaceType cisco:nvm:ifdata Interface Type, such as Wired, Wireless, Cellular, VPN, Tunneled, Bluetooth, etc. Enumeration of network types, defined by this spec.
in InterfaceName cisco:nvm:ifdata Network Interface/Adapter name as reported by the OS
ssid SSID cisco:nvm:ifdata Parsed from InterfaceDetailsList, this is the SSID portion, e.g. SSID=internet
ist Trust State cisco:nvm:ifdata Parsed from InterfaceDetailsList, this is the STATE portion, e.g. STATE=Trusted. This means either AnyConnect VPN is active or has determined the device is on a Trusted Network based on TND
im InterfaceMacAddress cisco:nvm:ifdata Mac address of the interface.
TIMESTAMP NOTES:
fss & fes provide seconds-accuracy, while fsms & fems provide milliseconds-accuracy. Both timestamp formats are sent to the NVM collector starting with version 4.9 of the client. If you are not interested in higher resolution timestamps and want to save bandwidth or storage, you can drop nvzFlowFlowStartMsec and nvzFlowFlowEndMsec in the AnyConnect NVM Data Collection Policy settings. Any of these fields can also be dropped at the NVM Collector using Filtering.
Enumerations
  • Interface Types
  • 1 - Wired Ethernet
  • 2 - Wireless (802.11)
  • 3 - Bluetooth
  • 4 - Token Ring
  • 5 - ATM (Slip)
  • 6 - PPP
  • 7 - Tunnel (generic)
  • 8 - VPN
  • 9 - Loopback
  • 10 - NFC
  • 15 - Unknown/Unspecified
  • Account Types
  • All Platforms
  • Unknown - 0x0000
  • Domain User - 0x8000 (Mask. 16th bit set for Domain user. Eg., a Domain-user administrator will have 0x8002 as the type).
  • Windows
    • Standard User - 0x0001
    • Admin User - 0x0002
    • Guest User - 0x0003
  • MacOS/Linux
    • Root user - 0x0004
    • Bit Representation
      • Bit 16 - Domain bit
      • Bit 15 - Reserved but not implemented yet
      • Bit 14 - Reserved but not implemented yet
      • Bits 13 through 9 - Reserved for future bit-masks
      • Bits 8 through 1 - Specific AccountType values
    SergGu
    Hello @Jason Kunst . Waht is the duration of time remove NVN AnyConnect module can buffer and store Cisco nvzFlow while the endpoint is not connected to the VPN?
    What is the best practice for NVN collectors? Would you recommend exposing it to the internet or keep inside the perimeter?
    The Install and Configure AnyConnect NVM 4.7.x or Later and Related Splunk Enterprise Components for CESA guide suggesting NVN has RFC1918 IP address.
