06-15-2015 06:15 AM - edited 03-08-2019 06:58 PM
For CSC Module version 6.6.1125.0, the latest HOTFIX is patch 1157. This brings a module up-to version 6.6.1125.0.1157 from any version of 6.6.1125.x. You can obtain the patch (csc_66_en_hfb1157.pkg) here:
https://dc1.safesync.com/LMcmmxjs/CSC-SSM/?a=-rAIk-XpkvI
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Trend Micro(TM) InterScan(TM) for Cisco Content Security and Control Security Services Module (CSC-SSM) 6.6 Hot Fix - Build 1157 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ NOTICE: This hot fix was developed as a workaround or solution to a customer-reported problem. As such, this hot fix has received limited testing and has not been certified as an official product update. Consequently, THIS HOT FIX IS PROVIDED "AS IS." TREND MICRO MAKES NO WARRANTY OR PROMISE ABOUT THE OPERATION OR PERFORMANCE OF THIS HOT FIX NOR DOES IT WARRANT THAT THIS HOT FIX IS ERROR FREE. TO THE FULLEST EXTENT PERMITTED BY LAW, TREND MICRO DISCLAIMS ALL IMPLIED AND STATUTORY WARRANTIES, INCLUDING BUT NOT LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, NONINFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. Contents =================================================================== 1. Hot Fix Release Information 1.1 Issues 1.2 Enhancements 1.3 Files Included in this Release 2. Documentation Set 3. System Requirements 4. Installation/Uninstallation 4.1 Installation 4.2 Uninstallation 5. Post-installation Configuration 6. Known Issues 7. Release History 8. Contact Information 9. About Trend Micro 10. License Agreement =================================================================== 1. Hot Fix Release Information ====================================================================== 1.1 Issues =================================================================== This hot fix resolves the following issue: Issue: If there is heavy network traffic or if FTP connections close unexpectedly while the FTP daemon receives data, it does not time out and thus, does not purge old temporary files. These files use up disk space. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix adds a timeout setting to the FTP daemon so that if it encounters heavy network traffic or if the FTP connections close unexpectedly while it is receiving data, the process times out and triggers the daemon to purge old temporary files. 1.2 Enhancements =================================================================== There are no enhancements for this hot fix. 1.3 Files Included in this Release =================================================================== A. Files for Current Issue ------------------------------------------------------------------- Filename Build No. ------------------------------------------------------------------- factory_default.tgz 1125 migrate.conf 1125 File for Issue ------------------------------------------------------------------- Filename Build No. ------------------------------------------------------------------- isftpd 1157 B. Files for Previous Issues ------------------------------------------------------------------- Filename Build No. ------------------------------------------------------------------- iwss-process 1148 httpsd 1134 libtmmsg.so 1128 issyslog 1129 issyslog.exe 1129 TmSmbGui.jar 1131 libisvwlib.so 1131 libhttpproxy.so 1135 IWSSPIScanVsapi.so 1133 setup.bin 1135 AuPatch 1140 libpatch.so 1140 libtmactupdate.so 1140 libciuas32.so 1140 cert5.db 1140 x500.db 1140 stargate_patch_apply.sh 1144 S01init_ISVW 1146 scheduled 1145 libtmau.so 1145 libhttpproxy.so 1148 httpsd 1155 2. Documentation Set ====================================================================== In addition to this readme.txt, the documentation set for this product includes the following: o Readme.txt -- basic installation, known issues, release history, and contact information o Installation Guide (IG) -- Provides product overview, deployment plan, installation steps and basic information intended to help you deploy InterScan for Cisco CSC SSM smoothly. o Administrator's Guide (AG) -- Provides post-installation instructions on how to configure the settings to help you get InterScan for Cisco CSC SSM "up and running." Also includes instructions on performing other administrative tasks for the day-to-day maintenance of InterScan for Cisco CSC SSM. o Online Help -- Context-sensitive help screens that provide guidance for performing a task. 3. System Requirements ====================================================================== Install this hot fix only on computers that meet the following requirements: - Platform: CSC SSM 10 or CSC SSM 20 - CSC Version: 6.6.1125.0. 4. Installation/Uninstallation ====================================================================== 4.1 Installation =================================================================== To install this hot fix: 1. Ensure that scheduled updates are disabled. 2. Log on to the CSC web console. 3. Click "Administration > Product Upgrade". 4. Select the hot fix package and upload it to the appliance. 5. After a few minutes, verify that the hot fix package has been uploaded to CSC. 6. Enable scheduled updates if you have disabled these in step 1. 4.2 Uninstallation =================================================================== To roll back to the previous build: 1. Log on to the CSC web console. 