TCC_2
Level 10
Level 10
Core issue
One arm routing is not working with ASA 5500
Resolution
One arm routing is not supported in Adaptive Security Appliance (ASA)/PIX Firewall versions earlier than 7.2, which means that they did not have the ability to re-send traffic from the same interface.
This functionality in PIX/ASA version 7.2 requires Network Address Translation (NAT)/Port Address Translation (PAT) to mask the source and ensure the traffic is not asymmetric.
Issue the same-security-traffic command, but with the inter-interface argument, to permit communication between interfaces that have the same security level. This feature is not specific to IPSec connections. The command syntax is same-security-traffic permit {inter-interface | intra-interface}.
This example shows how to enable intra-interface traffic:
hostname(config)# same-security-traffic permit intra-interface
Product Family
ASA Hardware & Software
ASA Models
ASA 5500
Features & Tasks
One Arm Configuration
