athukral
Level 4
Level 4
Introduction
This document is a quick reference to configure BGP pass through Firewall device.
Prerequisites
Routers and ASA
Concept
As we all know that ASA do port  randomization whenever traffic traverses through ASA, that is why BGP  does not work through the ASA. Hence, we need to do appropriate  configuration on ASA so that bgp traffic can traverse through ASA.
Network   Diagram
Configuration Sample
access-list outside permit tcp host 1.1.1.1 host 2.2.2.2 eq bgp
tcp-map bgp
tcp-options range 19 19 allow
class-map bgp
match port tcp eq bgp
policy-map global_policy
class bgp (where bgp is class name )
set connection random-sequence-number disable
set connection advanced-options bgp (where bgp is tcp-map name)
Related   Information
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009487d.shtml
https://supportforums.cisco.com/docs/DOC-21347
