Introduction
Cisco TrustSec (CTS) solution is also known as Adaptive Policy in the Meraki world. In the Cisco world TrustSec gets configured and managed centrally using Identity Services Engine (ISE) and Adaptive Policy in the Meraki world gets configured and managed by Meraki Dashboard so far. However, now adaptive policy too can be configured and managed centrally from ISE. Adaptive policy gets pushed into the Meraki Dashboard once it is configured in the ISE using API. This capability is available in ISE3.2 Patch1 and onward.
At the time of release of this integration feature, policies are getting pushed one way from ISE to Meraki Dashboard. This makes ISE a centralized place to configure and manage policy for the Cisco and Meraki based network together.
Lab Setup
ISE 3.2 patch was deployed in Data Center environment and Meraki Dashboard is in Internet in the Cisco Cloud. To integrate these two components, tcp port 443 was opened in perimeter firewall. Once it is integrated, all the configured SGT, SGACL and SGT policy will be pushed to the Meraki Dashboard.
Note: this solution works with web proxy too.
Prerequisites
- ISE Version 3.2 Patch 1 and above
- Meraki Dashboard admin account
- ISE admin account
- ISE to Meraki Dashboard connectivity on URL api.meraki.com on port 443
- Meraki Integration required at least ISE Advantage license.
Flow Diagram
Note: Firewall is present in the flow diagram becuase almost every organization will have firewall at the perimeter of on-prem Data Center. If firewall is not present between ISE and Meraki dashboard then it will establish direct connection.
Configuration
Integration of ISE and Meraki Dashboard
Step 1. Generate API from Meraki Dashboard
- Login to Meraki Dashboard --> Go to My profile --> API access and Generate an API Key and copy that key in a safe place.
Step 2. Login to ISE
- Login to ISE --> Go to to Work Centers--> TrustSec --> Intergrations --> Meraki --> Connections --> Click Connect Meraki --> Click Let’s do it!
- Provide below details:
- Connection: Provide any name
- API Key: Paste the API key which was generated in Meraki Dashboard
- Choose Meraki Organization: Select the Organization to which data need to be synced
- Click next and let the timer be default12 minutes to sync the data from ISE to Meraki periodically
- Select the Policy which you need to sync to Meraki (This can also be done later as well) and Click Next.
- Select SGACL which need to be Synced to Meraki (This can also be done later as well)
- Select the SGTs which you need to sync to Meraki (This can also be done later as well) and Click Next.
- Review the summary of the configuration and click Finish and refresh the page to see below for a successful integration.
Sync data from ISE to Meraki
- All the SGTs, Polices and SGACL created under Components and TrustSec Section will be reflected under the Meraki -> Sync Selection page where you can select which SGTs, Policy or SGACL which need to sync to Meraki Organization.
- Go to Work Centers - > Integrations - > Meraki - > Sync Selections and select the Policy, SGTs and SGACL which need to be sync to Meraki and click Save.
- Now, go to Work Centers - > Integrations - > Meraki - > Sync Status and wait for data to Sync Now to Meraki or click Manual Sync.
- Once data will be synced to Meraki you will see as below as status:
Verify the policy, SGTs and SGACL on Meraki
Navigate to Organization - > Adaptive Policy - > Groups to verify all the SGT groups are pushed from ISE to Meraki.
Navigate to Organization - > Adaptive Policy - > Policies to verify all the SGT based Policies are pushed from ISE to Meraki.
Testing & Troubleshooting
Collect the support bundle for troubleshooting purpose by enabling "Meraki Connector" as in screenshot below:
Limitation
The following limitations are known at the time of writing this document.
- One ISE or one ISE cluster can push the policy for 20 organizations under a Meraki Dashboard account.
- Static IP/Subnet to SGT mapping cannot be pushed to the Meraki Dashboard.
- One ISE or one ISE cluster can push only one TrustSec matrix to all the organizations of a Meraki Dashboard.
- Meraki dashboard can push max 60 SGT and policy between them in the Meraki Network.
- SXP is not supported for the Meraki Network Devices.
