Cat 5505 Help
steve.barnes
Frequent Visitor
Frequent Visitor
I've just brought a cisco Cat 5505 and it is not booting. The unit has the following cards installed:
Slot 1: Blank
Slot 2: WS-5530-E3
Slot 3: WS-X5302
Slot 4: WS-X5224
Slot 5: WS-X5224
I have tried moving all cards up one slot so the supervisor engine is in Slot 1 but this did not work.
The Supervisor III card is displaying Status LED red and Active LED amber. There are no LED's on for PSU 1 and 2 or Fans. When I connect to the console port (using a straight through cable) I get nothing. The WS-5302 RSM has a Status LED of amber and the cpu halt and enabled LED are lit green. Also both the WS-X5224 modules have an amber LED status.
All the fans and PSU?s look to be functioning correctly. Is there anything else I can try? I think it's a dead supervisor board.
Any suggestions would be appreciated.
Steve
steve.barnes
Frequent Visitor
Frequent Visitor
I've sorted it I think.
I re-seated all components on the WS-5530-E3 Supervisor card. Something must have come loose during shipping.
Steve
Hi Steve,
should slot0: not be filled with the supervisor?
Mine is!
Eric Sanders
esanders
Steve,
next suggestion; Did you connect to the console port with two(2) cisco cables, not with just one(1)!
Eric Sanders
emazurek
Hi Steve,
Here's a link to a troubleshooting guide:
http://www.cisco.com/en/US/products/hw/vcallcon/ps2027/products_maintenance_guide_chapter09186a00807dc03e.html
Here's what it says:
Replacing the Supervisor Engine
Note that the supervisor engine must go in slot 1 and the redundant supervisor engine in slot 2.
So, that's where I'd start. Move just the
WS-X5530-E3 blade up to slot 1. While your're
doing this check the pins in the back of the
blade and the inside the chassis (use a flashlight) and look for bent ones.
When you put the sup in slot 1 what do the
lights look like?
Are there any flashcards installed?
I'm not sure if any of that will help or not.
The sup may just be dead.
Ed Mazurek
