suddesai
Introduction
This script was written to gather the current software version, SRU version, and VDB version from remote Sensors.
get_sensor_sw_versions.pl
To execute the script, first copy the script onto the Defense Center. The script can be run from any directory, but for convention /var/common, /var/tmp, and /Volume/home/admin, are most often used. The following example uses /Volume/home/admin:
admin@dc:~$ ls
Then, elevate privileges with "sudo -i" to allow the script to run all the commands it needs to operate properly and change back to the directory where the script was copied:
admin@dc:~$ sudo -i
Password:
root@dc:~# cd /Volume/home/admin/
root@dc:/Volume/home/admin# ls
Then run the script:
root@dc:/Volume/home/admin# perl get_sensor_sw_versions.pl
The output file will be placed into /var/common with the following format:  hostname_version_info.csv
Please contact me for any enhancement requests.
Output:
This script collects current software/VDB/SRU versions to CSV file in /var/common/:
Warning: Using a password on the command line interface can be insecure.
File created: /var/common/dc_version_info.csv
Sample output:
root@dc:/var/common# cat dc_version_info.csv
DEVICE, IP, MODEL, SN, SWVERSION, SRU, VDB
543dSensor, 169.254.11.22, Virtual Device 64bit, None, 5.4.0.7, 2016-07-25-001-vrt, 271
Compatibility Information:
Version
Verified
Additional Information
5.4
6.0
6.0.1
6.1
6.2
Platform
Verified
SFR module
3D sensor
FMC
FTD
FX-OS
Not tested against this platform yet.
NOOKALARAMU
Hi Sudhir,
Can you please add another step where we can get sensing interface (s1p1 or s2p2..), Group and Domain info columns for sensors?
Ramu
suddesai
Hi Ramu,
I will look into adding this to the script.  I do not think it should be an issue; but will need some time to check it out and add the features.
Thank you for the suggestion!
Cheers,
Sudhir
suddesai
Hi all, please use this script (https://github.com/Lv2hack/fmc-api) to pull the same information that the perl script used to provide. It leverages the FMC API and is currently supported.
