eric.lessard
Hello!
a real newbe question.. am trying to setup a trunk between ASA5510 and a 3750G
all seems fine but cannot ping the ASA Ethernet0/1.12 from catalyst and not more from the asa to catalyst.
Am missing something but cannot find it
i have created a trunk on the catalyst:
ip routing
no ip domain-lookup
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 12
name vlan12
interface GigabitEthernet1/0/1
description trunk to ASA inside
switchport mode dynamic desirable
switchport trunk allowed vlan 12
interface GigabitEthernet1/0/7
description Port client
switchport access vlan 12
spanning-tree portfast
interface Vlan12
ip address 10.56.1.2 255.255.255.0
ip default-gateway 10.56.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.56.1.1
asa:
ASA Version 8.2(5)
hostname ciscoasa
interface Ethernet0/0
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/1
no nameif
security-level 100
no ip address
interface Ethernet0/1.12
vlan 12
nameif reseau_local
security-level 100
ip address 10.56.1.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 15
ip address 192.168.10.88 255.255.255.0
object-group network inside_network
network-object 10.56.0.0 255.255.0.0
ftp mode passive
same-security-traffic permit intra-interface
access-list nonat_inside extended permit ip object-group inside_network any
access-list local_in extended permit icmp any any
access-list local_in extended permit ip any any
nat-control
nat (reseau_local) 0 access-list nonat_inside
access-group local_in in interface reseau_local
route reseau_local 0.0.0.0 0.0.0.0 10.56.1.4 1
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect icmp
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
service-policy global_policy global
prompt hostname context
ciscoasa#
Any Idea?
