minkumar
This document will give you the bare minimum to provide RADIUS authentication to your Cisco Devices using Microsoft Internet Authentication Service (IAS) RADIUS server. Using RADIUS on your Microsoft server to authenticate Cisco devices allows you to use the same usernames and passwords on your Windows servers and Cisco devices.
Steps
1) Install IAS
2) Configure IAS
3) Configure Cisco Device
4) Test
1) Install IAS
Click "Start > Control Panel > Add & Remove Programs"
Click "Add/Remove Windows Components"
Double-Click "Networking Services"
Select "Internet Authentication Service"
Click "Ok"
2) Configure IAS
Click "Start>Programs>Administrative Tools>Internet Authentication Service"
*** Create Remote access Policy *** (left Pane)
Select "Remote Access Policies"
(right pane) Delete all policies
(right pane) Right-Click and Select "New Remote Access Policy"
Click "Next" Select "Set up a custom policy" and give it a name
Click "Next"
Click "Add"
Select "Windows Groups"
Click "Add" Type "Domain Admins" (or any other group you would like to use)
Click "Ok"
Click "Next"
Select "Grant remote access permission"
Click "Next"
Click "Edit Profile"
Select the "Authentication" tab
Select "Unencrypted Authentication" only
Select the "Advanced" tab
Change the service-type from "framed" to "login"
Delete "Framed-Protocol" Click "Add"
Select "Vendor Specific" Click "Add"
Select "Cisco" from the drop-down box
Select "Yes. It conforms" Click "Configure Attribute"
Change Attribute Number to "1"
Set the Attribute Format to "String"
Type "shell:priv-lvl=15" in the Attribute Value field
Click "Ok"
Click "Ok"
Click "Close"
If you get an error, select yes or no …. it doesn’t matter.
Click "Next"
Click "Finish"
*** Add Radius Clients ***
(Left Pane) Click "RADIUS Clients"
(Right Pane) Right-Click and click "New Radius Client"
Give the client a friendly name and enter the ip address
Click "Next"
Enter a shared secret password
Click "Finish"
*** IOS Configuration ***
aaa new-model
radius-server host 192.168.10.100 key P@ssw0rd
ip radius source-interface f0/0
aaa authentication login default group radius
aaa authorization exec default group radius
local line vty 0 4
   login authentication default
Minakshi
anuj_dev007
Community Member
Hi Minskshi,
Please could you provide us step by step configuration for better understanding.
Anuj Kumar.
