Anupam Pavithran
A python based script to generate report if there are double logging on FMC ACP (logging at beginning and end), having rule action "Allow" or "Trust". (Option1 )
Also, the logging at the begging will be disabled if logging is detected for both beginning and end. (Option 2)
Preparation
Step 1 Download the script on PC
Step 2 Make sure python3 is installed on PC and have reachability to FMC on 443)
Step 3 Make sure API is enabled on FMC (System -> Configuration -> Rest API Preference -> Enable REST API )
Step 4 Create a separate user on FMC to use during script execution
Step 5 Make sure proper permission is given to script to execute (This applies specifically if you're executing script from linux machine)
Both the python files "logging_main_1.9.py" and "rule_writer.py" is needed. A zipped enclosed.
Executing the script
1. Enter the IP of the FMC
2. Username and password (Make use of a separate user for running API based script on FMC)
3. Select the ACP you want to detect double logging.
4. You can either choose to just generate the report or
5. Generate report along with changing the logging to end of connection and save the changes.
        PS C:\Users\anupam\Desktop\scripts\loggin_main_1.9.py> python logging_main_1.9.py
        #               ACCESS CONTROL POLICY                     #
        #         anpavith              Cisco Systems India       #
        Enter the device IP address  : 10.106.55.55
        Enter the username of the FMC: api
        Enter the password of the FMC:
        #             ACCESS CONTROL POLICY LIST                  #
        1 5585-SFR
        2 Blank Policy
        3 Copy of Delhi Shared
        4 FTD-Mig-ACP-1613142830
        5 FTD-Mig-ACP-1615773808
        6 HELIUM
        7 BACKUP-SERVER-FW
        8 SERVER-FW-BACKBONE
        9 M_FW01-Updated
        Choose the ACP Number (integer value):8
                        Available operations on ACP
        1. Report rules with Action = Allow, LogBeg & LogEnd
        2. Disable logging at Beg if Allow, LogBeg & LogEnd
        Enter your selection (integer value) : 1
        Processing, Please Wait
        Retrived all rules from  SERVER-FW-BACKBONE
        Total number of rules in Access Control Policy      :  7965
        Number of rules with Allow action & LogBeg & LogEnd :  985
        The report has been created with name  ACP_SERVER-FW-BACKBONE_Report_1617188521.9678984.csv
Note: To be on safer side, create copy of policies you want to disable logging and run the script on them.
Please use the script and let us know if you run into any issues. Let us know for any other improvement on this as well.
 -/|nupam