2. Click "Administration > Product Upgrade". 3. Under "Update number", click the name of the device you want to view. A summary screen appears showing the updates and related log information. 4. Click "Uninstall" to remove an update. 5. Post-installation Configuration ====================================================================== No post-installation steps are required. Note: Trend Micro recommends that you update your scan engine and virus pattern files immediately after installing this hot fix. 6. Known Issues ====================================================================== There are no known issues for this hot fix release. 7. Release History ====================================================================== InterScan for Cisco CSC SSM 6.6.1125.0, July 1, 2011 7.1 Prior Hot Fixes =================================================================== Note: Only the new hot fix was tested for this release. Prior hot fixes were tested at the time of their release. Hot Fix 1128 Issue: InterScan slightly modifies the "Received" email header after the CSC POP3 scans email messages. This issue causes the time format of the email messages to violate RFC 5322. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix resolves this issue. Hot Fix 1129 Issue: CSC may stop transferring violation events to Cisco ASDM preventing the "Cisco ASDM Content Security" tab from showing violation events. This issue occurs because the CSC syslog adaptor module runs into a dead loop when it attempts to handle URLs that exceed 1024 bytes. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix resolves this issue. Hot Fix 1131 Issue 1: When users make changes in the DNS setting on the CSC web console, the new setting does not take effect. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution 1: This hot fix enables the web console to restart automatically after users make changes to the DNS setting on the CSC web console. This ensures that the new setting takes effect immediately. Issue 2: For the SMTP content filter feature, the previous file type setting in the background configuration file could not be cleared correctly. This can cause CSC to block a file type other than the one specified in the configuration file on the web console. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution 2: This hot fix resolves this issue. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Procedure 2: To correct the previous SMTP content filter background configuration file: a. Log on to the CSC web console. b. Make and save the necessary changes to the content filter setting in the "Mail(SMTP) > Content-Filter > Filter attachments of following file types" field. This step enables the fix to take effect. After performing this step, any changes you make on the content filter setting will take effect immediately. Hot Fix 1132 Issue: When users access some HTTPS sites, the browser freezes for one to two minutes or displays browser/SSL errors if the HTTPS server closes the connection before the client downloads all the data. This issue occurs because the CSC-SSM does not properly close the connection with the client. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix resolves this issue by allowing CSC-SSM to properly close the connection with the client when the server closes the connection with CSC-SSM. Hot Fix 1133 Issue 1: The iwss process may cause the CSC module to stop unexpectedly. This issue can occur when the VSAPI module sends out a large number of nesting call statements which can lead to useless memory allocation and eventually cause the system to run out the memory. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution 1: This hot fix enables the VSAPI module to use simple character strings instead of the String class to reduce the unnecessary memory allocation. This resolves the issue. Issue 2: The URL filtering and URL blocking functions of the HTTPS module may stop working 30 minutes after starting. This issue occurs because the httpsd process encounters a data corruption issue which can cause it to stop unexpectedly and may trigger a core dump issue. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution 2: This hot fix prevents the core dump issue in the httpsd process to ensure that both the HTTPS URL filtering and URL blocking functions work properly. Issue 3: The VSAPI module requires CSC to change the "Accept-Encoding" header of an HTTP request from "gzip/deflate" to "Identity" which is the default value, before sending the HTTP request to the server. However, the actual encoding of the PDF file is "gzip". This mismatch can prevent Microsoft(TM) Internet Explorer(TM) 8 from downloading the file. This issue does not affect Mozilla(R) Firefox(R). ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution 3: This hot fix prevents CSC from changing the "Accept-Encoding" header of HTTP requests in clients that use Internet Explorer. Hot Fix 1134 Issue: The CSC module stops unexpectedly because of a null pointer in the commonUID module. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix prevents the commonUID module from calling the null pointer. Hot Fix 1135 Issue 1: When accessing a web site through CSC and the size of the header of the HTTP response exceeds 16 KB, the client will not be able to display the web page properly. