CSM 3.3.1 and 6500
We are facing a problem with CSM 3.3.1 and 6500 switch with FWSM. We have 2x 6500 switches with 2 supervisors in each + 2 FWSM cards one in each chassis. The problem is that we have CSM 3.3.1 that manages the switch and FWSM. The problem is that when we try to delete a VLAN in 6500 we get a deployment failure because the switch outputs this message:
% Applying VLAN changes may take few minutes. Please wait..
We are using the following IOS version.
CSR-CORE#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI2a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 02-Sep-09 01:00 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX6, RELEASE SOFTWARE (fc1)
CSR-CORE uptime is 22 weeks, 6 days, 23 hours, 59 minutes
Uptime for this control processor is 22 weeks, 6 days, 23 hours, 55 minutes
Time since CSR-CORE switched to active is 22 weeks, 6 days, 23 hours, 55 minutes
System returned to ROM by  power cycle at 06:42:16 UTC Fri Feb 12 2010 (SP by power on)
System restarted at 11:10:39 EEST Mon Jun 14 2010
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI2a.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC1401000U
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
30 Virtual Ethernet interfaces
116 Gigabit Ethernet interfaces
12 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
CSR-CORE#
Note that we are NOT using VSS.
TIA,
Nicos
TIA, Nicos Nicolaides
Stefano De Crescenzo
Hi Nicolas,
did Panos answer answers your question? Otherwise let us know and we will investigate further.
Stefano
Panos Kampanakis
Geia sou Niko,
I would suggest looking into https://supportforums.cisco.com/docs/DOC-14307#212_Failed_deployment
Your deployment fails because the parser doesn't consider the warning as a success code. Your workaround for these commands could be a FlexConfig that pushes the command.
I hope it helps.
PK
Hi Nicolas,
Stefano
Hi all,
Sorry for not replying earlier. We found a workaround, as quoted below:
Changing How Security Manager Responds to Device Messages
Security Manager has built-in responses to many of the response messages that can be encountered when configuring a device. You might find that messages Security Manager treats as errors are messages that you want to ignore or treat as informational. Although you can configure your deployment jobs to ignore errors, you might instead want to update Security Manager to treat specific messages differently. To change how Security Manager treats a message, you need to update the DCS.properties file in \CSCOpx\MDC\athena\config folder in the installation directory (usually c:\Program Files).
Use a text editor such as NotePad to update the file. It is easiest to determine the message you want to ignore by looking at the transcript of a deployment job that encountered the error using these steps:
Step 1 Select the job with the error message from the Deployment Manager window.
Step 2 Click the Transcript button in the Deployment Details tab to open the transcript.
Step 3 Identify the error text that you want to ignore.
Step 4 Locate the appropriate warning expressions property in the DCS.properties file. For example, for PIX devices the property is called dev.pix.warningExpressions, whereas for IOS devices the property is called dev.ios.warningExpressions.Conversely, you can make device responses that are not tagged with the Error prefix to appear as error messages. To do this, add the message to the Error Expressions list (for example, dev.pix.ErrorExpressions).
Step 5 Add the error text to the warning expressions list. The warning message should be a generic regular expression string. Except for the last expression, you must delimit all expressions with “$\”. For example, if the message you want to ignore is “Enter a public key as a hexadecimal number,” enter the following string: .*Enter a public key as a hexidecimal number .*$
Step 6 Restart the CiscoWorks Daemon Manager
This has resolved the issue successfully
