Mourad ESSID
Community Member
I need to setup two Tunnel ipsec with different PSK to same peer address on PIX 515E V7.2
Thanks for you help
Mourad ESSID
Community Member
Also there is a traffic that will pass the first VPN tunnel and another trafic that will pass through the second Tunnel.
Jouni Forss
You should post this on the discussion are rather than the documentation area of the Cisco Support Community.
With regards to your question, I dont think this is possible. You can only have 1 L2L VPN connection with a peer IP address. Naturally you can include many local and remote networks in that one L2L VPN connection. But you cant have several L2L VPN connections configured between the same peers
- Jouni