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution 1: This hot fix increases the HTTP receiver buffer to enable CSC to process HTTP responses with headers that are larger than 16 KB. Issue 2: A related process can use up 100% of CPU resources while "setup.bin" runs. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution 2: This hot fix optimizes the handling method for terminated signals to ensure that it can efficiently handle terminated signals and that the affected process can close successfully. Hot Fix 1140 Issue: The ActiveUpdate module for Stargate supports "root signed" certificates only. However, "root signed" certificates will expire by March 2015. By that time, every SSL server certificate must be issued by an intermediate CA. Since the ActiveUpdate module does not support intermediate CA certificates, all ActiveUpdate updates will eventually fail. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix updates the ActiveUpdate module to enable CSC to support intermediate CA certificates. Hot Fix 1144 Issue: Updates may not complete because there is not enough disk space in "/opt/trend/isvw/lib/mail" and ActiveUpdate uses this folder for updates. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix transfers the ActiveUpdate folder to another location to ensure that it has enough disk space to perform updates successfully. Hot Fix 1145 Issue: Sometimes, a copy file error appears after a successful antispam pattern update. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix prevents the copy file error from appearing after a successful antispam pattern update. Hot Fix 1146 Issue: Sometimes, Virus Scan Engine updates fail because the backup file is missing. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix creates the missing backup file in affected computers to ensure that the Virus Scan Engine can be updated successfully. Hot Fix 1147 Issue: Sometimes, CSC cannot decode URLs that contain special characters because it cannot parse these URLs correctly. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix enables CSC to parse URLs with special characters to ensure that it can successfully decode these URLs. Hot Fix 1148 Issue: When users access a web site through CSC, the client may not be able to display the web page properly. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix enables clients to display web pages properly. Hot Fix 1155 Issue: An array overflow issue triggers the iwss process to stop unexpectedly and generate core dump files while parsing certain URLs. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Solution: This hot fix resolves the issue so users can access the affected web sites normally. 8. Contact Information ====================================================================== A license to the Trend Micro software usually includes the right to product updates, pattern file updates, and basic technical support for one (1) year from the date of purchase only. After the first year, Maintenance must be renewed on an annual basis at Trend Micro's then-current Maintenance fees. You can contact Trend Micro via fax, phone, and email, or visit us at: http://www.trendmicro.com Evaluation copies of Trend Micro products can be downloaded from our web site. Global Mailing Address/Telephone numbers ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ For global contact information in the Asia/Pacific region, Australia and New Zealand, Europe, Latin America, and Canada, refer to: http://www.trendmicro.com/en/about/overview.htm The Trend Micro "About Us" screen displays. Click the appropriate link in the "Contact Us" section of the screen. Note: This information is subject to change without notice. 9. About Trend Micro ====================================================================== Trend Micro Incorporated, a global leader in Internet content security and threat management, aims to create a world safe for the exchange of digital information for businesses and consumers. A pioneer in server-based antivirus with over 20 years experience, we deliver top-ranked security that fits our customers' needs, stops new threats faster, and protects data in physical, virtualized and cloud environments. Powered by the Trend Micro Smart Protection Network(TM) infrastructure, our industry-leading cloud-computing security technology and products stop threats where they emerge, on the Internet, and are supported by 1,000+ threat intelligence experts around the globe. For additional information, visit www.trendmicro.com. Copyright 2014, Trend Micro Incorporated. All rights reserved. Trend Micro, the t-ball logo, Smart Protection Network, and InterScan are trademarks of Trend Micro Incorporated and are registered in some jurisdictions. All other marks are the trademarks or registered trademarks of their respective companies. 10. License Agreement ====================================================================== Information about your license agreement with Trend Micro can be viewed at: http://us.trendmicro.com/us/about/company/user_license_agreements/ Third-party licensing agreements can be viewed: - By selecting the "About" option in the application user interface - By referring to the "Legal" page of the Getting Started Guide or Administrator's Guide
