Blue_Bird
                                                               Site-to-Site FlexVPN through Static VTI Implementation
Lab Topology
R1 Configuration
Step-1: Configure domain name
R1(config)# ip domain-name test.com
Step-2: Configure Keyring
R1(config)# crypto ikev2 keyring KR
R1(config-ikev2-keyring)# peer R2
R1(config-ikev2-keyring-peer)# address 2.2.2.2
R1(config-ikev2-keyring-peer)# pre-shared-key local cisco@123
R1(config-ikev2-keyring-peer)# pre-shared-key remote cisco@123
R1(config-ikev2-keyring-peer)# exit
Step-3: Create ikev2 profile
R1(config)# crypto ikev2 profile PRO1
R1(config-ikev2-profile)# match identity remote fqdn R2.test.com
R1(config-ikev2-profile)# identity local fqdn R1.test.com
R1(config-ikev2-profile)# authentication local pre-share
R1(config-ikev2-profile)# authentication remote pre-share
R1(config-ikev2-profile)# keyring local KR
R1(config-ikev2-profile)# exit
Step-4: Create IPSec Transform Set
R1(config)# crypto ipsec transfrom-set transform-1 esp-aes 256 esp-sha-hamc
R1(cfg-crypto-trans)# mode tunnel
R1(cfg-crypto-trans)# exit
Step-5: Create ipsec profile
R1(config)# crypto ipsec profile ipsec-profile-1
R1(ipsec-profile)# set transform-set transform-1
R1(ipsec-profile)# set ikev2-profile PRO1
R1(ipsec-profile)# exit
Step-6: Create Tunnel Interface
R1(config)# interface tunnel0
R1(config-if)# ip address 10.1.1.1 255.255.255.0
R1(config-if)# tunnel source fastEthernet 0/0
R1(config-if)# tunnel destination 2.2.2.2
R1(config-if)# tunnel protection ipsec profile ipsec-profile-1
R1(config-if)# exit
Step-7: Routing Configuration (static/dynamic)
R1(config)# Router eigrp 1
R1(config-router)# network 192.168.1.1 0.0.0.0
R1(config-router)# network 10.1.1.0 0.0.0.255
R1(config-router)# no auto-summary
R1(config-router)# exit
R2 Configuration
R2(config)# ip domain-name test.com
R2(config)# crypto ikev2 keyring KR
R2(config-ikev2-keyring)# peer R1
R2(config-ikev2-keyring-peer)# address 1.1.1.1
R2(config-ikev2-keyring-peer)# pre-shared-key local cisco@123
R2(config-ikev2-keyring-peer)# pre-shared-key remote cisco@123
R2(config-ikev2-keyring-peer)# exit
R2(config)# crypto ikev2 profile PRO1
R2(config-ikev2-profile)# match identity remote fqdn R1.test.com
R2(config-ikev2-profile)# identity local fqdn R2.test.com
R2(config-ikev2-profile)# authentication local pre-share
R2(config-ikev2-profile)# keyring local KR
R2(config-ikev2-profile)# exit
R2(config)# crypto ipsec transfrom-set transform-2 esp-aes 256 esp-sha-hamc
R2(cfg-crypto-trans)# mode tunnel
R2(cfg-crypto-trans)# exit
R2(config)# crypto ipsec profile ipsec-profile-1
R2(ipsec-profile)# set transform-set transform-2
R2(ipsec-profile)# set ikev2-profile PRO1
R2(ipsec-profile)# exit
R2(config)# interface tunnel0
R2(config-if)# ip address 10.1.1.2 255.255.255.0
R2(config-if)# tunnel source fastEthernet 0/0
R2(config-if)# tunnel destination 1.1.1.1
R2(config-if)# tunnel protection ipsec profile ipsec-profile-1
R2(config-if)# exit
R2(config)# Router eigrp 1
R2(config-router)# network 192.168.2.2 0.0.0.0
R2(config-router)# network 10.1.1.0 0.0.0.255
R2(config-router)# no auto-summary
R2(config-router)# exit
Verification
.............................................................................................. Thank you very much..! .........................................................................
