  • FP URL filtering capability can classify the URLs based on:
    • Categories (classification)
    • Reputation (risk level)
      • This varies from High Risk (level 1) to Well Known (level 5)
    • Category + Reputation
    • Manual URLs
  • If you select a reputation level to allow, all level below it will be allowed. Similarly, if you select a reputation level to block, all above levels will be blocked
Selected Reputation Level
Selected Rule Action
High Risk
Suspicious Site
Benign Site with Security Risk
Benign Site
Well Known
1 - High Risk
Block, Allow
Allow
Allow
Allow
Allow
2 - Suspicious Sites
Block
Block, Allow
Allow
Allow
Allow
3 - Benign Sites with Security Risk
Block
Block
Block, Allow
Allow
Allow
4 - Benign Sites
Block
Block
Block
Block, Allow
Allow
5 - Well Known
Block
Block
Block
Block
Block, Allow
  • URL filtering can be configured in
    • HTTP
      • FP will perform URL filtering for plain text traffic (either HTTP traffic or decrypted HTTPS traffic)
      • Its configured in ACP by matching HTTP application and configuring URL Filter
    • HTTPS Filtering
      • FP detects the URL during SSL handshake from the certificate CN
      • HTTPS URL filtering disregards subdomains  in the CN and matches the root domain only (unlike HTTP which consider subdomains in HTTP requests)
        • For example, if the CN contains www.example.com, FP will match example.com only
      • Its configured in ACP by matching HTTPS application and configuring URL Filter
    • SSL
      • Manual URL filtering isn't supported in SSL
      • Its configured in SSL Policy to match categories
  • Manual URL Filtering
    • You can override URL Categories and Groups by configurating manual URLs
    • Wildcard isn't support
    • For example, if you block a URL category which contains a single URL to be whitelisted, you can configure a rule with the whitelisted URL added manually before the blocking rule
    • When configuring Manual URLs, any match of the URL string will trigger action. For example, if you allow all traffic to example.com, your users could browse to URLs including:
http://example.com/
http://example.com/newexample
http://www.example.com/
Note: To see URL category and reputation information in events and application details, you must create at least one rule with a URL condition
  • Limitations of URL Filtering
    • Connection will establish 3-way TCP handshake. Once SSL Exchange starts or HTTP request received, FP will be able to action (3-5 packets)
    • Uncategorized URLs will pass through FP unless they are explicitly blocked
    • FP won't block searches on blocked categories. For example, using a web search to search for amazon.com is not blocked, but browsing to amazon.com is blocked
    • Due to low memory, low level appliances will use more generic matches. Example, the system might evaluate mail.google.com using the google.com category and reputation
      • Impacted models are ASA5506-X, ASA5506H-X, ASA5506W-X, ASA5508-X, ASA5512-X, ASA5515-X, ASA5516-X, and ASA5525-X
  • You can configure HTTP Response page (which will be displayed when ACP action is Block/Block with reset) and Interactive HTTP Response page (which will be displayed when ACP action is Interactive Block/Interactive Block with reset)
    • It won't be displayed for HTTPS blocked URLs
TIP
  • You can use URL filtering rule for allowing HTTPS access to a website while blocking HTTP access which is for security reason
    • Create an ACP rule which matches HTTPS application and X URL - Action Allow
    • Create an ACP rule which matches HTTP application and X URL - Action Block
How URL Lookup Process works?
In order to accelerate the URL lookup process, the URL filtering provides a dataset that is installed on a Firepower System locally. Dependent upon the amount of memory (RAM) available on an appliance, there are two types of datasets:
Type of Dataset
Memory Requirement
On Version 5.3
On Version 5.4 or higher
20 Million URL Dataset
> 2GB
> 3.4 GB
1 Million URL Dataset
<= 2GB
<= 3.4 GB
lnauman
How do you notify a worker that the HTTPS website he visited is blocked by the IT department?
I dont understand how the worker can know that if you cannot configure HTTP response page for HTTPS blocked URL.
Thanks in advance,
Lucas
David Miller
Hi Lucas,
You can configure a HTTP block page as normal and use SSL decryption to decrypt blocked sites first, this way the end user will still see a block page response, rather than a timeout on those blocked pages.
Kind Regards,
David
Xiaosheng Yu
Hi,sir
I want to know if it affects Manual URL Filtering? I wanted to use the FTD's Manual URL Filtering to manage the whitelist strategy for data center access to the Internet.
fatalXerror
Level 5
Level 5
Hi @Mohammed al Baqari ,
Can I use URL filtering together with application control? My use case is to allow FTP using a specific URL.
