TCC_2
Level 10
Level 10
Introduction:
This dcoument describes the process to assign STATIC IP Addresses to VPN Clients.
Two types of IP's:
  • Dynamic IP Addresses:Dynamic IP can be defined as an IP address which changes every time the device logs in to a network. To trace such IP address is very tough.
  • Static IP Addresses:A static IP can be defined as an IP address which is manually configured on a device.A static IP address is known "static" because it does not change.
Resolution
In this example, three groups are created, each with its own pool and with just one IP address. The inside network is 192.168.1.0/24:
ip local pool group1 172.16.99.1
ip local pool group2 172.16.99.2
ip local pool group3 172.16.99.3
access-list nonat permit ip 192.168.1.0 255.255.255.0 172.16.99.0 255.255.255.0
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 99 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
sysopt connection permit ipsec
isakmp nat-trav
isakmp identity address
isakmp keepalive 10 2
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
(the actual vpn groups):
vpngroup group1 password MYPASSWORD
vpngroup group1 address-pool group1
vpngroup group1 dns 192.168.1.5
vpngroup group1 wins 192.168.1.5
vpngroup group2 password MYPASSWORD
vpngroup group2 address-pool group2
vpngroup group2 dns 192.168.1.5
vpngroup group2 wins 192.168.1.5
vpngroup group3 password MYPASSWORD
vpngroup group3 address-pool group3
vpngroup group3 dns 192.168.1.5
vpngroup group3 wins 192.168.1.5
wr mem
You may add as many VPN groups as you wish. Each group must contain a password and an address pool. The Domain Name System (DNS) and Windows Internet Naming Service (WINS) statements are optional.
Problem Type
How to (General Information)
Product Family
Firewall - PIX 500 series
VPN - hardware & software clients
PIX Software Version
PIX version 6.x
PIX version 5.x
VPN Client Software Version
Cisco VPN Client
VPN Tunnel End Points
Client
PIX
Features & Tasks
Local address pool
VPN Protocols
IPSec
radioman1000
Not really helpful
PIX_500 is obsolete
I need to support PPTP in a router.  It doesn't have to have WiFi.
Can any of the RV series routers support PPTP and static VPN address?
Sam
