aijazbeigh
Level 2
Level 2
Thats great the. Can you please confirm if my understanding is correct.
1. I will assign ISE name as psn01
2. Use Ip domain name mydomain.com
3. Join ISE to my AD domain which is uk.group.local
And I can use public certificate from verisign with fqdn psn01.mydomain.com. and ISE will let me upload it.
aijazbeigh
Level 2
Level 2
I did the change but redirect url still shows with AD domain
https://ise.home.local:8443/guestportal/gateway?sessionId=14fe1cac000000018cc78251&action=cwa
I was it expecting to turn out to be like
https://ise.mycompany.com:8443/guestportal/gateway?sessionId=14fe1cac000000018cc78251&action=cwa
After I chnaged ip domain name mycompany.com
Any Clues.
Nicolas Darchis
your ISE still has a certificate issued to the old FQDN, this is why it's still returning the old name for CWA.
I suggest you open a discussion in the forum to discuss your issues rather than commenting on a document though.
scott3367
Community Member
Thank you. I have configured the central webauthentication sucessfully.
Scott
http://www.vmexplore.com
kapil.kumar
Community Member
Hi Nicolas,
thanks for this document, i have got my CWA working with user layer 3 vlan configured on the access switch but when i turn the layer 3 user vlan off  CWA doesnt work. would you please let me know if there is any particular setting i need to know.
i have also checked my firewall and all is allowed in firewall.
KK
