TCC_2
Level 10
Level 10
Core issue
Unable to configure ASA 5500 tp establish a Citrix connection to a unix host
Resolution
To resolve this issue, perform these steps:
  1. Make sure the policy map command has been issued.
  2. Check for the %ASA-6-602101: PMTU-D packet 1420 bytes greater than effective mtu 1350, dest_addr=, src_addr=, prot=TCP %ASA-2-106017: Deny IP due to Land Attack from to error in the log.
  3. Change the tcpmss size  to a value that is permissible according to the log. Set it to 1300, as shown in this example:
    ASA5510#conf t
    ASA5510(config)# mtu outside 1500
    ASA5510(config)# sysopt connection tcpmss 1300
For more information, refer to the cysopt connection tcpmss command.
