ASA - NAT rule problem
Mohamed Hamid
Hi Guys
I have a DMZ and a Clientnetwork in place, I require that my proxy servers in the DMZ be able to authenticate with my ldap server in the clietnnetwork.
I have created a NAT rule as follows
interface (clientNetwork) Ldap Server >> Interface (DMZ) Translated IP
I would expect that my proxy server would then be able to ping the translated IP but this is not hte case. Do I also need to create an access rule? or am I missing something?
Apologies if this question is a simple one but I am new to cisco asas and slowly getting by
Your help would be much appreciated
Kind Regards
Ridha
varrao
Level 10
Level 10
Can you share the following outputs:
show run nat
show run static
show run global
show ip
this would help me.
Varun
Varun Rao
Hi Varun
Please find outputs below
nat (dmzdata) 0 access-list ALLRAS
nat (AHdata) 0 access-list ALLRAS
nat (AHdata) 1 10.0.1.0 255.255.255.0
nat (dmzAHmgmt) 0 access-list ALLRAS
nat (dmzAHmgmt) 1 10.1.2.0 255.255.255.0
nat (AHmgmt) 0 access-list ALLRAS
nat (AHmgmt) 1 10.1.1.0 255.255.255.0
asa-L# sh run static
static (dmzdata,AHmgmt) 10.1.1.37 ProxyVIP netmask 255.255.255.255
static (AHdata,dmzdata) 192.168.9.9 macserver netmask 255.255.255.255
global (dmzdata) 1 interface
global (AHdata) 1 interface
global (dmzmgmt) 1 interface
global (AHmgmt) 1 interface
System IP Addresses:
Interface                Name                   IP address      Subnet mask                                               Method
GigabitEthernet0/0       dmzdata                x            255.255.255.0                                             CONFIG
GigabitEthernet0/1       AHdata                 x            255.255.255.0                                             manual
GigabitEthernet0/2       dmzmgmt                x            255.255.255.0                                             CONFIG
GigabitEthernet0/3       folink                 x            255.255.255.0                                           unset
Management0/0            AHmgmt                 x            255.255.255.0                                             CONFIG
Hi there
just to add it appears a ping request from the proxy server is being denied by the ACL on the asa.
I can see this from the syslog and thus suggests I need to enable or add something in the acl as well as the NAT rule?
