Resolution
The management application choice depends on the sensor version you are using:
If you are using an Intrusion Detection System (IDS) Sensor version earlier than 3.1, you can use:
If you are using IDS Sensor version 3.1 or later, you can use:
Note: IDSMC should be used for larger deployments in enterprises. To configure and manage up to three sensors, the IDS Device Manager (IDM) is more appropriate.
For more information on IDS management software, refer to the Cisco Intrusion Detection System page.
