Kureli Sankar
Configuration
https://community.cisco.com/t5/security-documents/snort-ips-on-isr-isrv-and-csr-step-by-step-configuration/ta-p/3369186
Troubleshooting
Unable to get signature update from cisco.com
1. Make sure the router can get name resolution. Configure the router with a proper DNS name server.
ISR4451#utd threat-inspection signature update server cisco username xxxxx password yyyyy
% This operation may cause the UTD service to restart which will briefly interrupt services.
Proceed with signature update? [confirm]
ISR4451#show utd engine standard threat-inspection signature update status
Current signature package version: 29.0.c
Current signature package name: default
Previous signature package version: None
Last update status: Failed
Last successful update time: None
Last successful update method: None
Last successful update server: None
Last successful update speed: None
Last failed update time: Wed Feb 14 09:01:16 2018 PST
Last failed update method: Manual
Last failed update server: cisco
Last failed update reason: ('Connection aborted.', gaierror(-2, 'Name or service not known'))
Last attempted update time: Wed Feb 14 09:01:16 2018 PST
Last attempted update method: Manual
Last attempted update server: cisco
Total num of updates successful: 0
Num of attempts successful: 0
Num of attempts failed: 1
Total num of attempts: 1
Next update scheduled at: None
Current status: Idle
The error highlighted in red above usually means DNS is failing to resolve cloudsso2.cisco.com sourced from the VirtualPortGroup0 interface. Once a proper DNS name server and the router is able to resolve cloudsso2.cisco.com to 173.37.144.211 source from virtual portgroup 0 interface, make sure to issue the following command to make sure the router can establish an https connection with the IP address
ISR4451#telnet 173.37.144.211 443 /source-interface virt0
Trying 173.37.144.211, 443 ... Open
Once this step is done signature update should happen without any problem as shown below:
Current signature package version: 2983.44.s
Current signature package name: UTD-STD-SIGNATURE-2983-44-S.pkg
Previous signature package version: 29.0.c
Last update status: Successful
Last successful update time: Wed Feb 14 09:38:32 2018 PST
Last successful update method: Manual
Last successful update server: cisco
Last successful update speed: 3212512 bytes in 19 secs
Last attempted update time: Wed Feb 14 09:38:32 2018 PST
Total num of updates successful: 1
Num of attempts successful: 1
Total num of attempts: 2
Unable to view the virtual service
Check memory available
ISR4451#show virtual-service
^ % Invalid input detected at '^' marker.
ISR4451#virtual-service install name myips package flash:iosxe-utd.16.07.01.1.0.1_
SV2983_XE_16_7.ova ISR4451#show log
Feb 9 18:54:45.096 PST: %VMAN-2-VIRT_INST_DISK: R0/0: vman: Virtual Service[UTD]:
:Disk reservation::Failed to reserve disk storage for virtual service::Disk storage
request (3210 MB) exceeds remaining disk space (3090 MB) on storage media
UTD_HEALTH_CHANGE: Service node changed state Down => Red (1)
Feb 22 12:00:49.283: %IOSXE-1-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:000 TS:00000000761565218623 %UTD-1-UTD_HEALTH_CHANGE:
Feb 22 12:01:10.871: %IOSXE_UTD-4-MT_CONTAINER_MESSAGE_TIMEOUT: UTD message sent to the container has timed out
Feb 22 12:01:42.871: %IOSXE_UTD-4-MT_CONTAINER_MESSAGE_TIMEOUT: UTD message sent to the container has timed out
Snort black holes traffic
Incorrect IP address configured on the guest (container) side
Packets go to the container but nothing comes back:
Encaps shows huge count but decaps shows nothing coming back out to the data plane.
CSR#show platform hardware qfp active feature utd stats
Diversion Statistics:
Redirect	137023
Encaps		137023
Decaps		     6
Reinject	             6
Check the configuration for misconfiguration.
Problem is because the container side IP address is a broadcast IP address.
interface VirtualPortGroup0
 ip address 172.30.50.121 255.255.255.252
 ip nat inside
 zone-member security zone-Inside
interface VirtualPortGroup1
 ip address 192.0.2.2 255.255.255.252
utd engine standard
 logging syslog
threat-inspection
 threat detection
 policy connectivity
 logging level debug
utd
 engine standard
 all-interfaces
virtual-service utd
 vnic gateway VirtualPortGroup0
  guest ip address 172.30.50.122
 vnic gateway VirtualPortGroup1
  guest ip address 192.0.2.3 =======> misconfigured with bcast address
 activate
IP address is being used some where else in the network
The IP address used on VPG1 on the router side and the guest side was already being used else where in the network and it was routed to null.  All the packets that were diverted to the UTD engine didn't make it to the UTD engine at all.  There by black holing traffic. A ping sourced from VPG1 destined to vnic gateway VirtualPortGroup1 IP address failed.
Refer to this defect:
CSCvi11665
When does engine status show as yellow?
There is hysteresis in the checking algorithm. When the memory usage is going up, it won't become yellow until crossing 95%. When the usage is going down, the health won't come back to green until crossing 90%.
sri.thotakura
I'm having issue related to SNORT Service Node showing Down. I have double checked the configuration on Router and didn't find any mistake.
Service Node Statistics:
SN Health: Down
Stats were all zero
Redirect failed, SN unhealthy 194538
Can you please suggest what might gone wrong here
I have opened a Cisco Case as well - Case # 684655355
unvacs
I got the following error:
Router#app-hosting install appid UTD package bootflash:secapp-utd.17.09.05a.1.0.9_SV2.9.18.1_XE17.9.x86_64.tar
The process for the command is not responding or is otherwise unavailable!!!!
What should I do?
/Mohammed
